4.56 & 4.88 Nitro Gear Ring & Pinions for ALL Toyota Tacoma Models - CustomTacos.com Forum
Go Back   CustomTacos.com Forum > Supporting Vendors > JTS Parts & Accessories
Old 04-25-2012, 11:42 AM   #1
justdifferentials
Supporting Vendor
justdifferentials's Avatar
Default 4.56 & 4.88 Nitro Gear Ring & Pinions for ALL Toyota Tacoma Models
4.56 & 4.88 Front Clamshell 8”
RING & PINION FOR TOYOTA FJ CRUISER, TACOMA, & 4RUNNER!
NITRO Gear & Axle has released the industries 1st 4.56 thick, 4.88 thick & 4.88 std ratio ring & pinions for the new Toyota 8” clamshell style IFS diff found in the front of 07+ FJ Cruiser, 05+ Tacoma, and 03+ 4runners. NITRO Gears are the first available to make it possible to restore power and economy lost by larger tires.
NITRO gears are manufactured using state-of-the-art CNC Machining processes, and the highest quality 8620 forgings. Special heat treating and lapping processes ensure long lasting, quiet running, and a smooth installation every time. JTS also carries master and minimum install kits, carriers, and lockers for this new front diff. As with all Nitro’s premium gear sets, these feature a 2 year warranty.
JTS stocks a wide variety of Ring & Pinions, Axle shafts, Bearing kits, Lockers, LSD’s, carriers, spider gears, spools and more for nearly all light trucks, 4wd’s and rear wheel drive passenger cars. JTS also builds custom 3rd members for nearly all Toyota 4wd’s from 79 to present, even Late model andinternational models including: Pickup, 4runner, Tacoma, Tundra (to 06), and 40, 55, 60, 70, 80 & 100 series Land Cruisers.
Fits: New design Toyota 8” clamshell IFS diff
Vehicles: 03+ 4runner, 05+ Tacoma, 07+ FJ Cruiser
Fitment Notes:
T8S-488R-NG 4.88 Fits 3.90+ carrier. Vehicles with 3.73 will require a new carrier, or ARBRD111
T8S-456RT-NG 4.56 THICK Fits 3.73+ carrier. Vehicles with 3.90+ will require a new carrier, or ARBRD121
T8S-488RT-NG 4.88 THICK Fits 3.73+ carrier. Vehicles with 3.90+ will require a new carrier, or ARBRD121
03-PRESENT 8” CLAMSHELL FRONT DIFF
07-present FJ Cruiser, 03-present 4runner, 05-present Tacoma Front:
T8S-456RT-NG FRONT R&P (THICK FITS 3.73 CASE, OR RD121)
T8S-488R-NG FRONT R&P (FITS 3.90 CASE OR RD111)
T8S-488RT-NG FRONT R&P (THICK FITS 3.73 CASE, OR RD121)
MK T8S-R MASTER KIT
IK T8S-R MINI KIT
SK CST8S-CLAM SOLID PRELOAD SPACER
ARBRD121 AIR LOCKER (FITS STOCK 3.73 OR W/ T8S-456RT-NG)
ARBRD111 AIR LOCKER (FITS STOCK 3.90+ OR W/ T8S-488R-NG)
8” REAR (taco w/ elocker)
-07-09 FJ Cruiser ALL, 03-09 4runner ALL, 05-Present Tacoma WITH E-locker.
TV6-456-29-NG R&P (NEW! 29 SPLINE BIG PINION, NO FLANGE REQ!)
TV6-488-29-NG (NEW! 29 SPLINE BIG PINION, NO FLANGE REQ!)
ARBRD132 AIR LOCKER
MK TV6-BMASTER KIT (NON LOCKER)
MK T8-ELOC-BMASTER KIT (W/ OEM LOCKER)
IK TV6-B MINI KIT (ALL)
SK CSTV6 SOLID PRELOAD SPACER
05-Present Tacoma 8.4” (NON LOCKER)
T100-456-NG R&P
T100-488-NG R&P
MK T100 MASTER KIT (ALL)
IK T100 MINI KIT (ALL)
SK CST100 SOLID PRELOAD SPACER
ARBRD129 AIR LOCKER
JT's Parts & Accessories
509-888-AXLE (2953)
www.justdifferentials.com
www.nitro-gear.com
Toyota Differential & Gearing specialist
justdifferentials is offline   Reply With Quote
Old 04-25-2012, 11:50 AM   #2
justdifferentials
Supporting Vendor
Default Re: 4.56 & 4.88 Nitro Gear Ring & Pinions for ALL Toyota Tacoma Models
Just got more in stock!
509-888-AXLE (2953)
www.nitro-gear.com
Old 11-12-2012, 11:40 AM   #3
justdifferentials
Supporting Vendor
We have lots of these in stock, let us know what parts you are looking for!
509-888-AXLE (2953)
www.nitro-gear.com
Old 11-12-2012, 12:11 PM   #4
tacomatic1
tacomatic1's Avatar
What about for 7.5" rear ends?
Old 11-13-2012, 06:08 PM   #5
Yodaforce
Grand Tacoholic
Yodaforce's Avatar
Tacoma: 2001 S-Runner boosted with alot of URD parts.
Or preTaco....
Diverse-Customs.com
Yodaforce is offline   Reply With Quote
Old 11-14-2012, 11:00 AM   #6
justdifferentials
Supporting Vendor
Here is the 7.5 inch stuff:
http://www.justdifferentials.com/ind...db0e43877d31ce
If you need a quote, shoot us an email to info@justdifferentials.com
509-888-AXLE (2953)
www.nitro-gear.com
Old 12-11-2012, 10:18 AM   #7
justdifferentials
Supporting Vendor
Bringing this back up, our websites are being rebuilt so if you can't find a part online give us a call or shoot an email to info@justdifferentials.com and we will send you all the info you need!
509-888-AXLE (2953)
www.nitro-gear.com
Old 12-11-2012, 11:40 AM   #8
HaVoCX
Enthusiast
HaVoCX's Avatar
Tacoma: 1996 3RZ 4x4
what gears would be beneficial to use on a *"Daily long distance Driver" 5spd Turbo'd 3RZ setup?
say with low compression pistons (8.5) and 12psi of boost...
& With +33" tires..
Very interested.
HaVoCX is offline   Reply With Quote
Old 12-11-2012, 12:11 PM   #9
tacomatic1
tacomatic1's Avatar
doesn't matter as much what the motor is, more of what you want to do with it
Old 12-11-2012, 02:39 PM   #10
HaVoCX
Enthusiast
HaVoCX's Avatar
Uhhh.. Thanks??
Ring gear torque? Yodaforce 1995.5 - 2004 2 05-21-2011 08:04 PM
Ring and pinions behemoth Performance 6 01-18-2010 12:05 PM
ring and pinions Rolling_Thunder 1995.5-2004 1 01-16-2009 10:18 AM
'05-06 ring gear breaking hytenor Off Road 14 03-29-2008 12:19 AM
where can i find a 3.73 or 3.9x ring gear? ochizon Performance 9 10-19-2007 07:08 PM
