Lean WOT - good at half throttle (Boosted) - Page 6 - Toyota Tacoma Forum
post #51 of 67 (permalink) Old 01-06-2013, 08:17 AM Thread Starter
blackedout_taco_stidham's Avatar
Re: Lean WOT - good at half throttle (Boosted)
Originally Posted by Yodaforce View Post
Say you have a Mountain Dew. If you pour just a little bit of it in a glass, it's still the same Mountain Dew in the glass than in the bottle.
But I prefer Sundrop...
I got you man, I'm not tryin to argue, I was just trying to eliminate the possibility of my theory (does that make sense)
I guess I will just have to wait until I get put these bigger injectors in and go standalone as well...
I like Toyotas.
blackedout_taco_stidham is offline
post #52 of 67 (permalink) Old 01-06-2013, 12:24 PM
Quoted: 82 Post(s)
Why the extra plumbing? Why not just "Y" it into the exhaust?
If it's all straight pipe, it'll sound about the same.
This wouldn't effect your AFR's tho..
Looks like they did a nice job on it..
Originally Posted by blackedout_taco_stidham View Post
post #53 of 67 (permalink) Old 01-06-2013, 12:36 PM Thread Starter
Well the "goal" was to have the 3 inch pipe muffled like stock...well close to stock while still being free flowing and keep the wastegate wide open. I also wanted them to come all the way out the back, or the side in front of the rear wheel...so this is a temp just to get some exhaust out from directly under the cab/bed...it was bad, turning everything black. Now it directs it at the ground directly under the axle...this isn't permanent.
I like Toyotas.
post #54 of 67 (permalink) Old 01-06-2013, 05:08 PM
tacomatic1's Avatar
Quoted: 7 Post(s)
where did you find that info? is it in a wiring diagram?
i might be but all narrowband signals are 0-1v. if you have a scangauge you can verify this also
tacomatic1 is offline
post #55 of 67 (permalink) Old 01-06-2013, 05:09 PM Thread Starter
how so? i do have a scangauge...
I like Toyotas.
post #56 of 67 (permalink) Old 01-06-2013, 09:00 PM
tacomatic1's Avatar
Quoted: 7 Post(s)
it should read 0-110 afr which is 0-1.1v
post #57 of 67 (permalink) Old 01-06-2013, 09:18 PM Thread Starter
mine just stays at 14.5 AFR...since its narrow band and all...i looked at the scangauge website for an added X Gauge feature for what you are talking about and i have already entered those values and i just get stock cruising ratio all the time since its such a low resolution system (a/f ratio system not OBD II).
do you have the necessary values to input into the scangauge so i can see what you are talking about?
I like Toyotas.
post #58 of 67 (permalink) Old 01-07-2013, 05:57 AM
tacomatic1's Avatar
Quoted: 7 Post(s)
oh maybe yours is different...i have no idea what you're talking about haha...i just plug it in and cycle to the "AFR" reading and it gives a value between 0-110.
post #59 of 67 (permalink) Old 01-07-2013, 09:34 AM
Quoted: 82 Post(s)
My sg2x dossn't show an AFR
BTS, have you tried any other wideband gauges?
Is there a voltage spec per afr # that you could compare with a volt meter?
post #60 of 67 (permalink) Old 01-07-2013, 09:53 AM
tacomatic1's Avatar
Quoted: 7 Post(s)
yeah it is in the AEM UEGO manual
two issues lofting lean condition at 1/4 throttle and 4x4 actuator mark2002double Performance 5 12-29-2005 07:05 PM
throttle body opening half way troymm Performance 10 06-13-2005 05:38 AM
Half red half clear tailights for 98 4x4 PGD55 Lights / Exterior Electricals 9 11-02-2003 03:41 PM
does the throttle cable trick work good? life Performance 3 09-13-2003 06:27 PM
SR: 'Taco Lean' (Noticeable 'Lean' / 'Tilt' to One Side) hschen S-Runner Talk 5 10-01-2002 09:17 AM
