Outer Tie Rod flip on lowered trucks. - CustomTacos.com Forum
Old 02-22-2009, 10:56 PM   #1
ToyComa
Tacoma: 1st autox/drift Tacoma in New Jersey
Default Outer Tie Rod flip on lowered trucks.
It is easy and works good.
I clearanced the hole in the spindles with a rat tale file. The hole and tie rod measure about .040" diffrence from the skinny to fat end. I suggest clearencing just enough that you can put the tie rod into the spindle by hand so that the cotter pin hole in the tie rod is just out of the spindle. Then use the nut to pull the tie rod the rest of the way up and into the spindle hole.
YOU WILL NEED AN ALIGNMENT!!!!!
I lowered my truck about 3/4 -1 more this past weekend after installing my QA-1 coil overs on the front. I had a massive amount of toe in. Your amount will very depending on how low you are. Having to adjust the toe alignment is very helpful though since now you can put more of the inner tie rod back into the outer tie rod end. This means your truck is much safer to drive. I never had a tie rod failure but I would never had been suprised if or when it broke if it did break.
ToyComa is offline   Reply With Quote
Old 02-23-2009, 07:53 AM   #2
OGSpacePimp
Grand Tacoholic
OGSpacePimp's Avatar
Tacoma: '99 2wd Extra-cab SR5, 2.4L 5spd
Default Re: Outer Tie Rod flip on lowered trucks.
sounds worth trying...got any pics? i need to replace my b/j's soon anyway so might as well try it on these...if I don't like it I can put it back when I change out my lower b/j and if it works well, i can do the new brackets while they are off the truck
O.G.SpacePimp
OGSpacePimp is offline   Reply With Quote
Old 02-23-2009, 08:18 AM   #3
ToyComa
no pics. it's simple to do. just file it until you can get the cotter pin back into it with the nut on. I need to replace my outer tie rod end on the drive side now because I tore the rubber on it trying to get it out/off. I replace both side though because I just like things to be even.
Old 04-03-2009, 11:13 AM   #4
Slo-mo
Slo-mo's Avatar
Tacoma: Sick BMX Bike
did you notice an increase in steering angle with this? im going to do this soon anyway but more angle would be nice
I has a WRX
Slo-mo is offline   Reply With Quote
Old 04-03-2009, 05:32 PM   #5
ToyComa
no i did not.
Old 04-13-2009, 08:16 AM   #6
raygenjay
Member
Tacoma: 96 toyota tacoma
hey whats up?does this work on bagged trucks that very in ride hieght at times?just asking?my bumpsteer is crazy.
96 tacoma turbo 2rz
fmic,apexi safc
92 supra independent rear suspension bagged
raygenjay is offline   Reply With Quote
Old 04-14-2009, 07:20 PM   #7
bagdxblz
Member
bagdxblz's Avatar
Tacoma: 97 toyota tacoma
yea i was accually going to do this to mine my truck is bagged and bodydropped on 20's so it toes in when its layed out and that hole for the tierods is tapperd so i wasnt sure if it would work because by the time you got it big enough so it would go in from the bottom it would jus be a straight hole. so im jus wondering if the steering is sloppy by the time you get done making the hole bigger
bagdxblz is offline   Reply With Quote
Old 04-16-2009, 02:17 PM   #8
ToyComa
the steering is not sloppy after it is done. As I said above. I filed it enough to get the tie rods in. They do not just slide in by hand. You have to put them in then crank them up into the hole by tightening down the nut.
Old 04-16-2009, 09:49 PM   #9
KANE
Veteran
KANE's Avatar
Tacoma: 98, 04 Toyota Tacoma
I've also heard of people using a welder to weld beads around the ball joint shaft to make it fit snug to a larger taper and polish them to a smooth taper. I tried it once and it worked out great, and once its tightened down its not going anywhere.
KANE is offline   Reply With Quote
Old 04-24-2009, 06:57 PM   #10
N2BNLO
N2BNLO's Avatar
Tacoma: 97' Bagged reg cab 2rz
ok, I did this with my first attempt at setting up the front to lay on 20s and thought it would help with the TOE issue and in-fact doing this makes the TOE worse. Doing this on a dropped taco with 19"+ wheels increases the bump steer geometry dramatically...at least thats what happened to my truck.
I sent my balljoints to Max at BioKustomz. He lowered and re-angled them(the mounting point for the sterring rod)and every thing works great....very minimal TOE. I also have the handmade drop spindles he sells...and worth every penny in my opinion...take care guys
N2BNLO is offline   Reply With Quote
First Batch Of Toyota Tundra Pickup Trucks Exported To Latin America CTadmin Industry News 10 12-28-2008 08:36 PM
work trucks tacogrande Off Topic 19 11-16-2008 05:29 PM
B/J Flip Done...but is this noise normal??? Srunnerman 1995.5-2004 6 06-02-2004 01:43 PM
Why you don't need "lowered shocks"... maybe??? BlitzKrieg 1995.5-2004 23 05-05-2003 08:04 PM
Some Local Trucks INACOMA Off Topic 23 06-16-2002 11:11 PM
