Performance Chip!!! - CustomTacos.com Forum
Old 05-19-2008, 11:04 PM   #1
813scrappy876
Newbie
Tacoma: 2001, Toyota, Tacoma 2.4 Regular Cab
Default Performance Chip!!!
What Performance Chips you guys recommend? Do you recommend any from ebay? Brands like White Lighting Performance Module, The Juice Box, Fuel Maxx, Chronic Power Chip, Pro Maxx Performance, Precision Engineered. Any Advice, I want to get a little more power, for cheap
813scrappy876 is offline   Reply With Quote
Old 05-19-2008, 11:10 PM   #2
rednecktaco
I see what you did there
rednecktaco's Avatar
Tacoma: 11'grand cherokee, 12 mazda 3i touring HB
Default Re: Performance Chip!!!
dont work with our trucks....look up urd
rednecktaco is offline   Reply With Quote
Old 05-19-2008, 11:10 PM   #3
humanoid
This Space For Rent
humanoid's Avatar
Tacoma: '99 PreRunner Xtra Cab 3.4L V6
Power and cheap are mutually exclusive, you can have one or the other, not both. Those eBay chips are a ripoff, don't get one.
humanoid is offline   Reply With Quote
Old 05-19-2008, 11:13 PM   #4
taco on steiroids
taco on steiroids's Avatar
Tacoma: 01 mini turbo & 82 corolla
sorry to be so brunt about this, especially if you havent quite learned to search around a bit here cause ur new
but the cheapest way of getting some power would be to park in your driveway and buy a poster of what it would look like driving fast and stick it in your window. Anything that's like a chip or something that claims to help you is total b/s...
there are some easy things you can do to notice either increased MPG or HP or both that arent bank breaking, so look around a bit, search, and you'll come up with some stuff!
Any of the basic naturally aspirated engine mods that allows for free'er air flow to start
BOOST BRIGADE
d'you think i should lose the vest?....Burn it.. what?
burn it, cause if you lose it, you might find it again...
taco on steiroids is offline   Reply With Quote
Old 05-20-2008, 07:13 AM   #5
zr2ee
Enthusiast
Tacoma: 2006 4.0L Tacoma Double Cab Long Bed
the only two available are the URD and Unichip, i personally have a unichip and its treated me well, no complaints except i dont have a tuner in my area, they might still be having their garage sale, check out their site, they have dyno's and lots of info http://www.unichip.us/index.asp#GarageSale
zr2ee is offline   Reply With Quote
Old 05-20-2008, 08:13 AM   #6
adaml01
Member
adaml01's Avatar
Tacoma: 2001 taco prerunner V6
what kind of power or milage gains have you seen? i would like to know/hear from someone who has one before i drop several hundered dollars
adaml01 is offline   Reply With Quote
Old 05-20-2008, 09:29 PM   #7
jlirish
Guest
Posts: n/a
Cheap power... If you have stock airbox & filter, do deckplate mod ($?), then try K&N filter (about $40).. If you're not concerned about lots of wet getting in, cut a huge hole in the front of the airbox (that'll let some air in)..
BTW> not kidding.. I dropped a K&N in the box, then cut nearly the entire front wall off the box... not a bad improvement for $40 + an hour's labor. The rubber matting on the side was an addon I did to help prevent hot air.. did not change anything.
Old 05-21-2008, 11:54 PM   #8
zr2ee
Enthusiast
I've done my milage a few times and it always comes to right around 20 MPG, with a good mix to city and highway, as far as power im not sure of the actual numbers but i definately felt it. i'd like to get a dyno but they are just too expensive
i think they have a return policy if your not satisfied, the only downsides are i have to run premium right now and there are no tuners in my area like i stated before, hopefully whenever the new powerflux module comes out it will take care of some of those issues
performance chip nathanxlikexwhoa Performance 10 07-17-2007 05:48 PM
Edge performance chip for ford powerstroke 7.3 sparkytacoma Parts and Accessories 6 03-04-2007 09:03 PM
Performance Chip Tacomac Performance 7 07-21-2006 12:46 AM
Performance chip on E-Bay?????? TRDStreetFighter Off Topic 4 05-09-2003 08:46 AM
Performance chip and programers lowtaco915 Performance 2 04-26-2002 07:31 PM
