1996 tacoma 2.4l 2wd 180,000 p0300 - random misfire - CustomTacos.com Forum
Go Back   CustomTacos.com Forum > The Garage > Maintenance > 1995.5 - 2004
Old 12-14-2012, 01:07 PM   #1
nickn
Tacoma: 1996 toyota tacoma
Default 1996 tacoma 2.4l 2wd 180,000 p0300 - random misfire
I am looking for suggestions on what to try next with my truck. It put out p0300, random misfire, and p0301-304, misfire on all cylinders. It started out misfiring worse at idle, and it was fine above 40 mph. after changing plugs, plug wires, coil, rotor, distributor cap, it idles fine, and now starts to misfire around 1700 rpm. it will stop if i accelerate in first or second past 2500 rpm, but 3,4, and 5 it gets worse the more i accelerate. I also replaced the fuel filter. could it be throttle position sensor or would it be putting out a code for that? How about the ignition module? thanks for your help.
nickn is offline   Reply With Quote Quick reply to this message
Old 12-16-2012, 01:24 PM   #2
nickn
Default Re: 1996 tacoma 2.4l 2wd 180,000 p0300 - random misfire
replaced ignition module and patched crack in exhaust manifold its better, but still misfiring a little.
Old 12-16-2012, 01:28 PM   #3
tacomatic1
Grand Tacoholic
tacomatic1's Avatar
Tacoma: 1998 Automatic 2rz xtracab, 1999 5spd 2rz regcab
i was getting bucking and misfire when cruising/slow accel around 2500 rpm when my front O2 was bad. Changed it and it went away. This is because your truck uses the front O2 for cruise AFR/slight throttle. Under high throttle it uses the fuel table.
tacomatic1 is offline   Reply With Quote Quick reply to this message
Old 12-17-2012, 07:08 AM   #4
Mambeau / Admin
(1) Welcome to CT, nickn!
(2) I think you're the 3rd one in the last month to ask about misfire problems in an early (1995.5 / 1996) 4-cylinder.
(3) It's conceivable that a problem with the throttle position sensor could cause this. So far the only solid solution anyone's found has to do with the front O2 sensor and / or the wiring associated with the front O2 sensor. Whether this turns out to be the source of your problem is anybody's guess.
Enola Gaia is offline   Reply With Quote Quick reply to this message
Old 12-17-2012, 08:38 AM   #5
nickn
thanks guys, i will give that a try.
Old 12-25-2012, 12:25 PM   #6
nickn
well i ordered the front o2 sensor, and the day it came in my check engine light had come back on, i went ahead and put the o2 sensor on and drove the pickup, still misfires, mostly in 4 or 5th low rpm and then giving it alot of gas, and the check engine light was still on. so I put the reader on it again and this time it read p0141 oxygen sensor bank 1 sensor 2, which is for the one after the cconverter. could this sensor have anything to do with my misfiring problem, or did the misfiring cause this sensor to trip the check engine light? thanks for your help
Old 12-25-2012, 07:22 PM   #7
tacomatic1
Grand Tacoholic
tacomatic1's Avatar
i highly doubt sensor 2 would cause a misfire, as this one is merely for indicating whether your catalytic converter is functioning. Have you cleaned your MAF recently? Also did you pull the efi fuse or disconnect the positive for a bit to discharge the ecu?
Old 12-25-2012, 09:01 PM   #8
NVTACO
NVTACO's Avatar
Tacoma: 97 5 lug
Any modifications?
Try checking the compression and valve clearance
NVTACO is offline   Reply With Quote Quick reply to this message
Old 12-26-2012, 07:43 AM   #9
nickn
Cleaned MAF last week, i didnt disconnect battery after replacing front 02 sensor, but i did after doing the other work. And no modifications to the truck. I will try disconnecting the battery one more time. I may take it to a mechanic if i need to check compression and valve clearance.
Old 12-26-2012, 02:34 PM   #10
TeamSleepRacing
TeamSleepRacing's Avatar
Tacoma: 96' 3.4 4XTaco
Default
You say that all the "tune up" helped curb the missfire a little? Could be related directly to the distributor itself. Pull the cap back off, grab the rotor shaft firmly and try to wiggle it(side to side, circular play is ok).If the shaft has Any play in it at all it will make it missfire a bit.
Sent from my iPhone using AutoGuide.com Free App
TeamSleepRacing is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
In order to be able to post messages on the CustomTacos.com Forum forums, you must first register.
Please enter your desired user name, your email address and other required details in the form below.
User Name:
If you do not want to register, fill this field only and the name will be used as user name for your post.
Password
Please enter a password for your user account. Note that passwords are case-sensitive.
Password:
Confirm Password:
Email Address
Please enter a valid email address for yourself.
Email Address:
Log-in
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
You may post new threads
You may post replies
misfire 98 tacoma 2.4L msanteler 1995.5 - 2004 5 07-04-2010 09:30 PM
p0300 and p0051 codes... HOSS454 Performance 9 12-03-2008 03:40 PM
CEl p0300 misfires George4drV6 1995.5 - 2004 20 01-23-2008 04:57 PM
Another code, p0300, and p0303. Need help, what should i do next? jaime7818 1995.5 - 2004 23 12-21-2007 10:48 PM
Random used parts for Tacoma!!!!!!!!!! Superdan Non-Automotive Items 13 06-02-2005 10:46 PM
Powered by vBulletin® Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
