2003 taco rear elocker - Page 2 - CustomTacos.com Forum
Go Back   CustomTacos.com Forum > On The Go > Off Road
Old 04-14-2012, 08:07 PM   #11
smee907
Tacoma: 98 Toyota Tacoma 2wd
Default Re: 2003 taco rear elocker
Its been a while since I did it, but I had a 98 with a noisy rear end and pulled it to have the gears inspected. It was a pain to removed the whole thing, and would've been easier if I had the locker (I think) engaged. After I got it out and had the diff checked, the gears turned out to be wearing fine, just noisy. It was kinda weird, but I drove it like that and never had a problem.... Grey wire mod ftw by the way!
smee907 is offline   Reply With Quote
Old 04-25-2012, 11:02 AM   #12
justdifferentials
Supporting Vendor
justdifferentials's Avatar
Did you get it?
JT's Parts & Accessories
509-888-AXLE (2953)
www.justdifferentials.com
www.nitro-gear.com
Toyota Differential & Gearing specialist
justdifferentials is offline   Reply With Quote
Old 11-19-2012, 01:43 PM   #13
DreamMachine
DreamMachine's Avatar
Tacoma: 2003 4x4 Tacoma TRD
Lift one tire off the ground as to alleviate any tension within the gears? There is only one bolt and the rest are nuts on studs. They all secure the locker to the housing. Be sure you got all of the fasteners from the top of the locker off. i just popped mine with a dead blow and it slid out just fine.
If you look at the below picture the actuator is on it's side. The the bottom most hole on the left which is slightly recessed is just to bolt the wiring and shield onto. The one just above it on the left and the two round holes on the right are all fasteners.
DreamMachine is offline   Reply With Quote
complete taco elocker rear end Big Ron Parts and Accessories 6 12-25-2009 04:28 PM
2003 Pre-Runner Steering Wheel Fit a 2003 Taco? SirSteve Interior/Audio/Electronics 1 12-15-2009 09:49 PM
WTB elocker rear end johnnyboy Wanted 1 02-26-2009 12:40 PM
WTB elocker rear end johnnyboy Parts and Accessories 4 02-26-2009 12:38 PM
gears for elocker rear??? cheapest??? PIMPINTACOMA 4x4/PreRunner Suspension 18 03-28-2005 08:17 AM
