Went to the track last night (vids) - Page 3 - CustomTacos.com Forum
Go Back   CustomTacos.com Forum > The Garage > Performance
Old 02-26-2013, 10:37 AM   #21
Speed Freek
Tacorvette enthusiast
Speed Freek's Avatar
Tacoma: 98 Extra cab 2wd, 5.7L LS1 aluminum block V8 with a T56 6 speed manual trans.
Default Re: Went to the track last night (vids)
Originally Posted by Racer_X View Post
The head wasn't decked properly and it let go while spanking a s/c'd X-Runner... with that said... with a properly decked head, I could have run 18psi on 440 primaries and 290(Stock Pink Tops) as secondaries.
Was the head overcut or just a bit too much timing? Did the valves touch the piston? I actually prefer higher static compression in an FI motor, for the street anyway.
BOOST BRIGADE I fabricate custom parts: HEIM STYLE STRUT RODS, FORWARD FACING INTAKE MANIFOLDS, and TRACTION BARS (5 LUG) contact me for more info @ www.Speed-freek.com or just PM me here THANKS!
Former Lexus / Toyota tech
Speed Freek is offline   Reply With Quote
Old 02-26-2013, 11:09 AM   #22
Texas_Ace
Texas_Ace's Avatar
Tacoma: 4Runner, 2000 limited
I agree, the days of low static compression boosted motors is quickly coming to an end, finally.
Just look at the new FRS/BRZ. They come from the factory with 11.5:1 compression and they are boosting those with ~18psi+ making 400whp+ on pump gas. Or look at basically any honda build now days.
2000 Toyota 4runner Limited 3.4l V6 Auto SUPERCHARGED, Meth injection, 2.0" Pulley, Doug Thorley Headers - My truck - My Youtube with lots more
Member of the "No BOV Club"
Texas_Ace is offline   Reply With Quote
Old 02-26-2013, 12:12 PM   #23
GRILLCRAFT
Supporting Vendor
High Compression FI motors are on the trend to popularity and a few local guys have have done some really bad damage to their motors. Some precautions to doing it:
-Watch/Limit your boost
-Know how much power your bottom end can take
-Dont over do the turbo size
A friend in particular built an entire block 11:1 compression, went FI with it and basically his crankshaft said I'm out of here. That was with a decent sided GT42R. Other guys can get more out of a paticular engine, but never lose mind that your build can only handle so much power.
GRILLCRAFT is offline   Reply With Quote
Old 02-26-2013, 12:58 PM   #24
Texas_Ace
Texas_Ace's Avatar
Naturally you have to build for your goals, that goes for any compression ratio.
High compression ratios will need a different tuning strategy, less boost and better intercooling as a rule but these are basics for any build IMO.
You also have to be reasonable with the compression ratio, for most engines 9-10:1 is the sweet spot, newer engines can run higher ratios then older ones as a rule.
With the ability of guys to use E85/water/meth injection now days high compression is the choice more then ever. Just look at all those stock block 5.3 GM truck motors making 800-1000whp with stock 9.5:1 compression. Or all the supras making even more with 10:1 builds.
It is about the whole package, got to make sure everything is working together properly.
Old 02-27-2013, 11:58 AM   #25
Racer_X
Turboless :(
Racer_X's Avatar
Tacoma: 06 IS250/ 09 328i
Compression was 9.5:1
Pistons didn't hit the valves.
Overcut and prolly more than necessary timing...
when it was running it ran stupid strong... kinda hating that I sold it for like 2500... hahahaha oh well!
I'm all VEEP'd now.
Racer_X is offline   Reply With Quote
Old 02-27-2013, 12:34 PM   #26
Tacoma: 2002 Tacoma mini, 08 Corolla S MT
That night we ran my plates on your truck,
that srt4 acr had no clue what to think when you unleashed hell!
I was so nervous at that dui check point, I felt like the black guy
And that shlt with the cop and the flashlight thing..
Priceless.. Hey, nice gmc syclone! Haha..
Best taco homey memory to this day!
Chris D. is online now   Reply With Quote
Old 03-01-2013, 10:28 AM   #27
Racer_X
Turboless :(
Racer_X's Avatar
Yeah, bro that was AWESOME... shouldda got it on video!! That same night some old broad flashed her tits at us!! Good ol' Methdesto!!
I'm all VEEP'd now.
Old 03-04-2013, 06:39 AM   #28
toycoma98
toycoma98's Avatar
Tacoma: 1998 2-RZ Turbo @ 10 PSI. Original owner since 1997
man, i did 15.6 @ 96mph. 0-60 was like 2.50 or higher. this was with new tire and speeds traction bars.
I did 15.1 at 100 before.
I need slicks.
toycoma98 is offline   Reply With Quote
Old 03-04-2013, 10:06 AM   #29
671taco
671taco's Avatar
Tacoma: 95.5 Tacoma / 05 Dbl Cab Tundra
I need slicks.
What are u doing bro? lol What type of tires are u running and pls don't say street tires. At least run a drag radial either bf goodrich or MT.
I was hitting 1.9 60' times on drag radials.
434hp 368tq @ 18PSI/ OEF 10-11
671taco is offline   Reply With Quote
Old 03-04-2013, 10:24 AM   #30
I need slicks.
This before you turbocharged it.. You gadda hit the track now that your boosted.. I'm curious what'll do @ 10psi.. High 13's at the worst I'd guess.
With a header, intake and some decent tires, my buddy Nate with his 04 standard cab taco ran 15.9 @ not sure..
I ran a 17.1 bone stock open diff lol
Went to the Track last night! LukeDuke Performance 7 04-09-2009 06:25 PM
couple vids from last night Firdaddy On Road 18 10-04-2006 11:29 PM
track last night - new best (vid) ComaJoe S-Runner Talk 6 01-09-2004 01:39 PM
the night at the track.. redrunner S-Runner Talk 15 05-13-2003 09:06 AM
Track last night! hypertaco Performance 14 04-14-2002 09:37 PM
