New Aluminum Radiator Install - Page 3 - Toyota Tacoma Forum
post #21 of 57 (permalink) Old 02-26-2013, 04:38 PM Thread Starter
tacomatic1's Avatar
Quoted: 7 Post(s)
Re: New Aluminum Radiator Install
haha. it doesn't GIVE me any power but it can facilitate cooler combustion temps which in turn can support more power.
tacomatic1 is offline
post #22 of 57 (permalink) Old 02-27-2013, 10:55 AM
Quoted: 28 Post(s)
. It actually looks nice, does the top sit higher than stock or am I imagining that?
-gmc
garetcurry is offline
post #23 of 57 (permalink) Old 02-27-2013, 11:32 AM
HaVoCX's Avatar
+1, lookin good. Top fitment ok??
HaVoCX is offline
post #24 of 57 (permalink) Old 02-27-2013, 12:23 PM Thread Starter
tacomatic1's Avatar
Quoted: 7 Post(s)
Yeah the top fits okay. The top of the core actually sits a little lower than stock. I had a lot of room to play, I could have lowered it much more but it would have been hard to get a radiator cap on, wanted the neck to sit above the core support.
post #25 of 57 (permalink) Old 02-27-2013, 06:29 PM
Originally Posted by tacomatic1 View Post
Precision 6262 turbo, 600cc injectors, walbro 255 lph fuel pump, megasquirt II diypnp, snow performance stage 2 methanol injection, LC-1 wideband, trutrac lsd, stage 5 competition clutch, fidanza aluminum 11lb flywheel
That s a really nice set up. What kind of power are you putting down?
Any changes seen in engine temps?
GRILLCRAFT is offline
post #26 of 57 (permalink) Old 02-28-2013, 10:23 AM
Tacorvette enthusiast
Looks really good in there!
BTW, I slanted my coilpacks back a little bit so it cleared the intake tube better, since it exits so close to the plug wires.
Man I miss my turbo, that thing was a monster. Even with a V8 I still really miss it, cant wait to have a V8 AND turbo..then the monster will be back.
BOOST BRIGADE I fabricate custom parts: HEIM STYLE STRUT RODS, FORWARD FACING INTAKE MANIFOLDS, and TRACTION BARS (5 LUG) contact me for more info @ www.Speed-freek.com or just PM me here THANKS!
Former Lexus / Toyota tech
post #27 of 57 (permalink) Old 03-02-2013, 06:52 PM Thread Starter
tacomatic1's Avatar
Quoted: 7 Post(s)
I will look into slanting the coil packs. Here are some more pics...I finished the wiring for the fan thermostat and filled her up, runs great!! I am not running a relay, simple setup.
I put the fan thermostat in the inlet hose using a manifold that was tapped. It works well.
Battery -> Fusible Link -> T-stat
Fan motor (-) back to battery (-) / Gnd. [Red 10ga wire]
T-stat -> Fan (+) and Fan (-) to battery (-) [ Two wires you see there ]
post #28 of 57 (permalink) Old 03-03-2013, 11:29 AM
Run a relay or you will burn up your thermostat from the load, especially during fan startup, Trust me, it will eventually burn up if the thermostat isnt designed to handle the amperage load (the only ones that are have an integrated relay built in for this reason)
Careful or the thermostat might fail (and certainly will without a power relay), the fan will stop, and the truck could overheat quickly if your not watching your gauge, which we arent 100% of the time, bad things could occur.
ADD A RELAY, or you will be sorry, and if your thermostat has one built in disregard, I just couldnt see the thermostat so I dont know what your using.
Just lookin out, I dont want to see something get damaged that could be prevented. It looks really nice though, I really gotta do that to mine, would like to have a more efficient radiator with my motor especially when it goes turbo, that really gonna send some heat into the motor...
post #29 of 57 (permalink) Old 03-10-2013, 06:53 PM
MatosTaco's Avatar
Quoted: 29 Post(s)
You post about how you want to turbo that thing every chance you get lol. Get it done man! I want to drool over the pictures
QA1 First 100 club "Clone me out cah me nah poppy show"
MatosTaco is offline
post #30 of 57 (permalink) Old 03-10-2013, 08:15 PM
Quoted: 76 Post(s)
It's lookin sexy! Bolted right in?
I have the diypnp too,.did you do the launch control and boost control?
I have the wire coming from the ecu for the flex-fuel sensor for that in the future too..
Aluminum Radiator Josh Taco Performance 20 03-02-2012 02:49 AM
Aluminum Radiator & Electric Fan Kit 95-04 Taco CUSTOEM Performance 6 11-07-2010 03:38 PM
NICE Aluminum Radiator 02KingTaco Parts and Accessories 12 12-04-2009 11:16 AM
22re Aluminum Radiator (2 Row) TRD2.4Tacoma Parts and Accessories 15 01-30-2008 10:39 AM
aluminum radiator? CelicaDRIFTER Performance 2 05-02-2006 04:59 AM
