Do I Need a Replacement Wheel Bearing? - CustomTacos.com Forum
Old 04-04-2010, 06:08 PM   #1
apkarian100
apkarian100's Avatar
Tacoma: 2004 Toyota Tacoma 3RZ 4x4
Default Do I Need a Replacement Wheel Bearing?
So I have a 2004 Toyota Tacoma 4wd extra cab. I have, what sounds like, a metal to metal rubbing at the driver's side front wheel. I checked the brake pads, and they are fine. The noise is heard when I start moving and doesn't stop till i come to a complete stop. The noise does not go away if I put on the brakes or put the truck in neutral.
Do I need to replace a wheel bearing?
Let me know your thoughts.
Thank You
i cant drive now cuz some fashest pig pulled me ova n made me get my car towd back home cuz he didntt like the lites i have now cuz i spray paintd my lites with clear thru purple spray paint it was cool lookn but not very brite
apkarian100 is offline   Reply With Quote
Old 04-04-2010, 07:25 PM   #2
Enola Gaia
Enola Gaia's Avatar
Default Re: Do I Need a Replacement Wheel Bearing?
Wheel bearing would be my first guess ...
Old 04-04-2010, 07:32 PM   #3
apkarian100
Okay, so I am thinking straight. Next question, I went to my local Toyota dealer the other day to price out a wheel bearing. $86! Then they told me all these other seals and junk I should replace. For anyone that's just done a wheel bearing, can't I just get by on replacing just the wheel bearing and not the other seals, hub, etc, they tell me do? I'd rather not spend $430 in parts.
Old 04-05-2010, 12:46 PM   #4
Mase
Enthusiast
Mase's Avatar
Tacoma: 2000 3.4 4x4 AT, TRD Off Road
You'll need to replace the seals. It's nearly impossible to remove the old ones without bending the tin ring or ripping the rubber. They're pressed in there.
You might be able to get away with repacking it as long as it's not all scoured up or corroded. I was able to re-use the bearing pack on my front output shaft just fine even after a bit of chalky water got into it.
Where did the dealer come up with $430? I've bought seals, front and rear, from Toyota and they're between $8-$15.
OME 884 Coils, Bilstein HD shocks, OME 5 leafs w/HD shackles, Bilstein 5125, Rear Firestone Airbags, ProComp rockcrawler wheels, 32" Goodyear Wrangler MTR's Kevlar, Magnaflow cat-back, cold air intake, Hayden oil cooler, grey wire mod.
Mase is offline   Reply With Quote
Old 04-05-2010, 01:13 PM   #5
BIGJOKER
Addict
BIGJOKER's Avatar
Tacoma: 03 tacoma
it do sound like a wheel bearing,
Its pretty much routine to replace the seals when you replace the bearings, you could save some cash by taking out the spindle yourself and having a shop press in the bearings and seals then installing the whole assembly yourself..
BIGJOKER is offline   Reply With Quote
Old 04-05-2010, 04:53 PM   #6
tacoyota
Tacoma: 99 2.4 extra cab mini taco
you can buy bearings at a discount parts store for cheap. i got mine for $10 a side made in japan. Just make sure you use lots of lube.
Total Chaos Long Travel Front, Engage Offroad Long Travel Rear, Trutrac LSD, Big Ron front bumper, USMC2003 rear
tacoyota is offline   Reply With Quote
Old 04-06-2010, 03:41 PM   #7
cfranck
Member
Tacoma: 95.5 Toyota Tacoma
When you turn a little left or right while driving does the noise get louder and or softer??
Turning a little while driving you can almost narrow down the sound to which side it is!!
But to me it does sound like one!
cfranck is offline   Reply With Quote
Old 04-06-2010, 07:15 PM   #8
pmbazus
Enthusiast
pmbazus's Avatar
Tacoma: 2004 Tacoma 4WD Reg Cab 2.7
I once had a truck that made a noise whe it was moving. It turned out that the cover over the rotor was bent and was rubbing. I bent it back and the noise stopped.
pmbazus is offline   Reply With Quote
Old 04-06-2010, 07:16 PM   #9
Chris D.
ADMlNAHATER
Chris D.'s Avatar
does it sound louder in corners vs driving in a straight line?
If so, sounds like a wheel bearing..
Pop off the wheels and have a look..
Have you hit or drove over anything lately?
Maybe your dust shields are tweaked and rubbing the rotor..
Old 04-06-2010, 08:07 PM   #10
BIGJOKER
Addict
BIGJOKER's Avatar
Tacoma: 03 tacoma
You could jack it up by the lca's too get on your butt and shake the tires back and forth,
If there is even a little shimmy then most likely its a bearing,
Wheel Bearing Replacement Price siebler 1995.5 - 2004 9 04-08-2009 07:15 PM
Wheel Bearing Replacement hayntaco 1995.5 - 2004 0 03-22-2009 07:31 PM
05+ Wheel Bearing Replacement 05DoubleTaco 2005+ 5 09-22-2008 03:11 PM
wheel bearing replacement d33pt 1995.5 - 2004 5 11-29-2004 10:14 PM
Wheel Bearing Replacement Help ericfoster2003 1995.5 - 2004 4 11-17-2004 08:01 PM
