acid on windshield - Toyota Tacoma Forum
post #1 of 15 (permalink) Old 01-10-2007, 01:39 AM Thread Starter
Stop Staring
amber00dak's Avatar
acid on windshield
a while back a friend of mine who worked in a detail shop showed me how to remove bad water spots on the windshield using a phosphoric acid based wheel and aluminum cleaner. he would spray it on, let it sit for maybe 10-15 seconds and then spray it off. , it worked great. i found some of the phosphoric acid based wheel cleaner in Napa this weekend and picked some up. i decided to try removing the water spots on my old truck. i sprayed the cleaner on, let it sit like 15 seconds and then hosed it off. i then continued to wash the truck and dry it afterwards.
water spots are gone, but there seems to be a haze all over the windshield now. im not sure if it was because of all the minerals in the waterspots being broken down and i didnt rinse them off fast enough, or if the glass somehow got messed up. my friend who originally showed it to me moved away a few years ago and i have lost contact with him, so im not sure what to do right now. im wondering if i should go out and try spraying the windshield down again and see if it gets better or if i should just get some glass polish and try to polish the haze away.
and for the record, when he showed me the process, the window was left crystal clear. this process was done alot for used cars that came in with bad waterspots.
any opinions?
amber00dak is offline
post #2 of 15 (permalink) Old 01-10-2007, 07:17 AM
StevenRedX's Avatar
Re: acid on windshield
When i cleaned up cars at the body shop they showed me a trick of using steel wool to get overspray and waterspots of windows... you would think that it would scratch them but it didn't.. may want to try that.
StevenRedX is offline
post #3 of 15 (permalink) Old 01-10-2007, 07:41 AM
Ramphonic's Avatar
I use a claybar to remove coatings on windshields to stop the blades from chattering. But thats usually rubber residue.
I would not use wheel acid on anything but a bare aluminum rim. The runoff will etch the paint
Ramphonic is offline
post #4 of 15 (permalink) Old 01-10-2007, 07:43 AM
The best thing I have found to clean windshields is to actually machine polish them using a glass polishing compound. Zaino glass cleaner works very well even by hand, but with my Porter Cable 7424, the results are great.
"I contend that for a Nation to Tax itself to prosperity is like a man standing in a bucket and trying to lift himself up by the handle!" ---Winston Churchill
sputnik767 is offline
post #5 of 15 (permalink) Old 01-10-2007, 07:47 AM
[]D [] []D
AFP520's Avatar
Quoted: 5 Post(s)
Something doesn't sound right about acid on anything. Def try rinsing it again, or the polish. Maybe Ray will chime in.
'14 SWP STI
AFP520 is offline
post #6 of 15 (permalink) Old 01-10-2007, 08:43 AM
Nürburgring X-runner
matt's06xrunner's Avatar
I have used this product called "Wink" It is for polishing silver and other metals. Works pretty good.
06 X-runner, URD intake, URD Y-pipe, Long tube headers, Magnaflow, MAF calibrator, URD Short Shifter, Wideband, 18" Electric Fan, tailgate spoiler, blacked out head and tail lights, C2C 1.75"/3" with DJM Notch, tonneau cover.
http://www.cardomain.com/ride/2591211
matt's06xrunner is offline
post #7 of 15 (permalink) Old 01-10-2007, 11:19 AM
Yota Doc
Flamingsushi's Avatar
You might have scored your glass, like that kind of acid on glass graffiti. Dont get that stuff on your paint!
Originally Posted by spyder041 View Post
IT may get a little "leg humperish" around here, but its all good fun
Flamingsushi is offline
post #8 of 15 (permalink) Old 01-10-2007, 01:47 PM
Waxed to Perfection
glassdoc's Avatar
Well personally, I would never use acid on a windshield unless your etching a vin number on it. I've seen too many that had acid rash from where a detailer sprayed the engine components and then power washed leaving the over spray acid enriched water on the windshield. Since you have already did this to your windshield the only thing that comes to mind would be a neutralizer of some sort. Try baking soda mixed with water into an almost runny paste and a soft cloth and scrub the windshield really well. The baking soda may neutralize the acid and polish the damage out. NOTE: Do not use a buffer!!! If that does not work you can order a product called A-MAZ. Do a google search as I do not have the website bookmarked.
I'm proud to have had the privilidge to meet some of the greatest CT'zens in the world. At mini-meets, meet n greets, car shows and TacOberFest. It all started right here..
glassdoc is offline
post #9 of 15 (permalink) Old 01-10-2007, 03:11 PM
George4drV6's Avatar
Use vinegar.
George4drV6 is offline
post #10 of 15 (permalink) Old 01-10-2007, 04:04 PM
Waxed to Perfection
glassdoc's Avatar
Originally Posted by George4drV6 View Post
Use vinegar.
Vinegar is also an acid, but when properly mixed with water is an excellant cleaner.
glassdoc is offline
Windshield Anti-Glare Light??? Lead_Foot Interior/Audio/Electronics 8 06-12-2010 09:14 AM
Crack in windshield Korova Windows / Mirrors / Etc. 9 01-23-2007 11:13 AM
scratched windshield morcheez Windows / Mirrors / Etc. 6 09-30-2006 12:03 PM
Windshield Replacement... Cost? Advice? Proteus503 Windows / Mirrors / Etc. 16 02-01-2006 05:57 PM
Windshield hair line scratches on 05 tacoma 00yota4x4 Windows / Mirrors / Etc. 7 05-05-2005 08:41 PM
HTML code is On
