Go Back   CustomTacos.com Forum > 2wd Discussion > S-Runner Talk
CustomTacos.com is the premier Toyota Tacoma forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Old 10-20-2009, 03:24 PM   #1
beatzapizza
Enthusiast
beatzapizza's Avatar
Tacoma: 2001 BSP S-Runner
Question Sagging or Lower Rear Passenger Side
Basically, I'm refering to the passenger side rear bed corner or bed side. I remember reading one post from a CT member with an '01 SR who described a very similar problem as the one I'm having. At this point I'm thinking the suspects are the leaf springs but I wanted to see if someone has a proven solution.
Thanks!
beatzapizza is offline   Reply With Quote
Toyota Tacoma Forum
Old 10-20-2009, 04:48 PM   #2
redrunner
slow poke
redrunner's Avatar
Tacoma: '01 S-Runner
Default Re: Sagging or Lower Rear Passenger Side
Thanks!
Mine leans to the passenger side towards the back, too.
May not be related, but one of my wheels (can't remember, I'll check later) is about 1cm "outward" from the other. not enough to notice unless you're looking for it.
redrunner is offline   Reply With Quote
Old 10-20-2009, 07:08 PM   #3
Enola Gaia
Enola Gaia's Avatar
Any suspension mods? If so - what are they?
Are the shocks original?
Old 10-21-2009, 02:33 AM   #4
beatzapizza
Enthusiast
Zero suspension mods as of now but will be changing in the next month or two. In contact with Beefed Taco about getting some of his 3" lowering blocks which is why I would like to diagnose the problem and see if I need different size blocks. Same Tokico blues with no real issues for now. I wonder if any of the 01-04 4cyl. X-cab 2WD 5-lug guys are having a similar problem.
Old 10-21-2009, 02:44 AM   #5
beatzapizza
Enthusiast
Sounds like the thrust line is off centered. Did you notice anything unusual when you looked at the leaf springs or hardware?
Old 10-21-2009, 04:26 AM   #6
Chris D.
Self Medicated
Chris D.'s Avatar
Tacoma: 02 Mini xtra cab
time to swap the leafs from one side to the other..
either that or have beefed make some custom blocks to ward off the lean..
get some measurments, how far off are we talking?
have you ever loaded your bed to the point you were on your bump stops?
Old 10-21-2009, 05:54 AM   #7
redrunner
slow poke
redrunner's Avatar
Tried to PM you but you have pm's disabled (didn't want to thread jack).
Anyway, in my truck the rear is on 4" blocks and carrier bearing flipped. Nothing seems unusual but I wouldn't know what to look for
Old 10-22-2009, 01:34 AM   #8
beatzapizza
Enthusiast
That's what I was thinking. It's gotta be the leafs right? The only reason I can think of is the amount torque applied with an open diff. Thus, the passenger side of leafs would fatigue quicker.
Magical Beefed blocks in the works as we speak.
Yes, the truck was used to haul trunks full of lighting gear so I do have marks on the bump stops.
Old 10-22-2009, 01:54 AM   #9
beatzapizza
Enthusiast
No worries about the thread jack and sorry about the PM settings.
I'm not an expert on thrust line but basically a rear axle aligned perfectly with the drive shaft would form a "T". So your axle would be the top part of the T and drive shaft would be the middle line. If your tires are wearing good and you're not hearing any unusual noises you should be good. Did you have any differential work done to the truck?
Old 10-22-2009, 05:53 AM   #10
redrunner
slow poke
redrunner's Avatar
LSD was put in about 6months after I bought it. I never payed enough attention before that to notice them being off This was over 7 years ago and everything is wearing normally
wtb passenger rear fender flare for 98- ToyotaTechGeek Wanted 2 12-06-2009 06:16 PM
Looking for passenger side rear fender Stilltacomatosed Wanted 0 08-07-2009 02:08 PM
Rear suspension sag (driver side) 2006_TOY_TACO 2005+ 8 06-24-2009 09:10 PM
Bad rear left side skirt kaoxvaj09 X-Runner Talk 7 04-13-2009 12:14 PM
rear driver side is lower than passenger side? itsnotacoma 1995.5-2004 10 02-22-2002 07:40 AM
Powered by vBulletin® Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
