Front bumper/winch fabrication plans - CustomTacos.com Forum
Go Back   CustomTacos.com Forum > On The Go > Off Road
Old 04-05-2008, 09:01 AM   #1
TEAM SHARK
Member
TEAM SHARK's Avatar
Tacoma: 2000 Prerunner
Default Front bumper/winch fabrication plans
Heys Guys:
Looking for some front bumper/winch fabrication plans for a 2000 tacoma. I would like the plans for a tube bumper/brush guard that will accomdate a winch. My son welds, if the proto type comes out good, then I am going to tell him to sell a few for cheap!! I would like detailed measurements length, curve angles, mounting brackets, etc..
TEAM SHARK is offline   Reply With Quote Quick reply to this message
Old 04-05-2008, 07:38 PM   #2
spyder041
damn
spyder041's Avatar
Tacoma: 1996 3.4L V6 Toyota Tacoma X-Cab 4x4
Default Re: Front bumper/winch fabrication plans
check ttora.. They have a thread for aftermarket bumpers.. Im actually looking to fab one up for my 4runner
New Jersey: Home of where the strong survive, and the weak are killed and eaten.
http://www.myspace.com/wildjerseyfirefighter
Photo Sharing and Video Hosting at Photobucket
spyder041 is offline   Reply With Quote Quick reply to this message
Old 04-05-2008, 07:54 PM   #3
NakedTacoma
Guest
Posts: n/a
what kind of pipe would u use to build a bumper?
Old 04-05-2008, 08:04 PM   #4
spyder041
damn
spyder041's Avatar
idunno.. I'm looking for more of a warn style bumper.. The non tube bumpers
Old 04-05-2008, 08:30 PM   #5
spyder041
damn
spyder041's Avatar
did some research and found that trail gear sells a winch mount base.. Bolts right up to the stock bumper holes on the first gen 4runners and trucks.. Just weld on tubes as you want.. Requires frame bracing for heavy duty winching.. For $130 I may look into it..seems sturdy enough as they make it out of 1/4" plate
Old 04-06-2008, 12:27 AM   #6
tacoman15
Newbie
Originally Posted by TEAM SHARK View Post
Heys Guys:
sorry broski nobody is gonna give you that stuff so you can make money on it. If your son welds and you guys have a tube bender have him build a few prototypes and go from there.
tacoman15 is offline   Reply With Quote Quick reply to this message
Old 04-06-2008, 11:17 AM   #7
NakedTacoma
Guest
Posts: n/a
broski??
Old 04-06-2008, 09:08 PM   #8
tacoman15
Newbie
Originally Posted by NakedTacoma View Post
broski??
Atleast somebody got a kick out of it.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
smashed front end, swap in a 2001 front end PGD55 Body / Structural 2 06-15-2006 03:18 AM
front end squeaking very bad... nooq 1995.5-2004 4 12-02-2005 06:23 PM
99 front end to 03 front end framentation Body / Structural 2 05-19-2004 01:07 PM
front wheel alignment Acidpain 1995.5 - 2004 2 05-19-2004 05:59 AM
Binding noise on front end. ChrisTaco 1995.5-2004 3 02-28-2002 10:13 AM
