Emergency Brake Light Won't Turn Off?? - Toyota Tacoma Forum
post #1 of 12 (permalink) Old 12-13-2009, 08:33 AM Thread Starter
apkarian100's Avatar
So my emergency brake light on the gauge cluster of my 04' Tacoma won't turn off. I can even slam the emergency brake down and the light won't turn off. The actual emergency brake engages and disengages fine; it's just the light in the cluster that won't turn off.
Has anyone had this issue before? Does anyone know how to fix it?
Thank You
i cant drive now cuz some fashest pig pulled me ova n made me get my car towd back home cuz he didntt like the lites i have now cuz i spray paintd my lites with clear thru purple spray paint it was cool lookn but not very brite
apkarian100 is offline
post #2 of 12 (permalink) Old 12-13-2009, 08:57 AM
Quoted: 193 Post(s)
Re: Emergency Brake Light Won't Turn Off??
Check your brake fluid level. The brake warning indicator is also triggered by low brake fluid pressure.
post #3 of 12 (permalink) Old 12-13-2009, 09:36 AM
Fatalaczach's Avatar
x2 there is a float level sensor in the brake resivoir. This might even mean you need some brake work done.
88 Toyota Pick up regular cab v6 that wont quit SAS on 35s 5.29's Taco rear On board air home brew sliders, flat bed, and rear bumper
02 Volkswagen GTI 1.8t tinted, drop in K&N, Magnaflow muffler and hi flow cat, HIDs
Fatalaczach is offline
post #4 of 12 (permalink) Old 12-13-2009, 09:55 AM Thread Starter
I just checked the brake fluid level, it's right at the min. line. I go get some brake fluid tomorrow and fill it up, see if that solves thing. If not, I'll let you guys know.
post #5 of 12 (permalink) Old 12-13-2009, 10:10 AM
Supporting Vendor
Also check your front pads. When they wear down to where they need to be replaced the fluid level drops enough to activate the light.
G
Gadget@URD is offline
post #6 of 12 (permalink) Old 12-13-2009, 01:47 PM Thread Starter
Brake pads look fine, must be the low level of the fluid. I will get some more brake fluid.
post #7 of 12 (permalink) Old 12-13-2009, 02:00 PM
TACOMATruckin98's Avatar
check your rear shoes too, the system should not leak any fluid, if the pads are all good you should figure out where you are leaking fluid
TACOMATruckin98 is offline
post #8 of 12 (permalink) Old 12-15-2009, 02:43 PM
indyingdays89's Avatar
Thank You
this happens to me in the winter only...
when its cold the light is on then it goes away then it comes back...
when its 70+ the light never goes on....
NiteLife Designs3
indyingdays89 is offline
post #9 of 12 (permalink) Old 12-15-2009, 03:47 PM
sickboy23's Avatar
I had that problem everything wasgood on my truck fluid pads etc. I ended up pulling my gauges out and tookthe bulb out
sickboy23 is offline
post #10 of 12 (permalink) Old 12-15-2009, 07:36 PM
if the fluid level is good then it is probably the Differential Pressure Sensor which senses a difference in pressure between the primary and secondary brake hydraulic systems, aka you need a master cylinder most likely
Brake Light Issue... tah 1995.5 - 2004 11 01-20-2009 04:14 PM
1999 Taco: Brake Light Comes On Intermittently turn1 Interior/Audio/Electronics 5 02-24-2006 07:17 PM
Brake light issue... P.P.F 1995.5 - 2004 4 10-26-2004 04:42 AM
Turn Signal Mod xxxxxBazzy Exterior/Body 19 09-21-2004 12:06 AM
disconnecting the stupid brake light? v8only Interior/Audio/Electronics 15 04-06-2004 11:08 PM
