5VZ-FE Cylinder Head Port Molds - CustomTacos.com Forum
Old 11-05-2012, 10:12 PM   #1
digitalfiend
Member
Tacoma: 2003 Double Cab Prerunner
Default 5VZ-FE Cylinder Head Port Molds
I'm porting a set of cylinder heads for my 5VZ-FE rebuild. I'll have a thread or two in the future on my progress and the finished project once completed. My plan for this thread is to share my resources that I learned this from and the photographs of the molds of the stock unchanged ports.
I originally learned about head porting from my Dad. He's ASE certified and builds FAST smallblock Ford V8's. He's ported his own cylinder heads in his garage for all the years that I remember growing up.
I read about port molds in David Vizzard's book "How to Port & Flow Test Cylinder Heads" (ISBN 1934709646) - my Dad loaned me a copy (thanks Dad!). However, it wasn't until I came across an article on diyporting.com that clearly outlined the port mold creation process and provided a list of material that is easy to obtain: http://www.diyporting.com/molds.html
To state it simply, the idea of creating port molds is to see the form of the ports in order to get a better idea of how they can be reshaped so that power increases can be obtained by reshaping the port. My port modification will be limited to removing material - I don't plan on doing any radical port reshaping or adding material.
The supplies I used to make these molds include:
1) A set of cylinder heads (this should be obvious )
2) RTV silicone - any parts store should have this
3) A paint brush. Something cheap will suffice. Don't plan on using it for anything else because the silicone will probably ruin it.
4) A release agent. I used WD40 in a pinch and I didn't have great results. I will be using an alternative release agent in the future. See the previously mentioned diyporting.com article for a better release agent.
The first two pictures are of the 5VZ passenger-side cylinder head that the molds were made from, and the silicone RTV and paint brush I used.
digitalfiend is offline   Reply With Quote
Old 11-05-2012, 10:13 PM   #2
digitalfiend
Member
Default Re: 5VZ-FE Cylinder Head Port Molds
Intake port molds. Top, bottom, and side views. For now, I'm going to simply post these pictures. If there's enough demand I may update this post with my plans on changing the intake ports, or, after I'm done grinding and polishing the ports, I may simply post side-by-side before and after port molds.
Last edited by digitalfiend; 11-05-2012 at 10:37 PM. Reason: updating a placeholder to contain proper content
Old 11-05-2012, 10:14 PM   #3
digitalfiend
Member
Pictures of exhaust port molds. Side/corner and bottom.
Old 11-06-2012, 04:04 AM   #4
mitzu
Grand Tacoholic
mitzu's Avatar
Tacoma: 03 S Runnerrrr
Nice! I hope you get some decent gains from it. Do you plan on putting stock valves/springs/cams in it after youre done?
Stop being sexist.
Bitches hate that!
mitzu is offline   Reply With Quote
Old 11-06-2012, 06:06 AM   #5
digitalfiend
Member
I plan on reusing the stock valves (if they're within spec), stock cam, and new stock springs. When I last searched, upgrading the cams or valve train was too expensive for me.
Old 11-07-2012, 06:05 AM   #6
Texas_Ace
Addict
Texas_Ace's Avatar
Tacoma: 4Runner, 2000 limited
That is very cool, I have never seen that done before. I will have to keep that in mind for sure.
Do post what you plan to change, the ports are actually not as bad as I thought they would be from what I can see.
2000 Toyota 4runner Limited 3.4l V6 Auto SUPERCHARGED, Meth injection, 2.0" Pulley, Doug Thorley Headers - My truck - My Youtube with lots more
Member of the "No BOV Club"
Texas_Ace is offline   Reply With Quote
Old 11-07-2012, 07:03 AM   #7
mitzu
Grand Tacoholic
mitzu's Avatar
just FYI, I believe you can get Colt Cams to regrind your cams for about 500 bucks
Stop being sexist.
Bitches hate that!
Old 11-07-2012, 07:10 AM   #8
Greg_Canada
Grand Tacoholic
Greg_Canada's Avatar
Tacoma: 89 4runner (VZN61) and 99' 4runner Ltd (VZN185)
500 + shipping both ways, + new shims, it will still end up atleast 800 to get them done (the colt cams shims are crap)
Originally Posted by George Bush View Post
I believe everyone living in this great country should speak english. Just look at Canada, they all speak canadian up there....
MY photobucket album (tacoberfest, my trucks, etc)
http://s148.photobucket.com/albums/s35/Greg_Canada/?
Greg_Canada is offline   Reply With Quote
Old 11-11-2012, 09:30 PM   #9
hambone155
Newbie
hambone155's Avatar
Tacoma: 95.5 tacoma
what type of gains did you see?
hambone155 is offline   Reply With Quote
Old 11-12-2012, 06:53 AM   #10
Greg_Canada
Grand Tacoholic
No dyno yet... truck is still in build stage... just broke the motor in...
Whats the Difference between the 8 Port and 4 Port Head iGSR_VR Performance 10 04-04-2010 06:10 PM
WTB 2rz 4 port cylinder head 2rzfun4me Wanted 9 02-05-2010 01:11 AM
4 Port 2rz/3rz Cylinder Head ochizon Wanted 0 02-24-2009 06:46 AM
2/3rz 4 port cylinder head intake side specs ? Cruznlife1 Performance 10 09-16-2008 08:23 PM
Hmm.... Can I use an 8 port head where a 4 port used to be ? Cruznlife1 Performance 0 04-06-2008 08:52 PM
