2RZ-FE to 2JZ-GTE VVTi swap log - CustomTacos.com Forum
Old 10-24-2011, 09:45 AM   #1
BlueBlazeRacer
Veteran
BlueBlazeRacer's Avatar
Tacoma: 99 2wd std cab 2.4 5 speed, 06 SWB Xrunner
Default 2RZ-FE to 2JZ-GTE VVTi swap log
I decided that boosting my 2rz for the power levels that I wanted wasnt going to do it very easily, or have the power I wanted down low so a swap was looking like a good route. There are lots of threads on here asking how hard to do this swap is or if there is a kit. This thread is to answer those questions and as a log file for myself. The obvious answer is yes, there is some fabrication involved, but exactly how much is fabrication and how much is bolt-on? Now on to the log.
Truck:
1999 toyota tacoma
single cab 5-speed 2wd
2RZ with 133,000 miles
Motor:
2JZ-GTE VVTi
Pulled from Toyota Aristo 97-04(Japan)
Miles unknown
Buying the motor:
I knew that I wanted the turboed motor and the vvti and I wanted to see if I could retain a working OBDII interface for emmisions. Reading from other posts about the swap stated that I needed to get the front sump version of the motor which happens to come out of the Aristo in Japan or as we call it over here the GS300. I shopped for a while on ebay and import websites reading reviews and getting familiar with what parts I needed to make sure to have. I ended up buying my motor from jdmenginescorp of ebay as it lowered the shipping rates since they were a little closer to me. It was $2000 for the motor, trans, ECU, etc, and $250 for shipping to residential. The only thing that I needed to watch out for with the GTE VVTi motor was that it is MAF and MAP based and a lot of the swaps dont have the MAF sensor needed to run the engine properly on the stock ECU. Included in my swap was the motor, turbos, 4speed auto trans, ECU in stock ECU box, Ignitor chip, MAF sensor, alternator, power steering pump, AC compressor. The only thing that was not included in my swap was the power steering reservoir and I was aware of that from the pictures before buying the motor.
10\12\2011
Today the motor came in and unboxing it was like christmas. I began cutting back all the wrapping and inspecting the motor. Everything visually looked OK so I moved on. Not knowing how many miles were on the motor I changed the oil. I managed to get the pallet far enough off the floor to get a drip pan under it and drain the oil. When they placed the motor on the pallet the drain plug was positioned perfectly between two planks on the pallet, CAKE. Next I moved on to the compression test to make sure there were no huge issues with the motor. Everything testes 150 +/-4 PSI which is great. The PSI number isnt the important thing especially since it was a Harbor Freight gauge but the key was that all the cylinders were close to each other. I had to take a crash course on how to hit the starter with no wiring hooked up by that was solved by jumper cables to the starter and alligator clips to the solenoid. I also installed new spark plugs. NGK was the way to go.
I will continue this later today. Hope you guys like it.
Life at ....oops the speedometer doesnt go that high
BlueBlazeRacer is offline   Reply With Quote
Old 10-24-2011, 09:56 AM   #2
norcalduck510
Enthusiast
norcalduck510's Avatar
Tacoma: '03 SlammedSingleCab 2rz-fe
Default Re: 2RZ-FE to 2JZ-GTE VVTi swap log
Truck:
1999 toyota tacoma
Motor:
2JZ-GTE VVTi
Miles unknown
Buying the motor:
10\12\2011
Hella Jelly!
norcalduck510 is offline   Reply With Quote
Old 10-24-2011, 10:01 AM   #3
AFP520
[]D [] []D
AFP520's Avatar
Tacoma: GAWN
NICELY DONE!
'13 Plasma Blue Pearl WRX
AFP520 is offline   Reply With Quote
Old 10-24-2011, 11:55 AM   #4
Josh Taco
Josh Taco's Avatar
Tacoma: 1999 toyota tacoma
This will be my route after my 2rz blows up. Take detailed notes for all of our sake! It would be greatly appreciated.
"subscribed to thread"
Old 10-24-2011, 01:06 PM   #5
OGSpacePimp
Grand Tacoholic
OGSpacePimp's Avatar
Tacoma: '99 2wd Extra-cab SR5, 2.4L 5spd
nice, i'll be watching this one
O.G.SpacePimp
OGSpacePimp is offline   Reply With Quote
Old 10-24-2011, 08:15 PM   #6
brooksjm2
Member
brooksjm2's Avatar
Tacoma: 1996 Toyota Tacoma 2wd 2.4L
I will also be watching this thread because I already have my donor engine (2JZ-GE+T) but have not installed it yet. I am really looking forward to it and watching a build thread will motivate me to get on it! Thanks in advance for the motivation!
brooksjm2 is online now   Reply With Quote
Old 10-24-2011, 10:49 PM   #7
MatosTaco
MatosTaco's Avatar
Tacoma: 96 Toyota Tacoma
Sweet, good luck with the build! Please tell me you are going to get a proper manual transmission for this swap, automatic is lame.
QA1 First 100 club "Clone me out cah me nah poppy show"
MatosTaco is offline   Reply With Quote
Old 10-25-2011, 09:33 AM   #8
Speed Freek
Tacorvette enthusiast
Speed Freek's Avatar
I was going to take that route as well, but decided to go with the LS1 just since I havent seen another one, motor swaps are just KOOL.
I believe Turbo Dave on this site has parts for the conversion on his website...that may help you out a bit.
I love my swap, tons of torque off idle and has a linear power curve like a diesel! And I havent even squeezed any extra power from it yet...
BOOST BRIGADE I fabricate custom parts: HEIM STYLE STRUT RODS, FORWARD FACING INTAKE MANIFOLDS, and TRACTION BARS (5 LUG) contact me for more info @ www.Speed-freek.com or just PM me here THANKS!
Former Lexus / Toyota tech
Speed Freek is offline   Reply With Quote
Old 10-25-2011, 06:50 PM   #9
stoner
Veteran
stoner's Avatar
Tacoma: 2000 tacoma inline 6, 6 speed cabplus.
Hey congrats i have the same swap and i love it i made 384 hp stock i also have some parts if you thinkin of goin stick r154 or w58 r154 clutch kit tail shaft i also have ecu and airflow sencer got a few more parts if you intrested here is my number 201 779 4747i will give you a few pointersof what to espect kool
stoner is offline   Reply With Quote
Old 10-25-2011, 07:16 PM   #10
stoner
Veteran
stoner's Avatar
here.
Vvti NakedTacoma Performance 7 09-28-2009 02:42 PM
VVTi questions Taco_Kid Performance 16 03-04-2009 02:47 PM
Undoing gear swap for another gear swap Balboa X-Runner Talk 28 11-16-2008 09:11 PM
V tech controller for 2005+ VVTI Taco Engines? BadX Performance 16 04-11-2006 09:41 AM
Anyone made a turbo kit for the 05 2.7 with the vvti? Skipperdaddy Performance 9 01-05-2006 11:24 PM
