Turbo 3rzfe injectors and ecu? - CustomTacos.com Forum
Old 09-16-2012, 04:45 PM   #1
Jh42089
Newbie
Tacoma: 02 3rzfe turbo
Default Turbo 3rzfe injectors and ecu?
I recently turbocharged my 3rz and rebuilt the whole motor bored .030 over w/ lc street pistons headgasket and arp studs. brand new head. Right now im running 8psi but would like 12.
I deleted the cat and have the spark plug non fouler trick done. Now my o2 is reading .02v and i think is the reason for a random re ocuring Lean code.
Obviously i need to upgrade my fuel system
Megasquirt looks like the way to go but which one? I dont see a megasquirt for a 02 taco.
what about injectors? Seems like 550s would work. Were could i find some that would work?
Jh42089 is offline   Reply With Quote
Old 09-16-2012, 05:57 PM   #2
Josh Taco
Josh Taco's Avatar
Tacoma: 1999 toyota tacoma
Default Re: Turbo 3rzfe injectors and ecu?
As of right now there is no "plug and play" option for the tacoma for megasquirt. What I had done was order a URD patch harness for my year and then had someone with wiring experience wire it up to the Megasquirt 3 that I bought.
550 injectors seem to be what people choose for 15ish psi. I found some remanufactured and flow tested ones on ebay for the 2rz/3rz.
Old 09-17-2012, 07:47 AM   #3
blackedout_taco_stidham
Grand Tacoholic
blackedout_taco_stidham's Avatar
Tacoma: 2000 Reg Cab 5-Speed Turbo
you are not getting a lean code from your REAR O2 sensor...that is for catalyst efficiency only, nothing to do with fuel trims.
have you upgraded your fuel pump yet?
and if you wanna go above 8 psi you are gunna HAVE TO HAVE injectors larger than stock(im not sure of the stock size for the 3rz...what color are yours?)
QA1's and BJ Flip up front, Drop leafs and beefed blocks out back, Celica Seats, decent sound system w/some 10's. Boost Brigade Since APR 2012, Member of the NO BOV Club!...CH-CH-Ch-Ch-ch-ch
blackedout_taco_stidham is offline   Reply With Quote
Old 09-17-2012, 08:07 AM   #4
tacomatic1
tacomatic1's Avatar
he prolly has browns
Old 09-17-2012, 04:04 PM   #5
Jh42089
Newbie
The injectors look orange/pinkish. I have a walbro in tank pump that havent put in because i was under the impression that the stock pump could put out more than the stock injectors could.
Soo the megasquirt 3 is the way to go?
Old 09-17-2012, 05:21 PM   #6
Grand Tacoholic
yeah i think my stock pump is starting to give out, anything over 6 psi and my sh!t gets lean...new fuel pump is the next upgrade, and i also got some injectors out of 7MGTE supra for 85 bucks...440cc i believe.
Old 12-13-2012, 10:49 AM   #7
HaVoCX
Enthusiast
HaVoCX's Avatar
Tacoma: 1996 3RZ 4x4
Exclamation Re: Turbo 3rzfe injectors and ecu?
So after reading this thread.. Whats your guys opinion on my setup. My mechanic says that im only good for 3-4psi right now with 440cc injectors..
My setup---I have my 440cc injectors installed with my walbro 255 and aeromotive FPR. MAP-ECU3 etc. ( not bottom end work yet -- Stage 2 soon to come)
He says the 440cc Injectors (mitsubishi) i have are only good for 3-4 psi??? pshhhh whatttt? i wanna be able to hit 7psi at least. I had 550cc injectors (rx7) but the spray pattern wasnt optimum he said...
Your opinions?
My ulitmate goal is to be at 12-15psi after stage 2 but right now i want to be at the ~7psi range. What injectors would you recommend to run at 12-15psi? Can i buy bigger injectors now and just run them at a lower duty cycle % ??
Any advice is appreciated guys.
HaVoCX is offline   Reply With Quote
Old 12-13-2012, 11:00 AM   #8
tacomatic1
tacomatic1's Avatar
he's wrong.
I ran 8 psi on blue tops (265cc-ish) and was still 11.5:1 at max boost.
You can calculate easily how much fuel flow you will need for a specific horsepower...440cc/min for 4 cylinders should get you up to about 250 or so
I am running 600cc injectors and i push around 65% duty cycle at 14.8 psi. Yes you can run larger injectors, standalones will adjust the pulsewith at 100% ve based on the max flow rating.
Old 12-13-2012, 11:27 AM   #9
HaVoCX
Enthusiast
HaVoCX's Avatar
Actually.. on second thought..He may be right if you wanna supply fuel to your setup correctly.. I think the 440cc will work fine for most, but I am a optimum type of guy so i decided to look into his reasoning..
Check out this calculator. I think this may just put the final nail in the coffin to the debate lol..
injector size calculator--
http://witchhunter.com/injectorcalc1.php4
According to this calculator, the 440cc injectors would be good up to 215HP at 80% duty cycle @ a BSFC of 0.625 (BSFC is .625 for turbo)
So for my goal of around ~350 Hp would be 717.8 cc sized injectors or bigger.(running at 80% duty and 0.625 BSFC)
Damn.. looks like im calling luis for the $99 fuel rail and just go from there. Just remembered the 3rz stock fuel rail is only good for 550cc?? correct me if im wrong... lol damn it. MORE MONEY MORE PROBLEMS!!
Old 12-13-2012, 02:05 PM   #10
mitzu
Grand Tacoholic
mitzu's Avatar
Tacoma: 03 S Runnerrrr
pm 671Taco-he has a friend that did his megasquirt and I think he offered it as a package deal before.
Stop being sexist.
Bitches hate that!
mitzu is offline   Reply With Quote
turbo injectors tkeller Performance 3 02-17-2010 09:44 PM
Need 440 injectors for turbo system Speed Freek Performance 26 03-16-2008 08:32 PM
turbo injectors toyotaracer9 Performance 2 11-30-2004 05:49 PM
turbo/injectors. teamrj83 Performance 21 01-25-2004 02:03 PM
