suspension 05+ - CustomTacos.com Forum
Go Back   CustomTacos.com Forum > 2wd Discussion > 2wd Suspension > 2005+
Old 03-01-2008, 01:24 AM   #1
dune boy
Member
dune boy's Avatar
Tacoma: 05 toyota tacoma
Default suspension 05+
so i thinking about getting the allied spindle lift for the front, and AAL for the rear? would list be ok? will i have to get new shocks for the rear,..? thanks
dune boy is offline   Reply With Quote
Old 03-01-2008, 02:19 PM   #2
chris4x4
Addict
chris4x4's Avatar
Tacoma: 2007 Double cab Prerunner, OME 885's, TC UCA's,Rear 5100's, 285/60/18 Nitto Terra Grapplers
Default Re: suspension 05+
Yes.
chris4x4 is offline   Reply With Quote
Old 03-01-2008, 06:07 PM   #3
NakedTacoma
Guest
Posts: n/a
not if u have a 5 lug diffrent front suspension
Old 03-01-2008, 11:43 PM   #4
dune boy
Member
dune boy's Avatar
i think its the 6 lug.. whats the diff? i have the 05 trd off road access cab. umm so if you get the AAL it wont blow out the shocks that i already have? by making the travel to long?
Old 03-02-2008, 01:19 AM   #5
DrifterFreak210
Enthusiast
DrifterFreak210's Avatar
Tacoma: 2006 Tocoma Indigo Ink Reg cab
The difference is 5 lugnuts per rim vs. 6 lugnuts per rim. huge difference. But one problem, your in the wrong section, it you read the the other section above the 2wd, its 4wd/prerunner, go there, much more help there then here since you have a different suspension.
15x8 Rockcrawler 51's and 31x10.5x15 Diffenity Mud Terrains, 2 inch leveling kit from the 6 lug, Ipod2car, BHLM, K&N 63 Intake, DT Header, Exhaust Cutout, BEEFED UnderGuard.
DrifterFreak210 is offline   Reply With Quote
05+ Tacoma sections ninobrown Customtacos AutoGuide Forum Support / Help 59 10-29-2005 02:28 AM
Hello L's & G's! New here and was hoping I could get some advice? WTT Off Road 28 04-15-2005 05:30 AM
Rear Suspension Advice momotaro S-Runner Talk 14 07-23-2003 06:07 PM
Roadmaster Active Suspension tested out this past Sunday... Vracer111 1995.5-2004 19 05-12-2003 02:55 PM
