Any stronger option for Tacoma V6 R150 Transfer Case swaps?? - Toyota Tacoma Forum
post #1 of 37 (permalink) Old 01-09-2013, 03:30 AM Thread Starter
I have a 1998 4x4 TRD Off Road Tacoma 5 Speed model I have swapped a twin turbo 2JZGTE engine into it. The engine will be delivering around 500 wheel horsepower and a enormous amount of torque. The weakest link in my power train is the chain driven transfercase. Any stronger transfercase anyone found for the Tacomas?
I know on the earlier model trucks that have the front diff on passenger side can have the bullet proof gear driven 4 cylinder tranfercase adapted on the earlier V6 transmissions but that doesn't do me any good since I need the transfercase that kicks off on the drivers side. Are the 4 cylinder Tacoma transfercases a similar tough design like the 1980s 22RE W56 gear drive T-cases? Any suggestion for beefing up my T-case or swapping on one would be appreciated.
1991Supercharged is offline
post #2 of 37 (permalink) Old 01-09-2013, 06:59 AM
Quoted: 193 Post(s)
Re: Any stronger option for Tacoma V6 R150 Transfer Case swaps??
Interesting question ...
I don't remember anyone bringing this subject up before ...
post #3 of 37 (permalink) Old 01-09-2013, 07:05 AM
Quoted: 193 Post(s)
According to the 2000 FSM all transfer assemblies (5VZ / 3RZ; manual / auto) use a chain. Here (attached) is the relevant components diagram ...
post #4 of 37 (permalink) Old 01-09-2013, 07:17 AM
Quoted: 193 Post(s)
Check Marlin Crawler. At one time they offered a kit for transplanting an earlier gear-driven transfer unit into a later Toyota truck / SUV with the chain drive unit.
post #5 of 37 (permalink) Old 01-09-2013, 10:07 AM
Greg_Canada's Avatar
Quoted: 28 Post(s)
What is wrong with the chain driven transfer case?
I'd be looking into axles before the tcase...
Greg_Canada is offline
post #6 of 37 (permalink) Old 01-09-2013, 02:11 PM Thread Starter
From what I have been told many times over the years the V6 chain drive transfercases are not nearly as strong as the 4 cylinder gear drive transfercases used back in the 1980s. Most guys swapping in a small block V8s and decide to use a Toyota transfercase mated to the Chevy or ford tranny use a 4 cylinder gear drive T-case. Guess the chains are prone to breaking or slipping under extreme power and or torque.
I'm pretty sure the Tacoma axles are fine. As most of you know they are pretty over built to begin with. The front end my be the next weak link. If all else fails and I can find a suitable T-Case upgrade to drive the front drive shaft on the driver side of the truck like in the Tacomas. Might just do a SAS on the Tacoma to get a stronger front end and be able to adapt the 1980s 4cylidner T-Case on which will have the drive shaft running up the passenger side. Don't really want to SAS the truck since it does handle, ride & steers much better with the Tacoma independent rack n pinion front end. If I was planning on hard off roading or mud bogging them a SAS would be a planned upgrade for sure.
Here is a link to a photo album of the build I did.
http://s1140.photobucket.com/albums/...peed%20Tacoma/
Ignor this image below. Pasted the wrong code in and now this wont go away!!!!
post #7 of 37 (permalink) Old 01-09-2013, 09:17 PM
HaVoCX's Avatar
Holy ****. Im in the same god damn scenario. got the R151 Tranny sittin in the garage with beefed up older T-case and my buddy just told me "drive shaft is on the other side buddy" doh..
But then he suggested the SAS that would go straight in to the R151 Tranny and older style transfer case....I didnt want to sacrifice driveability too sooo im kinda looking what to do next as well. And i will do something... just dont know what yet. Making it fast AND strong.
HaVoCX is offline
post #8 of 37 (permalink) Old 01-10-2013, 09:48 AM
Quoted: 28 Post(s)
everyone says that it's weaker, but i have YET to see or hear of a broken chain drive t-case in my 10 years of surfing the web (lol)...
I would leave it alone unless something happens. However, if you want to spend needless monies, give marlin crawler a call, they will help you out.
The guys used the 4-cyl t-case because it's VERY easy to add a reduction box / new gears (chain drive reduction boxed came out in the last 5 years or so)... and most of the people doing v8 swaps had a 4cyl in it's place before, so they re-used the parts they have. Nothing wrong with the gear driven cases, but you would have to do the 23 spline upgrade, (stock is 21) because your gear drive t-case is 23 spline (stronger).
post #9 of 37 (permalink) Old 01-10-2013, 09:58 AM
Texas_Ace's Avatar
Quoted: 89 Post(s)
What he said, I would not worry about it unless what you have breaks.
I beat the heck out of my stock t-case with a supercharged V6 making ~300hp and a ton of torque. AWD launches from every stop light, which would light up the front tires. Never had a problem.
Although the lack of an LSD in the t-case does mean that AWD mode with high HP is not as effective as it could be due to it lighting up the front tires. In 4wd mode though it launched amazing but turning on the road was not really an option. lol
2000 Toyota 4runner Limited 3.4l V6 Auto SUPERCHARGED, Meth injection, 2.0" Pulley, Doug Thorley Headers - My truck - My Youtube with lots more
Member of the "No BOV Club"
Texas_Ace is offline
post #10 of 37 (permalink) Old 01-10-2013, 10:56 AM
HaVoCX's Avatar
if anyone can point me in the direction for a 2TR-FE bellhousing i would be much appreciated.
Also, in regards to chain vs gears.. I think that the concept of "if it aint broke dont fix it". That was a good point stated earlier. Especially if were not finding any examples of the chain style giving out elsewhere.
Hmm.. guess i can just hold on to the R151F T-case for a future SAS swap, or try and sell it...
HaVoCX is offline
1996 Tacoma Transfer Case taco33 Parts and Accessories 0 01-19-2011 01:02 AM
05+ Tacoma transfer case... ltw9r Parts and Accessories 2 01-27-2010 01:21 PM
Bumper swaps that arent from a Toyota (Mazda/Nissan/Chevy swaps) Chris D. Body / Structural 6 01-14-2008 02:12 PM
Ipod integration option for tacoma double cab 07? pk5 Interior/Audio/Electronics 10 05-02-2007 07:21 PM
Sunroof an option on 05-07 Tacoma? Tillers_Rule Off Topic 1 02-25-2007 05:27 PM
