Lean WOT - good at half throttle (Boosted) - Page 7 - Toyota Tacoma Forum
post #61 of 67 (permalink) Old 01-07-2013, 04:52 PM
cold eh
flatboy's Avatar
Re: Lean WOT - good at half throttle (Boosted)
On the scan gauge I know my 2000 4 runner with the 3.4L won't read A/F but I haven't tried my taco as its still winter here.
BOOST BRIGADE
Friends don't let friends drive stock.
2000 Tacoma @15psi, (13.8@100mph @ 9psi)
2000 4 Runner @7 psi rear mount
flatboy is offline
post #62 of 67 (permalink) Old 05-19-2014, 07:27 AM
ok thread jack everyone...ive got a similar problem. boosted 2rz on 15lbs with 450cc injectors 255 fuel pump. Driving around at low throttle is fine but as soon as i try WOT right at 3k rpms it leans out like crazy and sputters terribly....is this an o2 sensor problem? i have no obd2 port to check with so any way to check with a multimeter would be helpful....thanks in advanvce
crijonRa29 is offline
post #63 of 67 (permalink) Old 05-19-2014, 07:35 AM
toycoma98's Avatar
Quoted: 4 Post(s)
its probably still in closed loop when you're WOT boost.. I use a URD o2 calibrator in my setup.
toycoma98 is offline
post #64 of 67 (permalink) Old 05-19-2014, 08:01 AM
So is it an o2 problem
post #65 of 67 (permalink) Old 05-20-2014, 12:10 AM Thread Starter
blackedout_taco_stidham's Avatar
i think it has something to do with the factory ECM not kicking into open loop fast enough. Mine does it too. So i tend roll into it more than just punch it...kinda sucks, but ill be installing the AEM FIC soon, along with 1000cc injectors...so hopefully no more lean conditions for me.
I like Toyotas.
blackedout_taco_stidham is offline
post #66 of 67 (permalink) Old 05-20-2014, 05:00 AM
lastresort's Avatar
Quoted: 20 Post(s)
When the ecu is in closed loop it is maintaining the afr closely based on the input from the o2 sensor. If you add some sort of piggy back you can alter the o2 signal and in effect trick the ecu to add fuel. When the ecu goes into open loop it no longer cares about the o2 signal and if your running larger injectors your afrs are often adequate.
BOOSTED 2RZ
W58 w/Stage 4 clutch and Fidanza flywheel
Ford 8.8 3.73 LSD with discs and parking brake in process
lastresort is offline
post #67 of 67 (permalink) Old 05-20-2014, 07:08 AM
toycoma98's Avatar
Quoted: 4 Post(s)
But it wont "ADD" fuel, more like allowing fuel to be added by maf signal naturally without o2 signal (closed loop), or a piggyback to increase voltage to the maf sensor making AFR richer.
two issues lofting lean condition at 1/4 throttle and 4x4 actuator mark2002double Performance 5 12-29-2005 08:05 PM
throttle body opening half way troymm Performance 10 06-13-2005 06:38 AM
Half red half clear tailights for 98 4x4 PGD55 Lights / Exterior Electricals 9 11-02-2003 04:41 PM
does the throttle cable trick work good? life Performance 3 09-13-2003 07:27 PM
SR: 'Taco Lean' (Noticeable 'Lean' / 'Tilt' to One Side) hschen S-Runner Talk 5 10-01-2002 10:17 AM
