2rz copper or mls head gasket - CustomTacos.com Forum
Old 10-20-2012, 03:06 PM   #1
ra22turbo
Member
ra22turbo's Avatar
Tacoma: 97
Default 2rz copper or mls head gasket
I have a 98 2rz that I want to install ARP head studs and a thick gasket in order to lower the compression ratio. my questions are where can I find the thickest gasket , and what material is better copper or mls ? Another question I have is if the engine never overheated do I need to mill the deck of the block and cylinder head or am I fine with just cleaning the mating surfaces? I was thinking about stacking two .50 mls gaskets and stacking them or a .90 copper gasket?
Last question is do i need to oring the block in order to use the cometic gaskets? Thanks in advance I apreciate any and all help. Thanks
Boost The Opposite of Asthma !!!
ra22turbo is offline   Reply With Quote
Old 11-10-2012, 10:42 PM   #2
jdzumwalt
Member
Default Re: 2rz copper or mls head gasket
do not stack gaskets cometic will custom make you one thicker.
jdzumwalt is offline   Reply With Quote
Old 11-19-2012, 11:20 AM   #3
ra22turbo
Member
ra22turbo's Avatar
Tacoma: 97
Thanks for the heads up . I appreciate that..
2RZ Cometic Head Gasket & ARP Head Studs ToRriD Parts and Accessories 6 09-19-2012 04:54 PM
4$ - ARP head bolts & Metal Head Gasket - 2rz (1997) Turbo357 Parts and Accessories 8 03-11-2011 08:56 PM
2rz/3rz head gasket Slick Nick Performance 8 06-18-2010 06:07 PM
WTB: 550cc Injectors, Head Studs, Head Gasket and Fuel pump dually Wanted 2 02-03-2009 03:10 PM
HEAD GASKET??? TACO626 Performance 20 05-27-2003 10:37 PM
