Go Back   CustomTacos.com Forum > On The Go > Off Road
CustomTacos.com is the premier Toyota Tacoma forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Old 10-28-2009, 07:38 PM   #1
Beefed Taco
Taco Vending Machine
Beefed Taco's Avatar
Tacoma: 99 2.4 5-lug Reg.Cab 5/7 Drop
Default Lift Shackles 1st gen Taco & Tundra
These are 8" bolt to bolt and will provide 2" of lift. They fit 95.5-04 Tacoma and the Tundra. 2nd gen Taco's use a inverted shackle setup so these won't work. Comes with correct grade 8 hardware which will replace the stock 14mm stuff. 2 styles, tubed or flat. Non greasable. They're Beefy!
http://streetacos.com/
Toyota Tacoma Forum
Old 10-28-2009, 09:38 PM   #2
tacorunner87
Grand Tacoholic
tacorunner87's Avatar
Tacoma: 01 Prerunner Xtra Cab
Default Re: Lift Shackles 1st gen Taco & Tundra
9/16 or 5/8 bolts?
tacorunner87 is offline   Reply With Quote
Old 10-28-2009, 10:02 PM   #3
Beefed Taco
Originally Posted by tacorunner87 View Post
9/16 or 5/8 bolts?
9/16" replaces OEM 14mm and 5/8" fits aftermarket poly bushings. Pictured is 9/16". I can supply poly bushings if someone wanted them instead.
Old 10-28-2009, 10:03 PM   #4
JonAz
JonAz's Avatar
Tacoma: 00' Turbo'd 2rz
Sweet! What about some drop shackles???
Boost Brigade (7psi)
JonAz is online now   Reply With Quote
Old 10-28-2009, 10:16 PM   #5
Beefed Taco
No room since the frame is right above, they're 3.5" stock.
Old 10-28-2009, 11:42 PM   #6
JonAz
JonAz's Avatar
Ghey, ill just have to get your bolt on kit for coilovers and go coilovers all around
Old 11-01-2009, 11:17 AM   #7
marky mark
Member
marky mark's Avatar
Beef..Can ya change your first post to read clearer..Guys are confused on the Tundra forums that this is not for the 2nd Gen Tundra..I can see how they can read that from your post above. It is not clear on what year Tundra.
marky mark is offline   Reply With Quote
Old 11-01-2009, 01:10 PM   #8
Beefed Taco
The flat H style (not the tubed) was made for my friends 08 Tundra. I'm not sure about the earlier ones, I have to look. I'll get back to you. I do know the H style is a direct bolt on for the newer style Tundra provided they use the grade 8 hardware that comes with them..
Old 11-05-2009, 07:24 PM   #9
Beefed Taco
I'm making lift shackles for the first gen 2WD 5-lugs and 4x4/Prerunners, and Tundra's. They are 6" hole to hole and will provide a solid 2" rear lift. Two styles are available, the H style or the tube racing style. The upper bolt is grade 8 metric 18mm, lower is grade 8 metric 18mm for 5-lug and grade 8 9/16" for 4x4/Prerunner. I will have a updated picture tomorrow, these were 2" Tundra.
I figured out all the details and made a set today. I'll have a updated picture of them tomorrow. I bit the bullet and bought a bunch of grade 8 hardware and a freakin' expensive drill bit today in hopes of selling a pair of these now and then since I heard Fabtech & Downey are no longer making them.
H style $99.95
tube style $134.95
USPS priority shipping $14.80
PLEASE: A good, economical 3-5 inch lift for a 2wd taco snakezrx 4x4/PreRunner Suspension 20 04-16-2009 05:51 PM
96 taco w/ plow and 33's Lift opinions reckedracing 1995.5-2004 1 10-13-2008 02:38 PM
Ready lift 5 lug lift kit suggestions. 08 access 4 cyl taco DIRTY42M 2005+ 2 07-05-2008 05:24 PM
lift for a tundra groundedtaco 4x4/PreRunner Suspension 3 03-27-2006 03:26 PM
10" lift for taco...... H8RSTYLE Off Road 6 10-26-2002 01:29 PM
Powered by vBulletin® Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
