blitzluft 1/2 air valves - CustomTacos.com Forum
Old 02-26-2009, 12:23 AM   #1
LAYLOWR
Newbie
LAYLOWR's Avatar
Tacoma: 1998 TOYOTA TACOMA
Default blitzluft 1/2 air valves
Does anybody have any pictures of how to properly setup the dump and fill valves on the airbags? I have blitzluft 1/2 inch valves. also a description on how to wire them, thankz. Can the valves be remotely installed away from the bags?
LAYLOWR is offline   Reply With Quote
Old 02-26-2009, 06:16 AM   #2
draggntaco85
Enthusiast
draggntaco85's Avatar
Tacoma: '97 Tacoma Std. Cab
Default Re: blitzluft 1/2 air valves
http://www.suicidedoors.com/files/ho...ams/8valve.gif
That's a quick diagram for an 8 valve set up. Yes, you can mount your valves anywhere you want, they do not have to be near the bags.
draggntaco85 is offline   Reply With Quote
Old 02-26-2009, 06:19 AM   #3
draggntaco85
Enthusiast
Just noticed they don't have the wiring in there but basically your relay will have a positive, a ground and a lead wire to your switchbox. suicidedoors.com has the schematic for wiring the relays for the compressor, and the valves are similar. Go to the website and click the how-to link.
Old 02-26-2009, 10:34 AM   #4
nancy
Grand Tacoholic
nancy's Avatar
they don't but the closer the valve is to the bag, the quicker it'll dump/fill
nancy is offline   Reply With Quote
Old 02-26-2009, 10:39 AM   #5
nancy
Grand Tacoholic
nancy's Avatar
here's a diagram for a 10 switch box
http://www.layitlow.com/tech/switches_10.shtml
Old 02-26-2009, 11:33 AM   #6
OGSpacePimp
Grand Tacoholic
OGSpacePimp's Avatar
Tacoma: '99 2wd Extra-cab SR5, 2.4L 5spd
super simple, just run the hot wire from the switch, ground the valve to whatever you mount it to
i run all my valves ported right into the tank, which is in the bed, keep things together and easy to access for maintenance
O.G.SpacePimp
OGSpacePimp is offline   Reply With Quote
Old 02-26-2009, 11:56 AM   #7
draggntaco85
Enthusiast
true but if they are further away, your ride is a bit 'softer'. Either way, air moves fast enough...
Old 02-26-2009, 12:28 PM   #8
nancy
Grand Tacoholic
nancy's Avatar
tru dat
GC Duece Valves lobody94 Parts and Accessories 1 12-09-2005 06:34 AM
3/8 bags and valves or 1/2 bags and valves how much of a difference is 84lota 1995.5-2004 9 12-07-2003 12:24 AM
opinion on blitzluft 1/2" valves 84lota 1995.5-2004 26 12-03-2003 08:27 PM
valves question riding_low85 1995.5-2004 7 09-24-2003 06:09 PM
Air Valves lowandloud 2wd Suspension 3 02-14-2002 07:44 PM
