Mean Green hi output alternator fuse source - Page 3 - CustomTacos.com Forum
Go Back   CustomTacos.com Forum > The Garage > Performance
Old 11-27-2012, 06:32 AM   #21
Mambeau / Admin
Default Re: Mean Green hi output alternator fuse source
Depending on which wire was broken, that might explain everything ...
Enola Gaia is offline   Reply With Quote
Old 12-01-2012, 06:28 PM   #22
LTtaco
LTtaco's Avatar
Tacoma: 2004, Toyota, Tacoma 4x4 3RZ-T
It ended up being the middle red 'ignition' wire on the 3-wire plug going into the alternator. I checked all the fuses and then pulled that section of harness off the truck and started testing for continuity, found ol red to be broken, and with the skillful helping hands of SMCdonn soldered in a replacement ... Charging commenced! However, I believe that there may have been damage done to my IAC motor during the ordeal. I'm still having high idle issues; it's not idling quite as high, but still isn't right. I've checked everywhere for vacuum leaks without any luck. My boost/vac gauge is reading approx 2inches more vacuum at idle than it should, and it's referenced to the little vacuum diaphragm tubing on the side of the throttle body.
LTtaco is offline   Reply With Quote
HIGH OUTPUT ALTERNATOR frgy28 Interior/Audio/Electronics 3 03-07-2013 07:37 AM
High Output Alternator OffroadTRD Interior/Audio/Electronics 9 12-27-2008 09:00 PM
High Output alternator TRDMoneyPit 1995.5 - 2004 5 04-14-2006 07:21 AM
hi-output alternator 97toytaco Interior/Audio/Electronics 6 11-12-2003 07:59 AM
Taco alternator output tacomaofdeath Interior/Audio/Electronics 9 07-28-2003 10:09 AM
