Re: Check your 2rz valve clearance.
Originally Posted by Speed Freek
You need to pull your valve cover and measure the lash (shim bucket to cam lobe clearance) to know if they are with in spec, better not wait till they get tight otherwise you WILL burn a valve
I have 24 left over shims and the pliers to remove them , i sell you the shims 5 bucks a pop and the pick and pliers for 50 $
OO SR5 Tacoma 3.4 5lug slopomatic , TRD S/C, TRD headers,TRD cat - exhaust, URD 2.1 pulley, URD FTC & AFR calibrator, 2jz injectors, 255 fuel pump, IK24 spark plugs, 170 thermostat, AEM guages, homemade methonal injection, homemade rear 02 sim, sprk adv. 20+
