5 lug tacoma rear diff lsd or locker??? - Toyota Tacoma Forum
post #1 of 11 (permalink) Old 05-05-2007, 09:28 PM Thread Starter
My friend is looking for an lsd setup for his 02 tacoma 2wd 5 lug truck. Im pretty sure its a 7.5., where do u find them at?
SAyota is offline
post #2 of 11 (permalink) Old 05-05-2007, 09:37 PM
Re: 5 lug tacoma rear diff lsd or locker???
You can try randy's ring and pinion .
footinmouth is offline
post #3 of 11 (permalink) Old 12-11-2010, 09:46 PM
Hey I'm new to tacos I have a 1990 v6 single longbed 1ton 5 lug 5 speed what stock lsd diff can I use. Any idea what size diff I have. I may just spool one up and keep my og for a spare
silkyimpala is offline
post #4 of 11 (permalink) Old 12-11-2010, 10:38 PM
h2oplaydamian's Avatar
I hear that you can use the older supra LSD rear ends just a swap
SHERIFF JOE ARPAIO FOR PRESIDENT !
h2oplaydamian is offline
post #5 of 11 (permalink) Old 12-12-2010, 07:23 AM
Quoted: 198 Post(s)
1989 - 1995 'PreTaco' V6's were normally fitted with the so-called 'V6 / Turbo' rear differential unit.
This is a different unit from the so-called '7.5' found in 4-cylinder PreTacos and 1995.5 - 2004 Tacos. It is also a totally different 'species' from the so-called '8.4' rear end used in 1995.5 - 2004 V6 Tacos.
The 'V6 / Turbo' unit was the basis for the factory e-locker unit available as an option or as part of the TRD Off Road Package. This is the only form in which the 'V6 / Turbo' unit appeared on 1995.5 - 2004 Tacos. This unit continued to be used on 4Runners after 1995.5.
It would be a good idea to check your specifications sticker (plate, whatever) and report the axle code you should find there. There are two reasons for this:
(1) There are known instances of V6 PreTacos which came from the factory with the '7.5' rear end.
(2) Certain 'V6 / Turbo' units were specifically configured for 4.88 gears, and these units cannot be regeared with aftermarket gears designed for non-4.88 V6 / Turbo units.
post #6 of 11 (permalink) Old 12-12-2010, 09:21 AM
Firdaddy's Avatar
Quoted: 12 Post(s)
you have to shave 1/2'' off each axle to do this
dumpted since 2/15/08 MMMMMM boos t
Firdaddy is offline
post #7 of 11 (permalink) Old 12-12-2010, 02:00 PM
Axle codes is that in the door jam
post #8 of 11 (permalink) Old 12-12-2010, 02:08 PM
I'm at pick in pull now and I see a third member with a sensor on it is it the taction controll or speed sensor. What third member should. I look for?
post #9 of 11 (permalink) Old 12-15-2010, 10:26 AM
Tacorvette enthusiast
Speed sensor is in the transmission not the rearend...you may be looking at a locker style from a Pre-runner if it has a motor hanging off the side of the diff with a connector plug on it..
BOOST BRIGADE I fabricate custom parts: HEIM STYLE STRUT RODS, FORWARD FACING INTAKE MANIFOLDS, and TRACTION BARS (5 LUG) contact me for more info @ www.Speed-freek.com or just PM me here THANKS!
Former Lexus / Toyota tech
post #10 of 11 (permalink) Old 12-15-2010, 04:37 PM
ZIP
ZIP's Avatar
Quoted: 49 Post(s)
Speaking of E-lockers..you might want to consider that as an option. Here's a link describing what you would need to modify to make it fit.
http://carterswebsite.com/4runner/mods/locker/
I've done it before, and its really not too difficult. I'd recommend pulling it from a Pre-Runner, complete with rear wiring harness and diff-lock ECU with connectors. Or at least the diff-lock ECUwith connectors and the pig-tail that goes to the diff.
The speed sensor on top of the diff housing was used on vehicles with Rear ABS. ..nothing special..
Another note: Although a factory locker was not available on pre Tacos in the US market, other markets such as Australia had factory LSDs in their "Hilux" utes. Don't know how much of a pain that would be to source.
I guess it depends on what you're planning to do with your truck
ZIP is offline
4wd brothers va burnt taco Off Road 19 01-03-2008 09:57 AM
05 Tacoma TRD Off Road Struts Shocks & Rear Springs va beach taco Parts and Accessories 24 05-11-2007 02:50 PM
Rear diff isnt locking brad171 Performance 4 04-03-2007 08:42 PM
Rear diff for 96 Tacoma Tacaino 1995.5 - 2004 18 03-15-2007 09:40 PM
Tacoma 96 rear differential Tacaino 4x4/PreRunner Wheels and Tires 2 03-14-2007 08:48 AM
