How Do You Change the Fuel Filter on a 2.4L Tacoma? - Toyota Tacoma Forum
post #1 of 2 (permalink) Old 05-10-2011, 06:24 PM Thread Starter
Does anyone have any tips tricks etc. on how to change the fuel filter on a '96 2.4L Ext. Cab Tacoma? The filter is beneath the exhaust manifold, on a bracket bolted to the block and has the EGR pipe around it on the front side and my large hands won't fit between the intake manifold, exhaust manifold and hoses on the back side. I can't even see the filter except by looking through a space in the exhaust manifold. The filter has banjo bolt fittings on both ends and they require two paper thin washers between each fitting and the filter. That's going to be really tough to line up when I can't even see the fittings.
The picture shown in my Haynes guide on how to replace the filter was taken with both the intake and exhaust manifolds removed. There must be some way to do the job without having to remove the manifolds. Any insight on how to get to the filter and change it the easiest way would be very much appreciated.
I would also appreciate hearing from anyone who has had the filter changed by a shop or Toyota dealership as to how much it cost and the name of the shop, if it was a chain, or is in the San Antonio, Texas area.
Thank you!
Yours, Blake
blake77 is offline
post #2 of 2 (permalink) Old 05-10-2011, 07:19 PM
Re: How Do You Change the Fuel Filter on a 2.4L Tacoma?
Disconnect the battery
Take off the gas cap
Loosen the wheel lugs and raise drivers side and set truck on a jack stand
Take drivers side tire off
Look through the wheel well and you can get to the filter through there..
Loosen the ends on the filter before you loosen the bracket holding the filter to
make things easier
tacomaman is offline
05+ fuel filter change rodstone 2005+ 3 02-12-2010 05:23 PM
fuel filter change 03tacoma2rz 1995.5 - 2004 25 11-30-2009 08:25 PM
how often to change fuel filter? tacomaman 1995.5 - 2004 11 04-20-2005 09:30 AM
is it necessary to change the fuel filter? Sauron64 1995.5 - 2004 55 03-14-2004 10:03 AM
No need to change the fuel filter? M5James 1995.5 - 2004 33 01-09-2004 08:35 AM
