No Heat??? - Toyota Tacoma Forum
post #1 of 10 (permalink) Old 12-23-2008, 08:42 AM Thread Starter
No Heat???
Hey Guys,
Have a 93 4Runner that wont push heat through the heater. It is circulating properly and the rig has a new thermostat but just doesn't produce any heat in the cab. Just as background information, the runner has a new head gasket and the previous owner had installed the battery backwards and blew the alternator fuse. (The only thing it blew I believe). Any ideas and suggestions are greatly appreciated as always! Thanks and Merry Christmas!
G3niX is offline
post #2 of 10 (permalink) Old 12-23-2008, 08:47 AM
Quoted: 189 Post(s)
Re: No Heat???
Just so we're clear ... When you say it's 'circulating properly', do you mean the coolant / fluid is circulating, or the fan is circulating air, or both?
post #3 of 10 (permalink) Old 12-23-2008, 08:55 AM
xsvtoyz's Avatar
Re: No Heat???
ok just for starting point there is a heater control valve on the firewall there should be two 1/2 in hoses going to it . are they hot on both sides?? try having a friend move the temp knob and check for cable movement. If it moves check the hoses for heat if it doesn't move the cable try unsnapping the cable and move it manually till both hoses get hot. Thats the basic starting point.
Supercharged Cammed Header 3rz!
xsvtoyz is offline
post #4 of 10 (permalink) Old 12-23-2008, 09:00 AM Thread Starter
Re: No Heat???
Fluid is circulating and the fan comes on, pushing cold air through the vents....
G3niX is offline
post #5 of 10 (permalink) Old 12-23-2008, 09:13 AM
xsvtoyz's Avatar
Re: No Heat???
start here! and let us know what you find!
xsvtoyz is offline
post #6 of 10 (permalink) Old 12-23-2008, 09:17 AM Thread Starter
Re: No Heat???
This control valve is on the engine side of the firewall?
G3niX is offline
post #7 of 10 (permalink) Old 12-23-2008, 09:21 AM
xsvtoyz's Avatar
Re: No Heat???
yes sir . its a small cigarette pack sized black box 2 hoses and a cable running to it. controls the water flow to the heater core.
xsvtoyz is offline
post #8 of 10 (permalink) Old 12-23-2008, 09:22 AM Thread Starter
Re: No Heat???
Got it. Will let you know what that tells me. Appreciate it!
G3niX is offline
post #9 of 10 (permalink) Old 12-23-2008, 11:15 AM Thread Starter
Re: No Heat???
Checked the valve. Lines are both hot and the dash control for the heat's cable is working freely. Only a small amount of warm is coming through though. Changed the relays as well...??
G3niX is offline
post #10 of 10 (permalink) Old 12-23-2008, 03:45 PM
xsvtoyz's Avatar
Re: No Heat???
then it has to be either a clogged heater core or a vent door not opening or closing. usually the cable for that is down near the passengers feet. there is another thread that has the cable routing.
I think it reads "my heater control only turns half way".
xsvtoyz is offline
Heat exchanger? trdtoy Performance 4 10-08-2006 09:20 PM
NBA Fans-Miami Heat DBLCAB2120 Off Topic 39 06-21-2006 08:39 AM
How important is it to mount an amp w/the heat sink vertical? UofATaco Interior/Audio/Electronics 7 01-04-2005 12:24 AM
Is not having a heat shield with headers safe? pssst_huy Performance 7 11-20-2003 12:04 PM
Exhaust header heat wraps? EdQ Performance 5 09-15-2003 12:11 AM
