Eibach springs / custom springs - CustomTacos.com Forum
Go Back   CustomTacos.com Forum > 2wd Discussion > 2wd Suspension > 1995.5-2004
Old 12-20-2012, 07:29 PM   #1
footinmouth
Tacoma: 01 s/c 2.4 reg cab
Default Eibach springs / custom springs
I'm sending an eibach spring to a custom spring shop so they can check the rate and make me custom springs that would be around 500 lbs [ just my guess ] with an additional 1 to 1.5 drop . Track / street application. The cost will be around 250 for the set , they may drop the price if more people want some but I haven't asked yet . Let me know and we'll see how it goes . As far as I know the eibach springs [ discontinued ] are the only performance springs for our trucks .
footinmouth is offline   Reply With Quote Quick reply to this message
Old 12-20-2012, 07:49 PM   #2
Mambeau / Admin
Default Re: Eibach springs / custom springs
Please be sure to post the results of the spring rate evaluation on the Eibachs. The exact Eibach spring rate has always been a subject of debate.
Enola Gaia is offline   Reply With Quote Quick reply to this message
Old 12-20-2012, 10:07 PM   #3
Tacoma: 2002 Tacoma extended cab 2wd 5 lug
Why not spend a little more and get an adjustable dampened coilover with the spring rate of your choice?
Your still going to need a custom shorter shock that more than likely will not have adjustable dampening to go with that spring..
Factor in the price for those custom springs, then add the cost of custom shocks then call Luis @ Paradise Racing and see what kind of specials he's runnin. (humor me)
Your really not that far off from having QA1 coilovers.
Just sayin.. It's a night and day difference.
Chris D. is offline   Reply With Quote Quick reply to this message
Old 12-21-2012, 08:33 PM   #4
footinmouth
I have QA's in the stock pickup points in the front but had to grind some of the inside LCA and cut off the turn knob and make it a flat slot for adjustment . It can be adjusted without taking it off. The other set up I've seen on here is very nice . I own the shocks already . I'll let you know what the real spring rate is . I remember them telling me it was 427 or so .
Old 12-21-2012, 11:39 PM   #5
Oh, so you dont have a coilover.shock in there? Just an adjustable shock? Specs?
Any reason you didn't do the coilovers? What.are you using the truck for?
Old 01-05-2013, 08:56 PM   #6
footinmouth
I've had the qa's in since 06 and the coil over's were not around . I have a deal with qa and they will be sending me new shocks ,when I get the specs I'll pass the info on. The truck was set up for hpde track days/DD/ fast road driving when the coast is clear .Now that I have a van this truck will turn into a gutted, caged track/ road vehicle . Motor to come soon ,250 at the wheels will be the range I'll be shooting for . The truck also has a 1/8 thick aluminum cover with a 65 degree 5 inch spoiler .Nascar truck style but lower .
Old 01-06-2013, 03:23 AM   #7
toycoma98
toycoma98's Avatar
Tacoma: 1998 2-RZ Turbo @ 13 PSI.
Belltech 2" drop $174
http://thesuspensionsource.mybigcomm...-springs-4260/
SuspensionSource brand 2" drop $169
http://thesuspensionsource.mybigcomm...COMA-6CYL.html
toycoma98 is offline   Reply With Quote Quick reply to this message
Old 01-06-2013, 08:08 AM   #8
stirpicult
Tacoma: 2000 2wd std cab
pics? your truck sounds a bit like what i am shooting for with mine.
stirpicult is offline   Reply With Quote Quick reply to this message
Old 01-06-2013, 08:24 AM   #9
NVTACO
NVTACO's Avatar
Tacoma: 97 5 lug
I'd rather have copies of eibachs .75" drop
NVTACO is offline   Reply With Quote Quick reply to this message
Old 01-06-2013, 10:54 AM   #10
Originally Posted by toycoma98 View Post
Those are just lowering springs, their not aimed towards performance..
I'd rather run qa1 coilovers, had these have been a known option years ago, thats where I would have leaned towards because nothing else beats the performance (for my needs at least) Static < Adjustable
If you really like to yank the wheel and get on it, off the shelf drop spring and shock combo's are a waste of your time.
Quick Reply
Message:
Options
Register Now
In order to be able to post messages on the CustomTacos.com Forum forums, you must first register.
Please enter your desired user name, your email address and other required details in the form below.
User Name:
If you do not want to register, fill this field only and the name will be used as user name for your post.
Password
Please enter a password for your user account. Note that passwords are case-sensitive.
Password:
Confirm Password:
Email Address
Please enter a valid email address for yourself.
Email Address:
Log-in
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
You may post new threads
You may post replies
Eibach Springs interm_4 Parts and Accessories 1 01-04-2012 08:34 PM
Eibach springs YankeeTaco72 Parts and Accessories 2 11-27-2009 11:17 PM
djm 3/4 with eibach springs 96excabtaco 1995.5-2004 6 07-24-2004 03:03 PM
new fiberglass leaf springs and eibach coil springs installed. ToyComa 1995.5-2004 28 03-07-2004 08:33 PM
eibach springs ComaSutra 1995.5-2004 5 05-30-2002 12:20 PM
Powered by vBulletin® Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
