horrible gas milage - CustomTacos.com Forum
Old 03-07-2008, 09:29 PM   #1
spyder041
damn
spyder041's Avatar
Tacoma: 1996 3.4L V6 Toyota Tacoma X-Cab 4x4
Default horrible gas milage
been getting progressively worse mpg on my truck..1/2 tank is at 115 miles.. Did a tune up and it didnt make a difference.. Can my truck just need to be tuned or something? Only thing I have done is borla cat- back and an open air cone.. Drive like a grandma too..
New Jersey: Home of where the strong survive, and the weak are killed and eaten.
http://www.myspace.com/wildjerseyfirefighter
Photo Sharing and Video Hosting at Photobucket
spyder041 is offline   Reply With Quote
Old 03-07-2008, 09:34 PM   #2
humanoid
This Space For Rent
humanoid's Avatar
Tacoma: '99 PreRunner Xtra Cab 3.4L V6
Default Re: horrible gas milage
Are you getting any codes? Maybe the MAF sensor is dirty too.
humanoid is offline   Reply With Quote
Old 03-07-2008, 09:35 PM   #3
Firdaddy
Grand Tacoholic
Firdaddy's Avatar
Tacoma: 2001 Stepside turbo 06 Forester fxt
i'm right there with ya man, nothign i do makes a difference
dumpted since 2/15/08 MMMMMM boos t
Firdaddy is offline   Reply With Quote
Old 03-07-2008, 09:37 PM   #4
spyder041
damn
spyder041's Avatar
No Codes.. When I did my tune up I cleaned the maf also.. Wonder if I put my airbox back in if it would help? Maybe do thedeckplate.. I used to get 250 miles when I had my truck stock
Old 03-08-2008, 12:32 AM   #5
dropthattaco
www.ncp-power.com
dropthattaco's Avatar
Tacoma: 97 Taco 2.4L t-t-t-turbo
Might try replacing your front o2 sensor or sensors (the one or ones before the cat). They can get sloppy and not set a code sometimes. Also, does your truck warm up to normal operating temp?
Turbo, bitches.
dropthattaco is offline   Reply With Quote
Old 03-08-2008, 03:46 AM   #6
Rembrant
Veteran
Rembrant's Avatar
Tacoma: 2000 SR5 4x4
Have you tried a good does of Seafoam or similar product? Could the cat be gettin' plugged up?
I'd at least try sticking some of the stock bits back on at least to rule them out....
I had the exact same truck, right down to the Ivans and same size tires, and I rarely ever got below 300 miles to a tank before the fuel light came on....even got as high as 310-315 on the highway b4 the light came on.
In any case, good luck...hope you get it sorted out....gas is spendy these days.
Rembrant is offline   Reply With Quote
Old 03-08-2008, 07:03 AM   #7
glassdoc
Waxed to Perfection
glassdoc's Avatar
Tacoma: 04 Tacoma Doublecab 4x4 SuperCharged
Where do you buy your fuel from? Check the ethanol sticker on the pump.. The more ethanol, the less miles per gallon you are going to get. Clean the MAF, if it is a sensor its likely the rear O2 sensor, 60k is recommended change from Toyota. Overall how does it run? Idle good, throttle response? Have you looked at your plugs? Pull one and check the gap, they do change on the 3.4's after having been run for a time. You mentioned the cone filter. Did you oil it up? Maybe it coated the MAF, maybe it has too much oil on it and not letting in enough air..
I'm proud to have had the privilidge to meet some of the greatest CT'zens in the world. At mini-meets, meet n greets, car shows and TacOberFest. It all started right here..
glassdoc is offline   Reply With Quote
Old 03-08-2008, 09:50 AM   #8
pug407
pug407's Avatar
Tacoma: Tacoma Prerunner 2003 SC'ed 3.4
What exactly you call a tune up, what parts you changed, cleaned...?
pug407 is online now   Reply With Quote
Old 03-08-2008, 07:23 PM   #9
chipsndukes
Addict
chipsndukes's Avatar
Tacoma: 1996 Toyota Tacoma Regular Cab 2.4 L 5 spd
happened to me on my truck mileage went from 25-26 to 21-22 after did some engine work (head gasket), the front O2 sensor flaked out but didn't throw a code, switched it and went back to 25-26 instantly, what drophat says above is true, don't have to have a code to have a bad sensor, would go with this solution.
CD
chipsndukes is offline   Reply With Quote
Old 03-10-2008, 12:15 PM   #10
Tacasandburritos
Enthusiast
Tacasandburritos's Avatar
Tacoma: 2004 Tacoma extra cab TRD V6 4x4
Make sure your gas station gets alot of traffic. I had MPG issues as well by going to po-dunk gas stations that saw maybe one car a day. The gas just sits in the tanks and pretty much turns into water.
Tacasandburritos is offline   Reply With Quote
Realistic 2007 Double Cab milage ? ericg23 On Road 6 05-13-2007 12:27 PM
horrible gas milage? spyder041 1995.5 - 2004 8 12-17-2006 04:53 AM
Gas Milage Difference Between A/T & M/T zRockstar 2005+ 2 09-21-2006 01:21 PM
Gas milage? 99redyota Performance 22 08-28-2005 06:48 PM
Bad milage Luvs2Race 1995.5 - 2004 31 07-10-2005 12:07 PM
