loosening torsion bars (PreTaco) - Toyota Tacoma Forum
post #1 of 12 (permalink) Old 11-21-2005, 02:31 PM Thread Starter
sitnlow4life's Avatar
Question loosening torsion bars (PreTaco)
Please help
I tried to lower my truck by lossening the torrions.
There are 2 nuts on the bolt for some reason I can nto get either of them loose.
I need to break them free to be able to loosen the torrisions
Correct?
Any Ideas?
Suggestions?
Please Help
sitnlow4life is offline
post #2 of 12 (permalink) Old 11-21-2005, 03:52 PM
Re: loosening torrisions
Correct, one of the bolts acts as a locking bolt for the other. Should be the top bolt if I remember right. Soak them in wd-40 or something similar if you are having problems. But be sure to make the same amount of turns on each side. Also measure the distance from the tire to the fender on each side to make sure it's level. Then tighten the locking nut back up. Get an alignment ASAP. Also if it rides rough, remove/replace/trim down your front bumpstops. Also remember you won't have as much suspension travel so you will have a rougher ride due to that.
IdahoPU is offline
post #3 of 12 (permalink) Old 11-29-2005, 09:56 PM Thread Starter
I still having a problem with this.
Those damn nuts wont break loose.
Also could I just flip my ball joints?
That would give me a 3in drop right?
Do I need a kit to do this?
What are the disavantges to doing a ball joint flip.
Thanks Again
post #4 of 12 (permalink) Old 11-29-2005, 09:59 PM
ChrisTaco's Avatar
Thanks Again
Get some new spindles to drop it, then crank down your torsions. Guarantee your ride will be alot better. Let the wd-40 or some penetrating oil sit for a while before you try to bust the bolts loose.
Alignment and some new shocks too, OEM shocks won't cut it and will blow.
ChrisTaco is offline
post #5 of 12 (permalink) Old 11-29-2005, 10:17 PM Thread Starter
Sorry I did not mention thsi earlier I already have drop spindles and drop shocks all the way around
post #6 of 12 (permalink) Old 12-01-2005, 08:11 AM Thread Starter
Bump
Anyone?
post #7 of 12 (permalink) Old 12-01-2005, 08:59 AM
vtechthis's Avatar
when i had my pretaco i hosed those nuts down with liquid wrench and then broke them loose. i didnt have a spindle but i bought sway away power bars and then ground off 2 of the splines and rotated the bars so it would drop the truck so i didnt have to have my adjusters super loose. i didnt run any bumps and i had toxic shocks. truck sat so low. i only had 15s but the frame sat about 2 1/2 off the ground. and it rode a bit stiff but it was a sporty stiff. handled amazing
vtechthis is offline
post #8 of 12 (permalink) Old 12-01-2005, 09:28 AM
ChrisTaco's Avatar
Bump
Anyone?
Nothing else to really tell you bro. You're gonna have to get em loose one way or another. I'd just use some more pentrating oil and take an impact to it to get em loose then.
post #9 of 12 (permalink) Old 12-01-2005, 12:05 PM Thread Starter
How about the ball joint flip idea?
What you think?
Which will give me better alignment?
If I flip the ball joints will have have to change them back when I bag it?
Thanks again
post #10 of 12 (permalink) Old 12-01-2005, 08:54 PM
nator's Avatar
Hey I read your specs and like a lot, post up some pics please.
As for the torsions i payed to get mine droped was like 50$ and then i put some Beltech Nitros and it rides stiff but I can live with it.
______________________________________________
Sex is like fishing, when it's good it's really good
and when it's bad it's still pretty good!!!
nator is offline
PreTACO front lowering w/ torsion bar? peterpoop 2wd Suspension 18 11-11-2006 01:54 AM
how do i drop a 89 yota with torsion bars? TrailerParkPimp 2wd Suspension 5 06-02-2006 08:41 PM
Front end lift on torsion bars 91hiLux 4x4/PreRunner Suspension 2 09-13-2005 09:37 PM
torsion baRS chimmychonga 2wd Suspension 3 05-01-2005 12:20 PM
SwayAWay Torsion Bars xxroderigoxx Performance 3 01-04-2005 10:03 AM
