98 Taco odd blinker issue...... - CustomTacos.com Forum
Go Back   CustomTacos.com Forum > The Garage > Interior/Audio/Electronics
Old 11-20-2012, 01:48 PM   #1
rocfrog
Default 98 Taco odd blinker issue......
I have a 98 Taco standard cab short bed 4x4 4cyl manual, and lately I have had a right turn signal issue. Some times it works and other times it does a rapid flash and other times it does nothing. I found out this morning that when it does the rapid flash none out the actual blinkers are actually blinking, along with the inside indicator. I assume that the times that it does nothing it is also doing nothing out side. This is completely random and sometimes corrects itself mid turn.....all the bulbs and fuses are good so I don't know what could be causing this...??? The left turn signal is fine and works just fine it's only the right one.
Nick
rocfrog is offline   Reply With Quote
Old 11-20-2012, 01:55 PM   #2
Hot Sace
Hot Sace's Avatar
Tacoma: *01 S-Runner* and *98 Tacoma*
Default
My 98 did that a couple weeks ago and hasn't done it since. Sounds like a short someplace.
Sent from my iPhone using AutoGuide.com App
"The truck people love to hate"
"Ergo bibamus"
Actual Join Date: Nov. 2005
Hot Sace is offline   Reply With Quote
Old 11-20-2012, 05:30 PM   #3
Mambeau / Admin
Default Re: 98 Taco odd blinker issue......
Originally Posted by rocfrog View Post
... I found out this morning that when it does the rapid flash none out the actual blinkers are actually blinking, along with the inside indicator. I assume that the times that it does nothing it is also doing nothing out side. ...
I can't parse the first sentence, Nick ...
Do you mean that under the rapid flash condition (at the cluster indicator end), none of the external signal lamps are working at all?
Here (attached) is the 1998 turn signal wiring diagram. As you can see, it's a convoluted wiring scheme that has the turn signals and hazard lights tied together.
There might be any number of electrical glitches that could explain these symptoms. That's the problem.
However, I'd start with the combination switch (turn signal switch on the column). A bad electrical connection for the RH signal circuit would explain everything. It might be that the combo switch is bad, or that the wiring leading down the column has been kinked (or whatever ...) causing a transient short or broken connection.
Enola Gaia is offline   Reply With Quote
Old 11-20-2012, 10:18 PM   #4
purplepoison
Veteran
purplepoison's Avatar
Tacoma: 1997, Toyota Tacoma 2.4L L4 Auto, DLX Ext.
Default
If i understood correvtly i had a similar problem with my ucles 2rz it ended up being the flasher had gone bad
Sent from my SGH-T989 using AutoGuide.Com Free App
purplepoison is online now   Reply With Quote
Old 11-21-2012, 08:42 AM   #5
rocfrog
WOW! Sorry didn't realize I had typed that so badly!!!
Yes when it does the "rapid flash" (as if a bulb is out) the inside indicator (in the instrument cluster) and both the front and rear blinkers (on the outside of the truck) do nothing but the you can hear the "flasher" clicking rapidly.
I went thru and checked all the bulbs to make sure they were fine and actually just swapped them out with new ones just in-case, but still nothing. I did notice today that while I was driving if I barely move the turn signal switch (what I assume your referring to as the "combination switch") the blinker seemed to work normal but if I went all the way up it either rapid blinked (the flasher) or did nothing so I'm now thinking it might be the actual switch....
Nick
Old 11-21-2012, 08:59 AM   #6
Mambeau / Admin
Thanks for the clarification. Now I understand the cluster indicator wasn't working either.
It could still be a bad flasher unit, but the fact that switch position affects the behavior seems to point to the combination switch on the column.
Old 11-21-2012, 09:04 AM   #7
purplepoison
Veteran
Default
Id try swapping the flasher $5 piece as opposed to the switch im not sure the price but pretty sure its a lot more then 5bucks
Old 11-21-2012, 09:24 AM   #8
rocfrog
Ya I think on my way home I might pick up a new flasher to give it a try, anyone know exactly where it is located under the dash??
Nick
Old 11-21-2012, 10:17 AM   #9
purplepoison
Veteran
Default
Right above the fuse panel thats insode on the drivers side
Fog Lamp Issue on My 2005 Taco ToyoTacoma2005 Lights / Exterior Electricals 2 05-28-2010 04:55 PM
New (to me) Taco, tire rubbing issue. mtflyfisher 4x4/PreRunner Suspension 1 09-24-2008 04:00 PM
08 TRD offroad taco clutch issue... melon16 2005+ 6 08-05-2008 05:23 AM
03 taco altezza taillight blinker problem sagitarox Lights / Exterior Electricals 2 05-14-2004 09:31 AM
03 taco altezza taillight blinker problem sagitarox Lights / Exterior Electricals 1 05-13-2004 07:37 PM
