Chassis Tech leaf springs INSTALLED!!!!! - Page 3 - Toyota Tacoma Forum
post #21 of 26 (permalink) Old 01-20-2010, 10:19 PM
Quoted: 82 Post(s)
Re: Chassis Tech leaf springs INSTALLED!!!!!
I didn't have my montiros dialed in, now I can see the notch.. on the 2nd picture, just not the first one..
the truck looks baller, I really like those wheels against a white truck..
post #22 of 26 (permalink) Old 11-02-2012, 06:31 PM
i have ordered 3" drop springs from chasis tech and i want to know what shocks can i go with, thanks.
toyotasyndicate is offline
post #23 of 26 (permalink) Old 11-03-2012, 11:35 PM
nancy's Avatar
Quoted: 4 Post(s)
Front or rear?
Sent from my iPhone using Autoguide.com App
nancy is offline
post #24 of 26 (permalink) Old 12-02-2012, 11:31 PM
What kind of the bushings are in the front of the ct leafs? I bought some used ones from someone on here and he had removed all the bushings! He supplied me with new ones but they are all 2 pice like the rear on the stock leafs. I know these are not right for the front as they came with no sleeves and there is slop between the bolt and bushing? Help me please..
20inchtaco is offline
post #25 of 26 (permalink) Old 12-11-2012, 03:53 PM
Beefed Taco's Avatar
Quoted: 19 Post(s)
You need to buy 2 new metal sleeves that fit the 2 piece leaf bushings correctly. And you will probably have to shorten the length of the new sleeves a bit to fit between the leaf hanger on the frame. Your stock bolts (14mm) will fit through the new metal sleeves with some play, so I recommend getting 2 new Standard bolts from the bolt store that fit the sleeves with less play than the stock ones. They'll need to be 5/8" x 4" to fit the diameter of the sleeve and the width of the frame correctly. You'll need to open up the holes to 5/8" on the frame.
I've done a couple CT leaf installs and had to open the holes on the leaf hangers up to accept the new larger diameter bolts. When I returned the truck to stock (put stock leafs back on) I had to weld washers to the leaf hangers to accept the smaller stock bolts.
Pic below shows a set of CT leafs (bottom) and they do have a pressed in front bushing and sleeve. These went on a 96. Someone may have swapped your bushings or they may have even come that way. I think Ct leafs up to 97 had pressed in bushings while 98 & newer had 2 piece like you have. You're missing the sleeves.
Checkout Streetacos on Facebook!
Beefed Taco is offline
post #26 of 26 (permalink) Old 12-11-2012, 05:17 PM
HaVoCX's Avatar
Lookin good sir! Hard work pays off!
HaVoCX is offline
chassis tech 2" drop springs 98GreenTaco 1995.5-2004 7 11-05-2012 03:16 PM
WTB chassis tech leaf spring for 99 taco, anyone??? taco86 Wanted 1 07-28-2009 06:30 PM
Chassis tech leaf springs Part #??? taco90262 1995.5-2004 6 02-26-2009 04:25 PM
Need Chassis Tech Lwrg Leaf By Sat taco on steiroids Wanted 9 11-10-2007 08:45 AM
new fiberglass leaf springs and eibach coil springs installed. ToyComa 1995.5-2004 28 03-07-2004 09:33 PM
