33 inch tires on 3 inch lift? - CustomTacos.com Forum
Go Back   CustomTacos.com Forum > 4x4 and PreRunner Discussion > 4x4/PreRunner Wheels and Tires > 2005+
Old 05-04-2008, 12:10 AM   #1
freddeez
Member
Tacoma: 2008 Toyota Tacoma DC LB
Default 33 inch tires on 3 inch lift?
Whats going on, I'm about to get the toytec 3 inch ome lift soon and i want to put 33x12.5x17 Pro Comp AT. Does anyone know if they will rub on the UCA or anything? 33x12.5x17 are wider than 285/70/17 and 285/75/16 i believe... Pls help....
freddeez is offline   Reply With Quote Quick reply to this message
Old 05-04-2008, 01:32 AM   #2
Tillers_Rule
Grand Tacoholic
Tillers_Rule's Avatar
Tacoma: 2006 double cab 4x4.
Default Re: 33 inch tires on 3 inch lift?
From what I have heard, you'll want 4.5" backspacing for the wheels in order to not rub the control arms. You may have slight rubbing issues with the fender well though, nothing a little trimming can't get rid of.
Tillers_Rule is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
1999 8" Lift 35" Tires, Price Reduced joeylead Vehicles:All Other 7 12-20-2006 12:33 PM
95 chevy suburban-11 inch lift -39-1/2 inch tires on 20's cable Vehicles:All Other 3 08-07-2006 04:08 AM
3" lift with stock tires tacoreaper 4x4/PreRunner Suspension 8 04-04-2006 07:46 AM
3.5 inch fabtech lift Kingfisher 1995.5-2004 4 09-08-2004 08:21 PM
5 inch lift Kingfisher 1995.5-2004 19 09-05-2004 02:51 PM
