Dash and tail lights not working - CustomTacos.com Forum
Old 12-16-2008, 07:56 PM   #1
kyleml13
Newbie
Tacoma: 2001 Toyota Tacoma SR5
Default Dash and tail lights not working
I just posted this thread, but in the wrong area, thought I would try again. When I go to switch on my running lights, the dash and tail lights do not turn on. I have checked all of the fuses and adjusted the dimmer, and the brake lights, dome light and headlights work as well.
I am thinking it is the relay, but not exactly sure where it is at. I have a 2001 tacoma, with no mods.
Any help is appreciated, and any ideas of what else might be causing this issue?
Thanks,
Kyle
kyleml13 is offline   Reply With Quote Quick reply to this message
Old 12-16-2008, 10:01 PM   #2
Stock Taco
Babylon is Falling
Stock Taco's Avatar
Tacoma: '03 Reg Cab 2wd Mildly Mod'd 2RZ-FE
Default Re: Dash and tail lights not working
Double check the 10A taillight fuse... it's probably blown. Your dash lights are powered by the taillight circuit. It's located at the "Relay Block" under your hood right behind the battery. Look at the diagram on the plastic cover that you'll need to lift up, it's show you which one is for the tailligfht.
Keep in mind fuses usually don't pop unless there's a reason, normally caused by a short somewhere. Replace it with another 10A fuse, keep fingers crossed, pray to Taco Gods and see what happens. If it pops again you've got a short for sure.
This happened to me one time in my '03 4x4 when I towed my buddy's freshly painted '62 Bug back from a Tijuana body shop. The trailer had a shorted taillight socket, which caused the taillight fuse to blow when I turned on the headlights and therefore no tail or dash lights. Like you mentioned, the turn signals, brake & headlights will still work.
LCE FW/Clutch/Pulley/Header; Magnaflow Cat/14" Muffler; FAL e-fan; aFe CAI; NGK Iridiums; AMSOIL; StreeTacos 2" Blocks, Eibachs; KYBs; ADDCO Rear Bar; EATON Detroit TrueTrac LSD; '04 Taco Buckets
Stock Taco is offline   Reply With Quote Quick reply to this message
Old 12-17-2008, 10:48 AM   #3
kyleml13
Newbie
I checked all of the fuses again, and switched out a few, and they still are not working.
Old 12-17-2008, 11:33 AM   #4
Stock Taco
Babylon is Falling
Stock Taco's Avatar
Not sure why you're checking ALL the fuses... Only necessary to check the tailling one. Use a test light and probe the fuse's two metal "tab" opeinings. Will prove wheather or not the circuit has power. You could have a bad switch.
Old 12-17-2008, 11:26 PM   #5
Enola Gaia
Enola Gaia's Avatar
There is a tail relay, and a malfunction with it would explain this behavior (assuming you've convinced yourself it's not the 10A Tail fuse ...).
Here (attached) is the 2001 taillight / illumination wiring diagram ...
Enola Gaia is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Tail and lights do not work kyleml13 Introduce Yourself 3 12-17-2008 10:14 PM
tail lights! alex serrato Lights / Exterior Electricals 27 10-05-2008 12:48 PM
DJM Control Arms, 01+ Tail Lenses, Dash Clock, DJM 4" Blocks Taco Supreme Parts and Accessories 19 10-08-2007 12:38 AM
Tail light problem. Please help gurus! george.arnold Interior/Audio/Electronics 5 01-26-2007 09:21 AM
Help - dash lights don't work cheez Interior/Audio/Electronics 6 01-26-2006 08:36 PM
