Bags on the rear - CustomTacos.com Forum
Go Back   CustomTacos.com Forum > 2wd Discussion > 2wd Suspension
Old 02-08-2012, 09:16 PM   #1
Ironhead
Member
Ironhead's Avatar
Tacoma: 1999 ext cab Tacoma SR5
Default Bags on the rear
Ok guys I am not real familiar with bagging trucks but I want to know if bagging the rear of my truck would be hard? I use the truck to move my Motorcycles around as I fix buy and resell and I was thinking if I bagged rear I could drop the back for ease of loading as well and run up the pressure for the load in the bed any suggestions or comments are welcome thanks again
Ironhead is offline   Reply With Quote
Old 02-08-2012, 09:27 PM   #2
Josh Taco
Josh Taco's Avatar
Tacoma: 1999 toyota tacoma
Default Re: Bags on the rear
Ya its definitely been done. Air shocks may be a better bet for you. But either way would handle your motorcycle, bags would just be a bit more work. The shocks you could just swap out with the factory ones.
Old 02-09-2012, 03:13 PM   #3
Yodaforce
Grand Tacoholic
Yodaforce's Avatar
Tacoma: 2001 S-Runner boosted with alot of URD parts.
Usually, if you have to ask if it's hard, then it probably is, but then again, it really depends on which route you take to get it done.
I'll second the recommendation to just use air shocks to help with a load. If you were to bag the rear (like a link suspension), then you would have no "fall back plan" if you were carrying a load and had any kind of failure. Atleast with air shocks just bolted in place of the stock shocks, you could still get around with a sudden air leak.
Diverse-Customs.com
Yodaforce is offline   Reply With Quote
Old 02-09-2012, 03:23 PM   #4
toycoma98
toycoma98's Avatar
Tacoma: 1998 2-RZ Turbo @ 10 PSI. Original owner since 1997
There are Air Lift helper bags, bolt on.
toycoma98 is offline   Reply With Quote
Old 02-09-2012, 04:08 PM   #5
Yodaforce
Grand Tacoholic
Yodaforce's Avatar
Also a good option.
Diverse-Customs.com
Old 02-09-2012, 04:55 PM   #6
Chris D.
ADMlNAHATER
Chris D.'s Avatar
That don't fit worth a shlt unless you ditch your parking brake cables..
Air lift sucks..
Old 02-09-2012, 04:59 PM   #7
Ironhead
Member
Ironhead's Avatar
I have to equipment and the ability to install just about everything at the shop I work at but I have to keep in mind I have to drive it to and from. The Air shocks Idea is a good one I think and I might go that route I remember the air lines used to be a pain in the butt always broke on others guys trucks and stuff but I am sure it was because it was Mickey moused. Thanks for the replies and I think I have the answer I was seeking. Thanks again gang
Old 02-09-2012, 05:01 PM   #8
Chris D.
ADMlNAHATER
Chris D.'s Avatar
Monroe MA-727's
Old 02-10-2012, 08:49 AM   #9
Ironhead
Member
Ironhead's Avatar
Thanks for the part number Chris
Old 02-10-2012, 01:13 PM   #10
Ironhead
Member
Ironhead's Avatar
Now I need to post 2 new KYB Monomaxs rear for sale slightly used :P Live and Learn
Rear bags finally. deadmaggot6 1995.5-2004 14 05-16-2007 07:34 PM
Rear Helper Spring Air Bags? Dropitmore 1995.5-2004 2 02-16-2007 05:20 PM
Rear Air Bags or Air Springs? thwedge 1995.5-2004 1 11-12-2005 04:34 AM
What bags to use in the rear? fabtaco 1995.5-2004 22 05-17-2005 10:16 PM
Rear End for Bags??? Ballintaco35 1995.5-2004 6 12-15-2002 07:52 PM
