Questions on pulling 3RZ out? - CustomTacos.com Forum
Old 03-17-2008, 07:35 PM   #1
Rembrant
Veteran
Rembrant's Avatar
Tacoma: 2000 SR5 4x4
Default Questions on pulling 3RZ out?
Hey folks,
Ok, so I have to pull my engine out and I have a couple questions for those of you that have done so already:
1. Can I just unbolt the AC pump and push it aside out of my way? (So I don't have to screw around with the sealed system)
2. I don't see an engine rear lift hook. Am I blind? I've pulled 22-RE engines before, and they had front and rear lift points.
3. Can you buy new starter contacts? ( like you could for the 22-RE engines) I figure it would be a good idea to do while the engine is out.
4. To replace the oil pan, is there a traditional gasket, or just silicone like Ultra-Copper, etc?
5. Should I bother sending my injectors out for a cleaning & balancing? Truck has 122K miles on it. Maybe it's a waste of time and money?
Any other suggestions on things to do while the engine is out? I'm only pulling it out to replace the oil pan, so I have no intentions of pulling the engine apart, just basic tune-up stuff....filters, plugs, cleaning the MAF, TB, and intake, etc, etc.
Any ideas or thoughts would be great. I'll likely think of more questions as I go. Thanks.
Rembrant is offline   Reply With Quote
Old 03-17-2008, 07:46 PM   #2
Taco_Kid
Taco_Kid's Avatar
Default Re: Questions on pulling 3RZ out?
hmmmm, whats the cost to have the old injectors cleaned vs. just buying a new set??
Taco_Kid is offline   Reply With Quote
Old 03-17-2008, 07:47 PM   #3
95tojo
Tacoma: '95 3rz 4x4 (SOLD) '11 Double Cab TRD Sport (SOLD) '03 3rz PreRunner
the oil pan does not have a traditional gasket . . . go to a toyota dealer and get some of the good sealent . . .
also mine does not have a rear hook either for lift points . . . .
i did buy new start contacts for my 3rz . . . .
and the a/c would be a little tricky, just take it easy when pulling out the motor and see how much clearence you have . . . .
95tojo is offline   Reply With Quote
Old 03-17-2008, 07:56 PM   #4
snwbdr
Grand Tacoholic
snwbdr's Avatar
Tacoma: '02 S/C V6 TRD 4x4
Paradise racing cleans em for $10 per injector....dunno how much a new set will cost but I imagine it'd be a bit more than $40
snwbdr is offline   Reply With Quote
Old 03-17-2008, 08:00 PM   #5
McKeever
McKeever's Avatar
Tacoma: 98 Turbo Taco 2WD Std. Cab 5 spd & 79 4WD Toy Pickup
What makes you think you need to pull the motor to replace the oil pan?
McKeever is offline   Reply With Quote
Old 03-17-2008, 08:11 PM   #6
chipsndukes
Addict
chipsndukes's Avatar
Tacoma: 1996 Toyota Tacoma Regular Cab 2.4 L 5 spd
Originally Posted by Rembrant View Post
Hey folks,
1. I did that with no prob. on my 2RZ, also how the FSM describes removing the engine, A/C system stays closed
2. there is a bolt hole kitty corner to the hook in front in the head, I swapped the hook to the back. i just put the bolt the hook in the front on the rear and but the bolt through a chain link on the front. maybe someone else knows a better way
4. you can get a cork gasket and i used one, i don't know if it did any good, I covered it every sq. inch with ultra copper and gently tightened, I don't know if it is the right way, but it made me feel slightly better because it was easier and I doubt it will leak or be a problem. If you screw up the FIPG you take the pan off again, someone hear can walk you through the perfect 'Toyota' way.
5. I sprayed em down with Gumout on the tip, the filled them a little with Gum out and tripped them with a battery while I hit them with a blow gun, did that a couple time, mines a daily driver too and I get 27mpg so I don't worry about 'calibrating' or "balancing".
I would recommend putting new injector o-rings and grommets and replace the valve cover gasket and also the front and rear oil seals. Fuel filter, too.
Do you really have to pull the engine on a 3RZ to replace an oil pan? (Help out a 2WD 2RZ guy, I'm maybe a little ignorant?
CD
chipsndukes is offline   Reply With Quote
Old 03-17-2008, 09:07 PM   #7
Tred
Grand Tacoholic
Tred's Avatar
Tacoma: 2002 3RZ-TFE 1BAR
2. FSM calls for installing a second hook temporarily.
Vrrm pssht!
Tred is offline   Reply With Quote
Old 03-18-2008, 02:25 AM   #8
Rembrant
Veteran
Rembrant's Avatar
Guys,
Thanks for all the answers, thats great.
Truck is a 4x4 and there's about 3/8" clearance between the top of the front diff and the bottom of the oil pan. I don't see any other way to do it other than lifting the engine out. I suppose I could drop the front diff, but that looks like a ton of work to me.....maybe pulling the engine is the lesser of two evils, I dunno.
At least if I have the engine out, I can put it on a stand, flip it upside down and do it right.
If there's an easier way to do it, I'm all ears boys? Let me know.
Old 03-18-2008, 02:54 AM   #9
Tred
Grand Tacoholic
Tred's Avatar
Dropping the diff is easier, supposedly.
Vrrm pssht!
Old 03-18-2008, 07:03 AM   #10
tylerangle1990
tylerangle1990's Avatar
Tacoma: '00 Lunar Mist Stepside - Back & Boosted. Replacement: '02 MSM IS300 5spd w/LSD :-D
They both sound like work to me. Do whatever you're comfortable with
The taco is back and on the boost!
tylerangle1990 is offline   Reply With Quote
Cannot shift out of park and tranny fluid level questions pray4surf 1995.5 - 2004 7 03-16-2008 07:07 PM
Ultimate 3RZ Drivetrain? JESSE_at_TLT Performance 17 01-29-2006 01:51 PM
2RZ for 3RZ Swap - I have some Questions Proteus503 Performance 5 05-30-2004 01:54 PM
Are 2RZ and 3RZ clutches the same? What about 2WD and 4x4? mosk Performance 7 12-19-2003 07:06 PM
Pulling a 3RZ head? mosk 1995.5 - 2004 2 11-15-2003 07:55 AM
