CustomTacos.com is the premier Toyota Tacoma forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Old 09-09-2009, 02:42 PM   #1
mtucker
Veteran
mtucker's Avatar
Tacoma: 2003, Prerunner double cab
Default Map light LED install
I replaced my incandescent map lights with LEDs. I went with the 3022-CWHP2 bulbs http://www.superbrightleds.com/specs..._3022-xHP2.htm from superbrightleds.com I like the bright white light much better than the orangish stock bulbs. Don’t let the two LEDs per bulb fool you. They come close in light output to the 16 LEDs that are in my Oznium dome light. The pictures were taken with the flash on, but show the big difference between stock and the "cool white" LEDs.
Cover off. Left = stock Right = LED
Covers on. Left = stock Right = LED
Matt
mtucker is offline   Reply With Quote
Toyota Tacoma Forum
Old 09-09-2009, 03:17 PM   #2
Enola Gaia
Enola Gaia's Avatar
Default Re: Map light LED install
Was it pretty much a 'plug and play' installation? Any additional tweaks or adjustments necessary?
Old 09-09-2009, 03:26 PM   #3
mannyfresh619
Grand Tacoholic
mannyfresh619's Avatar
Tacoma: 99 toy tacoma
POH-KAY
mannyfresh619 is offline   Reply With Quote
Old 09-09-2009, 03:32 PM   #4
YankeeTaco72
YankeeTaco72's Avatar
Tacoma: 1997 Toyota Tacoma 2wd
Yes was it a simple plug and play? Thats exactly the bulbs Im looking for. PM please with the info I need to order mine.
YankeeTaco72 is offline   Reply With Quote
Old 09-09-2009, 04:40 PM   #5
Stock Taco
Babylon is Falling
Stock Taco's Avatar
Tacoma: '03 Reg Cab 2wd Mildly Mod'd 2RZ-FE
Lookin' good Matt. Thanks for sharing.
"I'd rather be a free man in my grave, than living as a puppet or a slave" The Harder They Come by Jimmy Cliff
http://www.youtube.com/user/StokedTaco
Stock Taco is offline   Reply With Quote
Old 09-09-2009, 05:16 PM   #6
mtucker
Veteran
mtucker's Avatar
It was totally plug and play with no modifications needed. Before I ordered, I measured the length of the stock bulbs with calipers..... 30.5mm. The 30 in 3022-CWHP2 is the length in millimeters. The bulbs in that series with more than two LEDs were longer so I had to stick to the two LED bulbs. They put off plenty of light.
One thing nice about that specific LED bulb is it works no matter which way you put it in (you don't have to worry about polarity). I saw at least four diodes on the board so they must have used a bridge rectifier input to do that. That is a nice touch that makes it totally plug and play. They are $6.95 each.
Matt
Old 09-09-2009, 05:32 PM   #7
Enola Gaia
Enola Gaia's Avatar
Thanks for the additional info!
Old 09-17-2009, 08:31 PM   #8
Chris D.
Self Medicated
Chris D.'s Avatar
Tacoma: 02 Mini xtra cab
I know your reading this Chris, you nuked your old post a little too quick.. LOL
use the * symbol when searching for a 3 letter word,
its a filler so it meests the 4 charactor minimum..
*led
led*
ect..
Old 09-17-2009, 08:41 PM   #9
voodootrip
4-Linked Mod
voodootrip's Avatar
Tacoma: 2001 BSP S-Runner... yummy
Too quick What was the stock number on the bulb?
*led
led*
ect..
yes it's a truck... yes it's fast
"Click here" for My Build http://streetacos.com
voodootrip is offline   Reply With Quote
Old 09-28-2009, 03:29 AM   #10
Stock Taco
Babylon is Falling
Stock Taco's Avatar
Thanks again Matt.
My tach's wide-angle LEDs (five per bulb) were way too bright and also caused hot spots. So I replaced them with with single LED bulbs and problem solved. While I was at it I also got the same map light ones and they are nice!
LED taillights and 3rd brake light truck_n_ninja Parts and Accessories 28 07-01-2009 07:55 PM
help me find this part # (led for fog light button) joman Interior/Audio/Electronics 1 05-28-2009 06:59 AM
led 3rd brake light for 05-07 alaxrunner Lights / Exterior Electricals 16 03-13-2007 07:31 PM
Consumer Reports BRB GTG PP Off Topic 49 11-02-2006 11:47 AM
Turn Signal Mod Bazzy Exterior/Body 19 09-20-2004 11:06 PM
Powered by vBulletin® Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
