exhaust manifold heat shield - CustomTacos.com Forum
Old 04-15-2008, 10:03 PM   #1
xwikedonex
Addict
xwikedonex's Avatar
Tacoma: Bagged '99 xtra cab - Had to sell it
Default exhaust manifold heat shield
Can i remove the heat shield that covers the stock exhaust manifold and not have to worry about anything melting??
the shield is cracked in a couple places and makes a god awful noise when my truck is idling so i wanna just remove it. it should be ok right, cause when you run headers there is no shield. just throwin it out there to see what people think
xwikedonex is offline   Reply With Quote Quick reply to this message
Old 04-15-2008, 10:23 PM   #2
rossk35
rossk35's Avatar
Tacoma: 07 Dub Cab TRD Sport Supercharged, (04 2.4 S/C ext cab sold)
Default Re: exhaust manifold heat shield
Yes you can. I took mine off when I had my old truck.
rossk35 is offline   Reply With Quote Quick reply to this message
Old 04-16-2008, 05:39 PM   #3
1 bad tacoma
Moonbeam
1 bad tacoma's Avatar
Tacoma: 2005 toyota tacoma
take it off i had to do that on my 91 toyota i had. i didn't have any problems after doing it
1 bad tacoma is offline   Reply With Quote Quick reply to this message
Old 04-16-2008, 05:42 PM   #4
DieToRemain
Grand Tacoholic
DieToRemain's Avatar
Tacoma: 02 F250 7.3L Turbo Diesel
Fool just go get a thorley header for it man!
02 F250 7.3L Powerstroke Diesel
NOT exactly stock.
DieToRemain is offline   Reply With Quote Quick reply to this message
Old 04-17-2008, 03:57 PM   #5
xwikedonex
Addict
xwikedonex's Avatar
you buyin cause i'm broke!
Old 04-17-2008, 04:17 PM   #6
1 bad tacoma
Moonbeam
don't feel bad i am too welcome to the party
Old 04-17-2008, 05:52 PM   #7
DieToRemain
Grand Tacoholic
haha would if I could man my truck is gonna put me in the poor house.
NOT exactly stock.
Old 04-17-2008, 06:58 PM   #8
chipsndukes
Addict
chipsndukes's Avatar
Tacoma: 1996 Toyota Tacoma Regular Cab 2.4 L 5 spd
you can also cut away the spots that rub/rattle or maybe use some mounting washers under the bolts/nut to help hold it in place. mine is all cracked but doesn't rattle (yet).
then you can have your shield and not worry about it, just a thought.
chipsndukes is offline   Reply With Quote Quick reply to this message
Old 04-25-2008, 04:03 PM   #9
xwikedonex
Addict
xwikedonex's Avatar
GOOD NEWS - BAD NEWS
Good news - i removed the damn rattling heat shield, it was cracked in several places as you can see, one of the bolt holes was cracked all the way around
BAD NEWS - after i removed the heat shied i found out my header had a 3 to 4 inch long crack in it
GOOD NEWS - i guess i'm gonna have to get a set of headers
BAD NEWS - I'm still broke
Old 04-25-2008, 04:32 PM   #10
siebler
Addict
siebler's Avatar
Tacoma: 99 Ex-cab 5 Lug
What engine do you have? I will sell you my stock manifold for cheap if its the right size. I should have my DT header finished Monday.
That heat shield is a pain. I repaired mine several times and finally got it to stop rattling.
"Its a spiritual erection every time"- The Nuge
siebler is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
1997 2rz alternator & stock exhaust manifold pdmech73 Wanted 0 03-20-2007 11:23 AM
box o' harnesses for early 2RZ, and stock exhaust manifold CelicaDRIFTER Parts and Accessories 0 08-28-2006 08:13 PM
Labor to replace exhaust manifold & O2 sensors? 95XCAB 1995.5 - 2004 2 04-11-2006 04:36 PM
Heat shield.......? darrcoma Performance 5 01-13-2004 08:58 AM
Cracked exhaust manifold Corrado Hauler 1995.5 - 2004 12 01-12-2004 01:10 AM
