Neutral Safety Switch Diagram... - CustomTacos.com Forum
Old 02-13-2010, 04:29 PM   #1
ScooterTaco
Newbie
Tacoma: 2008, Toyota, Tacoma
Default Neutral Safety Switch Diagram...
Hi everyone, I'm wiring up some reverse lights and I need to know which wire coming out of the neutral safety switch is the reverse lights so I can use it as a switch to turn the new lights on. I searched but couldn't find a diagram or anyone explaining which color wire it is. Does anyone know?
Thanks in advance!
ScooterTaco is offline   Reply With Quote Quick reply to this message
Old 02-13-2010, 04:43 PM   #2
Enola Gaia
Enola Gaia's Avatar
Default Re: Neutral Safety Switch Diagram...
I'm not 100% certain of the precise color scheme, but I'm sure it's not the yellow wire.
As of 2007 it was a red wire with a white stripe (coming off the park / neutral position switch).
As of 2009 it was a solid red wire.
I don't have a 2008 diagram illustrating this particular circuit, so I'm not sure whether yours matches the 2007 or the 2009 color scheme.
Enola Gaia is offline   Reply With Quote Quick reply to this message
Old 02-13-2010, 05:33 PM   #3
ScooterTaco
Newbie
If I am looking at the right connector, the red wire has power regardless of shifter position so that's not it. This is the connector I believe to be coming out of the switch..is this correct?
Or is it this one? I think this one is going into the shifter
Old 02-13-2010, 06:39 PM   #4
Enola Gaia
Enola Gaia's Avatar
WTF am I looking at in the photos?
My guess is that they are overhead shots looking down into a disassembled center console ... Right?
If so - the answer is 'Neither', because you're looking in the wrong place.
The park / neutral position switch is located under the floor 'hump' on or beside the transmission itself - toward the auto transmission's front end (bell housing). The red (or red / white) wire coming off it leads to connector IH1, which is located up under the dash, to the right (passenger side) of the glove box.
Old 02-13-2010, 06:43 PM   #5
Enola Gaia
Enola Gaia's Avatar
To give an illustrative example of the park / neutral position switch's location ... Here (attached) is the parts location diagram for the A750F automatic tranny.
Old 02-13-2010, 06:47 PM   #6
ScooterTaco
Newbie
Haha my bad, I could have sworn I captioned them! Sorry about that but yes it is looking down at the disassembled center console.
I'll go look and report back which color it is, I should be able to find it now. Thanks a million Enola!
Old 02-13-2010, 07:01 PM   #7
Enola Gaia
Enola Gaia's Avatar
Wait, wait ....
I got so caught up in locating the park / neutral position switch I lost sight of the main issue - tapping into the hot line on the backup light circuit.
Here (attached) is the 2009 version of the diagram. It's identical to the 2007 version, except for the exact red color scheme on the wire in question.
After the line runs from the switch up to connector IH1 (under the dash, to the right of the glovebox) it runs over to pin #1 on connector ID2 - which is conveniently located in the left kick panel (somewhere).
I'm including the 2009 version of the wiring diagram because it includes an illustration of the connector(s).
Old 02-13-2010, 08:34 PM   #8
ScooterTaco
Newbie
The wire is red with a white stripe and the black IH1 connector is very easy to find if you take the glove box off. I didn't spend too much time looking for the ID2 connector because there were several gray connectors and no easy way to distinguish them. Thanks for all the help Edola!
Old 02-14-2010, 07:11 AM   #9
Enola Gaia
Enola Gaia's Avatar
Glad it turned out to be easy to access ....
Now be sure to post photos of these new lights when you've got everything installed ...
Old 02-14-2010, 03:49 PM   #10
ScooterTaco
Newbie
Here are some pics of the install of my PIAA backup lights...
This is where I mounted them. They are aimed slightly outwards and light up a great deal behind me. They are also very useful for getting people behind you to turn of their brights, stop tailgating you and to mess with your friends!
I believe I used the existing holes in my bumper (I did most of this install almost a year ago so I can't remember)...there was drilling involved somewhere in this step but it might have been on the mounting bracket. Sorry I can't remember!
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
HELP!! Park Neutral Switch OEM code P1780 XKnivesX 1995.5 - 2004 25 02-16-2010 08:58 AM
Toyota Calls IIHS Top Safety Pick Results "Extreme And Misleading" [Car Safety] CTadmin Industry News 0 11-18-2009 11:50 AM
Transfercase slipping into neutral Mr Chills 1995.5 - 2004 0 04-20-2009 03:36 AM
Tranny engages while in neutral ChrisTaco On Road 11 01-23-2008 08:11 PM
High Water Safety Switch? Mountain Taco Off Road 9 02-27-2007 07:11 AM
