Transmission Drain Plug - CustomTacos.com Forum
Go Back   CustomTacos.com Forum > The Garage > Maintenance > 2005+
Old 12-21-2011, 05:27 PM   #1
Mariner310
Member
Mariner310's Avatar
Tacoma: 2008,Toyota,Tacoma
Default Transmission Drain Plug
Hey folks, so I was under my truck yesterday and I noticed a ring of oil around the transmission drain plug. I go to tighten it and it just keeps turning. I'm thinking it's the gasket but I may be wrong. I don't know how this happened because my truck only has 30 K on it and I never took it to a mechanic. I'm just trying to get a couple opinions on this matter so I can see if I can fix it. Anything helps, thanks and Merry Christmas!
Mariner310 is offline   Reply With Quote
Old 12-21-2011, 05:46 PM   #2
pimpRunner
pimpRunner's Avatar
Tacoma: 05 XRUNNER
Default Re: Transmission Drain Plug
um, these are not servicable ("fill for life")
bolt may be stripped if it just keeps turning
I plead the 5th, unless copping to the crime is of my benefit...
pimpRunner is offline   Reply With Quote
Old 12-21-2011, 06:25 PM   #3
Yodaforce
Grand Tacoholic
Yodaforce's Avatar
Tacoma: 2001 S-Runner boosted with alot of URD parts.
Tighten it enough and eventually it will fall out in your hand (followed quickly by all of your oil. lol).
Sounds stripped to me. You can pick up a somewhat universal "expanda-plug" at most parts stores. Insert plug, tighten bolt head with wrench, and the rubber sleeve expands to tightly fill the hole. Still will work as normal when you change fluid.
If it is indeed stripped to the point that you keep turning it and it will not tighten at all, I see this as your only option considering the size of the plug.
Diverse-Customs.com
Yodaforce is offline   Reply With Quote
Old 12-21-2011, 08:14 PM   #4
ZIP
Veteran
ZIP's Avatar
Tacoma: '02 2JZ-GTE ; '98 2RZ Stock ECU 6500Redline
Should be covered under the factory 5 year 60k mile powertrain warranty. Don't touch it...Bring it to the dealer and make them fix it.
Stock ECU raised Redline 20+ psi on bone stock motor. NO upgrades to hg or studs
12.64@113.6 http://www.youtube.com/watch?v=RPuatjh_xEU
12.003@116.6 http://www.youtube.com/watch?v=E9zOIlQE-5o
ZIP is offline   Reply With Quote
Old 12-21-2011, 09:23 PM   #5
Yodaforce
Grand Tacoholic
Yodaforce's Avatar
I guess if you can prove that you (or anyone else) has ever touched the drain plug since it was new. Otherwise I'd be willing to bet they would chalk it up to "someone elses fault" and problem.
It's worth a shot. Their are a few good dealers out there.
Diverse-Customs.com
Old 12-22-2011, 10:13 AM   #6
pimpRunner
pimpRunner's Avatar
Tacoma: 05 XRUNNER
"fill for life" should never have been 'touched'
find a good service writer, and good luck
oil drain plug location Trevork22 1995.5 - 2004 46 04-19-2009 11:10 PM
Striped Transmission Drain Plug kaydar6 1995.5 - 2004 7 08-10-2008 04:47 AM
lsd drain plug... alfonso 2005+ 10 10-29-2006 01:39 PM
2005 Manual transmission drain & refill plug?? supertoyo 2005+ 1 03-16-2006 02:25 PM
Oil Drain Plug Gasket Pete S. 1995.5 - 2004 9 04-16-2004 10:13 PM
