sitting crooked - CustomTacos.com Forum
Go Back   CustomTacos.com Forum > 2wd Discussion > 2wd Suspension > 1995.5-2004
Old 01-15-2013, 07:52 AM   #1
slidingtaco
Tacoma: 1999, Toyota, Tacoma
Default sitting crooked
Would different kinds/makes/models of shock mess up the front ride height? One side of my truck has a tokico blue and the other is some yellow shock with the fork pulled all the way up and a bunch of spacers installed to take up the slack. Ive noticed the drive-side sits lower than passenger side What to do???
slidingtaco is offline   Reply With Quote
Old 01-15-2013, 09:06 AM   #2
Mambeau / Admin
Default Re: sitting crooked
(1) Exactly what sort of Tacoma do you have?
(2) It is common and normal for the driver side to sit slightly lower than the passenger side, because most of the weight (battery; fuel tank; driver; etc.) is on that side. We call it 'The Taco Lean'.
(3) However ... The fact you have mismatched front shocks might mean this is not just a case of the usual Taco Lean.
Enola Gaia is offline   Reply With Quote
Old 01-17-2013, 01:51 PM   #3
slidingtaco
1999 SST Standard Cab, 2WD, 2RZ-FE 2.4L w/5speed
Old 01-17-2013, 02:26 PM   #4
Tacoma: 2002 Tacoma mini, 08 Corolla S MT
has it been wrecked?
Tubro, bro!
Chris D. is offline   Reply With Quote
Old 01-17-2013, 05:10 PM   #5
Mambeau / Admin
I'm not sure what you've got there. The presence of the spacers would make me suspect the yellow one is obviously the non-stock one.
However ... Toyota didn't use factory Tokicos until the 2001 model year (and then only on TRD Double Cabs and S-Runners). So the blue Tokico is definitely not OEM / factory.
Old 01-18-2013, 12:11 PM   #6
slidingtaco
From what the previous owner told me, I deer ran into the driver side fender... I'm thinking something other than a deer must have hit it at some point
Old 01-23-2013, 10:01 AM   #7
So Low
So Low's Avatar
Tacoma: 2001 Reg Cab 5/6.5 drop!
Most of our generation Tacos have the lean. I had to trim a small amount from my drop spring on the passenger side to compensate. Also had to run a 1/2" larger block in the rear for the higher side. She sits nice and level now.
Proud member of the Beefed Taco mailing list!!!
So Low is offline   Reply With Quote
Old 02-01-2013, 09:48 AM   #8
slidingtaco
I finally got it fixed!!! for the front I added a 1.75" rubber Coil Spring Spacer and in the rear removed the 1" bloack I had stacked on the 3" block. Sit nice and even now, and rides a hell of a lot better too ;-)
help bed is crooked LIVE2HUNT Maintenance 9 04-25-2011 09:30 PM
WTF!?! Crooked Bed... texastrd7 Body / Structural 8 04-01-2007 11:03 AM
anyone's bed on crooked cseger1 X-Runner Talk 17 03-13-2006 05:55 PM
crooked bed... VBTaco Body / Structural 5 01-02-2005 04:56 PM
Anyone else with a crooked axle!?!?!? s-runnin 1995.5-2004 21 12-16-2002 06:38 AM
