Rear Differential gear oil leaking thru the inside of the drums - Toyota Tacoma Forum
post #1 of 10 (permalink) Old 03-16-2009, 08:16 AM Thread Starter
Angry Rear Differential gear oil leaking thru the inside of the drums
Hy I have this problem for awhile is the my 2001 Taco prerunner 2wd is leaking the gear oil thru the inside of the drums, I have change in several times all of the oil seals, bearings, the big o ring and the breather valve and the last time I did all that I dissemble booth axel and took them to the machine shop and have tested to see if they wear bend but thy are perfect and she still doing the same SHTTTTT. Is something frustrated please HELLLLLPPPPPPP
alexover69 is offline
post #2 of 10 (permalink) Old 03-16-2009, 08:28 AM
Quoted: 199 Post(s)
Re: Rear Differential gear oil leaking thru the inside of the drums
(1) Welcome to CT! ...
(2) Have you done any modifications to the differential / rear axle, or is it totally stock?
(3) Do you happen to have the electric locking differential, or do you have the stock 'open' differential?
post #3 of 10 (permalink) Old 03-16-2009, 08:57 AM Thread Starter
1) Ty for the welcome
2) no modification to diff. is totally stock
3) and yes i have the electric locking differential
post #4 of 10 (permalink) Old 03-16-2009, 09:09 AM
Quoted: 199 Post(s)
Just so we're clear ...
When you had the oil seals / bearings / etc. checked before (multiple times), this included inspection of the center 'pumpkin' / e-locker unit as well ... Right?
post #5 of 10 (permalink) Old 03-16-2009, 09:19 AM
Quoted: 199 Post(s)
I have a possible theory ...
According to the parts listings I can access, the bearings and oil seals for a 2001 PreRunner are different for a non-locker versus a locker.
This is entirely understandable, because the e-locker unit is based on a totally different differential (the older, so-called 'V6 / Turbo') from the non-locker PreRunners (which have the later so-called '8.4' unit).
Could it be that the wrong oil seals / bearings / etc. have been installed, and that's what's causing the leakage?
post #6 of 10 (permalink) Old 03-16-2009, 09:27 AM Thread Starter
Well i have buy all the parts form my local toyota dealer all genuine"original parts" useing the vin # from my taco and yes (multiple times), this included inspection of the center 'pumpkin' / e-locker unit as well
post #7 of 10 (permalink) Old 03-16-2009, 09:33 AM
Quoted: 199 Post(s)
The VIN number wouldn't indicate the presence of the e-locker (which was an option). If all they used was the VIN number, they may have ordered parts for the 'regular' (non-locker) PreRunner with the '8.4' instead of the peculiar e-locker unit.
They *might* have been able to tell the difference if they went so far as to ask you for the axle code ...
I don't know that this is the cause, but it certainly explains everything - especially why it never seems to get 'fixed' no matter how many times you dig into it ...
post #8 of 10 (permalink) Old 03-16-2009, 11:16 AM
pimpRunner's Avatar
any possibility of wrong fluid, damage to seal surface(not warp but scuffing etc) or a clogged breather line?
I plead the 5th, unless copping to the crime is of my benefit...
pimpRunner is offline
post #9 of 10 (permalink) Old 03-17-2009, 07:31 AM
Supporting Vendor
What you are having is not that uncommon at all. The axle seal design is not the best on these trucks.
I have two 4Runners and one has CHRONIC axle seal leaks and the other never ever leaks.
Then next thing I am going to try is to get a used axle assembly from the junkyard and put my 3rd member in it.
One thing I did was drill a very small hole in the bottom of the axle housing between the axle seal and the bearing so it will leak out of the hole instead of through the bearing and brakes.
It is a very annoying problem indeed.
Gadget
Gadget@URD is offline
post #10 of 10 (permalink) Old 03-17-2009, 03:59 PM
Aldo's Avatar
Was the axle perhaps over filled with oil?
Aldo is offline
Why Oil Prices Are So High!!! WHAT HAPPENED Off Topic 36 04-30-2008 03:59 PM
Oil Change for Men and Women Dropitmore Off Topic 10 08-24-2007 07:26 PM
Leaking oil between drive shaft and differential S-Dad 1995.5 - 2004 15 06-28-2006 06:38 PM
Rear Axle Oil Seals keep failing MountainBiker 1995.5 - 2004 3 10-15-2004 08:43 AM
rear differential oil change? SRakaSSS 1995.5 - 2004 8 08-31-2004 08:31 AM
