2004 radio removal - Toyota Tacoma Forum
post #1 of 9 (permalink) Old 11-12-2007, 09:35 AM Thread Starter
2004 radio removal
can i be directed as to how to remove my factor radio out a 2004 toyota xtracab?
MikeNeufeld is offline
post #2 of 9 (permalink) Old 11-12-2007, 09:43 AM
tylerangle1990's Avatar
Re: 2004 radio removal
refer to the tech section....here: http://www.customtacos.com/tech/
and find the dash take apart instructions here: http://www.customtacos.com/tech/index.php?article=77
It's pretty simple but theres a lot of plastic stuff so just take it slow and be careful
The taco is back and on the boost!
tylerangle1990 is offline
post #3 of 9 (permalink) Old 11-12-2007, 10:00 AM
Quoted: 198 Post(s)
Check the first page in this 2003 dash removal chapter (attached) ...
post #4 of 9 (permalink) Old 11-18-2007, 03:24 PM
i am trying the same, to remove the stereo of my Tacoma 2004, and i printed and followed all the instructions from the tech section. however i'm stuck now.
step #3 says "Remove ashtray and remove the phillips head screw on upper right side". im assuming the screw is inside the slot where the ashtray was, but there are too screws there. since the instructions are *VERY* detailed, im afraid i might be removing stuff i shouldnt.
also, it seems that the console below the dash, where there are two other lighters and the "toyota security", this console seems to be holding the dash, but the tech section doesnt say if i should remove that either (there are no screws!).
i need to find someone that went through all this, because these questions are not in the tech section....
rafaelfigueira is offline
post #5 of 9 (permalink) Old 11-18-2007, 04:17 PM
Ok, I did this to my '03 about 3 years ago, but this is what I remember from it:
I just checked the ashtray area, and there are two screws that hold the ashtray mounting frame to the black trim. Both of them will need to be removed.
You are correct that the console below the dash is holding the black trim in place. There are 2 plastic anchor things on each side of the console, close to the back. Once you remove those, the console can be moved out of the way to reveal a 3rd screw that holds the plastic trim in place. Those pins that hold the console are technically single use, but it is possible to remove them without breaking them. I actually never put them back because they are a pain to remove again should the need arise, and really not necessary anyway.
"I contend that for a Nation to Tax itself to prosperity is like a man standing in a bucket and trying to lift himself up by the handle!" ---Winston Churchill
sputnik767 is offline
post #6 of 9 (permalink) Old 11-18-2007, 11:40 PM
you are absolutely right. this is the step that is missing in the tech section: removing the console below is a must, and reveals a 3rd screw, then the trim goes.
in my case i didnt need to remove the two screws of the ashtray, i just needed to pull the stereo a little bit and connect the TOYAUX. everything is back together, and working nicely.
post #7 of 9 (permalink) Old 06-13-2013, 09:47 AM
Quoted: 198 Post(s)
The MIA Tech article on 1995.5 - 2004 dash take-apart instructions has been salvaged and re-posted as a new reference thread within Interior:
'95.5 - '04 Dash Take-Apart Instructions (TECH SALVAGE)
post #8 of 9 (permalink) Old 12-28-2014, 06:01 PM
2k4 Tacoma's Avatar
Quoted: 17 Post(s)
Question Re: 2004 radio removal
Huh....
Was looking @ my Tacoma, trying to figure out how to remove the center bezel....
Looks like I have to "move" the lower shifter base[& cup holder assembly] to access the lower screws around the "ash-tray"
Right?
My HVAC uses all knobs- I still have to pull these & gently remove the HAVC faceplate too?
2k4 Tacoma is offline
post #9 of 9 (permalink) Old 12-31-2014, 07:31 AM
Quoted: 198 Post(s)
(1) Sorry for the delay - I somehow missed this thread's arrival over the weekend ...
(2) You shouldn't have to do anything with the shifter base trim thingie. There's a 'Lower Center Cover' at the bottom of the center bezel which has 2 clips holding it in place. Remove the clips and this Lower Center Cover.
Next - remove the HVAC knobs and pry / pull out the heater control panel.
Now remove the 3 screws holding the bezel (Center Cluster Finish Panel) and pull it out.
Disconnect the cigarette lighter / ashtray lamp, and the bezel should be free.
2004 DASH REMOVAL ??HELP! TacoInProgress Interior/Audio/Electronics 4 07-10-2013 07:35 AM
01 radio removal Mr Tode Interior/Audio/Electronics 6 06-13-2013 09:46 AM
2004 Tacoma Door Panel removal Madmardagan Interior/Audio/Electronics 13 09-15-2007 07:28 AM
Radio Trim Removal 03 DC audipartsman Interior/Audio/Electronics 1 05-01-2004 03:11 PM
Truck OEM Radio problems (2004) Acidpain Interior/Audio/Electronics 2 02-02-2004 12:43 PM
