Go Back   CustomTacos.com Forum > The Garage > Performance
CustomTacos.com is the premier Toyota Tacoma forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Old 11-13-2005, 04:09 PM   #1
TRDOLMAN
The Ol Man
TRDOLMAN's Avatar
Tacoma: 04 xcab 4x4 with S/C 3.4 auto
Default URD\'s 3.4 Turbo S Runner----impressions
Well with Gadget's permission, it's time to let some info out about the Turbo S Runner prototype.
Sean (S/X Runner) is the lucky bastard that owns the truck the turbo kit was installed on. Since Sean only lives a few blocks from me, he was kind enough to come by the house for me to take a good look at it. He only got it back a couple of days ago.
Impressions:
Gentlemen this turbo kit is the REAL DEAL! It has to be the nicest exhaust/turbo manifolds I have ever seen. The intake piping/intercooler set up is routed well with minimum cutting involved and looks good at the same time. The picture Gadget posted in the "teaser" thread in the S Runner forum is indeed Sean's truck. The picture doesn't really do it justice. The cruise control box had to be relocated and Sean has to come up with a different windshield washer tank and location.
The fuel setup is unique. As shown in the picture there are 6 additional 240cc RC injectors provided in a special injector plate sandwiched between the two halves of the intake plenum. A special additional injector controller (AIC) is used to control the extra injectors. Basically the system uses the stock ECU for all engine functions including most of the closed loop. The MAF signal is not altered. A URD AFR calibrator is installed to aid in the transition from closed to open loop. The AIC starts adding fuel approaching and during open loop. Those 6 injectors
should be able to handle all the boost and HP this turbo wants to produce.
The system looks good and appears to be well engineered. I think I drooled on Sean's fender when I was looking at the manifold!
Sean cranked it up for me and it ran pretty much like a stocker except for the tone of the exhaust. URD installed a 3" exhaust from the downpipe and a very large Dynomax muffler exiting in the stock location. Sounded nice and beefy without being loud.
I was asked if I wanted a ride---as if he had to ask!!! All I can say is WOW! The turbo spooled at about 2000/2200 rpm however I felt no lag. The way the setup is now, it produces 6.5 psi of boost. Honestly as hard as this thing pulls, I'm not sure you need to boost any higher. At 6.5 psi boost this truck will pull my 12 psi S/C truck with no problem at all. I didn't get the "full tour" but Sean made a few runs in 2nd and 3rd to redline. Very impressive to say the least!! I was pushed back in my seat hard. The turbo and blowoff valve make this thing sound awesome.
I don't have any particulars on the turbo or the trims. You guys will have to ask Gadget. There are no dyno numbers or track times on this truck yet. There are a few more personal "tweaks" Sean is going to do first like install a manual boost controller. He plans on setting it up so he can run around 12 psi as well as the stock 6.5 psi. He said he will dyno at both settings and post the sheets. The track is closed for the season so that will have to wait as well. I can tell you this, he did a 2nd gear roll on for me and even with the sticky X Runner tires he has, the tires simply went up in smoke. I don't know how he is going to get all this power to the ground while running on the street. (I really wish I had that problem!!) Guys, there is no way you can run this turbo setup with out a really good clutch, a good LSD or locker, and the widest, stickiest tires you can find. This is not a setup for the "meek and mild". You better know what you are doing if you want to make use of all the potential of this kit.
All in all, if you guys care about my opinion, I was very impressed with the quality and most definitely impressed with the performance. It is a very "mild mannered" street set up you could daily drive with no problems at all. When you get on it and hit full boost all hell breaks loose and this thing simply hauls ass!! I don't know how else to describe it. My work truck is a Cummins turbo and I know well what turbo lag is. Lag on this setup was not a factor. If it lagged I couldn't tell. Then again my ass was taking bites out of his seat cushion when he was stepping on it and I was so amazed at the amount of "push back" I was feeling, maybe I just didn't notice!
Gentlemen, I am no expert on turbo systems but I am impressed with this one. If the production kit is anywhere close to this setup there are going to be some very happy 3.4 drivers when it comes out. After Sean gave me the ride, I had to slap him upside the head to get that dumbass grin off his face and get him to talk!!
Sean, again, you are one lucky bastard!!
Dave
TRDOLMAN is offline   Reply With Quote
Old 11-13-2005, 04:50 PM   #2
RevHard6
il padrino
Tacoma: 2008 V6 DC Prerunner TRD Off Road
Default Re: URD\'s S Runner Turbo----impressions
Time for another trip down to Dave's house.
Hmmm.... Dammit, the temptation.
RevHard6 is offline   Reply With Quote
Old 11-13-2005, 05:10 PM   #3
CUSTOEM
Tacoma: 2003 BSP S-Runner
Uhhhhh
CUSTOEM is offline   Reply With Quote
Old 11-13-2005, 06:14 PM   #4
trdtrlsntrq
Tacoma: 1996 EX-Cab Taco V-6 4X4-Maxed
Default Re: URD\'s 3.4 Turbo S Runner----impressions
When can I buy one?
trdtrlsntrq is offline   Reply With Quote
Old 11-13-2005, 08:00 PM   #5
Impulse2k1
Impulse2k1's Avatar
Tacoma: 2001 Toyota Tacoma Dub Cab
Wow! that thing sounds sick. Is it just going to be for the S-runner or is it going to be for all 3.4l equiped tacos?
Impulse2k1 is offline   Reply With Quote
Old 11-13-2005, 08:04 PM   #6
trdtoy
trdtoy's Avatar
Tacoma: 2002 Toyota Tacoma, Extra cab, 4x4, V6, 4spd auto
From my understanding it should fit any 3.4L/5vz equipped taco/4-runner.
trdtoy is offline   Reply With Quote
Old 11-13-2005, 08:12 PM   #7
relimseoy
Veteran
relimseoy's Avatar
.....a man ........his name.............
GADGET
relimseoy is offline   Reply With Quote
Old 11-13-2005, 08:20 PM   #8
TRDOLMAN
The Ol Man
TRDOLMAN's Avatar
The kit should fit all 3.4 trucks both 2WD or 4WD--- all tacos, 4 runners, and tundras.
As to when it will be available----from what Gadget has told me----he is going to install the kit on his personal 4 Runner, give it a good and thorough evaluation, then make a final determination on market feasibility. That's Dave talk for "I don't have a clue".
Old 11-13-2005, 08:56 PM   #9
S/X Runner
Yeeeah, I'm still smiling!!! The work that was done is unmatched to any I have ever seen before. I am sooo stoked that the workmanship that is on my truck IS ON MY TRUCK. I am not lying when I say this, I just go outside to open my hood and I stare at the manifolds, the piping, the exhaust, everything and my mouth actually starts to water. Then I just think this stuff looks sooooo good. The "kit" performs excellent!! My truck now has Titanium balls!!
A HUGE thanks goes out to www.URDUSA.com for having the love for Tacos!!!!!!
S/X Runner is offline   Reply With Quote
Old 11-13-2005, 09:09 PM   #10
ChrisTaco
Grand Tacoholic
ChrisTaco's Avatar
Tacoma: Sold: Bagged 97 5MT
Awwww.....skeet skeet skeet.
ChrisTaco is offline   Reply With Quote
Powered by vBulletin® Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
