3rz Swap ECU Simplification - Toyota Tacoma Forum
post #1 of 7 (permalink) Old 06-04-2012, 12:15 PM Thread Starter
Jethrobodean's Avatar
I'm working on a 2004 3rd gen, 4 coil 3RZ swap into a Samurai offroad Buggy, & hoping to simplify this setup down to the absolute basics. I've stripped a 22RE down to the necessities, & like the simplicity of it. No smog, not street legal, & trail only.
A list of the things I'm hoping to delete:
Evap system
EGR system
Downstream O2
VSS (Not 100% sure if this is required or not)
Everything to do with AC (again, not sure if ECU is looking for anything here)
I've found a few threads mentioning a resistor for the EGR, & some vacuum line trickery for the Evap. (keeping the sensor, & VSC) In the hopes of doing it right, I'd rather not have them at all, rather than just tricking the computer into thinking they're there. What I haven't found is if anyone's found any tuning software that will work for these. Or possibly if there is a reputable tuner I could send it off to & have things completely removed from the system?
Been through several threads on this picking out info, these are the questions I never found answers for. (Most all other questions were answered in Marlins swap thread)
Cliffs:
Does the 4 coil 3rz require the VSS?
Is the ECU looking for something from the AC system, or is this a simple cut it out?
Anything else that I'm missing could potentially be removed?
Does anyone have a software recommendation, or a vendor who could do the programming. (preferably with 3rz experience)
Is this even doable (tune) with the stock ECU?
Thank all for any advise.
Jethrobodean is offline
post #2 of 7 (permalink) Old 06-04-2012, 02:28 PM
Josh Taco's Avatar
Re: 3rz Swap ECU Simplification
Evap system
EGR system
Downstream O2
Cliffs:
This has nothing to do with your questions... but I see you are deleting "everything to do with AC"... you wanna sell it?
Need some ideas? Come see my build [/URL].
Josh Taco is offline
post #3 of 7 (permalink) Old 06-04-2012, 02:37 PM Thread Starter
Eventually, but not anytime soon. Will be missing some stuff too (evap, lines, etc.), as it's a front end / roof damage total.
post #4 of 7 (permalink) Old 06-05-2012, 10:13 AM
Tacorvette enthusiast
Evap system
EGR system
Downstream O2
Cliffs:
Does the 4 coil 3rz require the VSS? No, you do not need a speed sensor for ign. coil function
Is the ECU looking for something from the AC system, or is this a simple cut it out? Just remove it, wont be a problem and will not affect ECU operation.
Anything else that I'm missing could potentially be removed? Nothinig that will be a benefit, you got it pretty much covered
Does anyone have a software recommendation, or a vendor who could do the programming. (preferably with 3rz experience).
I am a tuner and technician with years of experience on the 2-3RZ platforms, you cannot tune these ECU's. The only way to change things is with a piggyback computer so you can skew the signals.
Is this even doable (tune) with the stock ECU? Negative, see above, its not like the Chevy or Ford read/write style ECU, piggyback or standalone needed.
BOOST BRIGADE I fabricate custom parts: HEIM STYLE STRUT RODS, FORWARD FACING INTAKE MANIFOLDS, and TRACTION BARS (5 LUG) contact me for more info @ www.Speed-freek.com or just PM me here THANKS!
Former Lexus / Toyota tech
post #5 of 7 (permalink) Old 06-05-2012, 10:23 AM Thread Starter
Thank You sir, after a few hours of searching & reading last night, that's pretty much what I had come up with. Only way to remove things is to "trick" the ECU. I had just ASSumed all of the late model OBD2's were read/write.
So, VSS should have no effect on fuel or IGN. mapping? Will I see any SES codes without it?
Also, so far, seems a few resistors for the Evap, and for the EGR seems to be the accepted method of tricking the ECU. That sound right to you?
post #6 of 7 (permalink) Old 06-05-2012, 10:26 AM
You are correct, as far as CEL light, you should have none with VSS disabled, I didnt have one for a while and had no light.
I too am thinking of building an off road rig using Toyota drivetrain and Samurai body. Seems like the way to go, light and strong, and will go anywhere, I currently have a Jeep but it is really heavy!
post #7 of 7 (permalink) Old 06-05-2012, 10:40 AM Thread Starter
Yup, a real nice platform to build off of. I'm fully caged & on 36's now, 1.6 /stock transmission / Toyota doubler / Toyota axles. Loaded with tools, fuel, & me in the drivers seat, I'm at 3050#, 52f-48r% weight bias. It hooks REALLY good, but just lacks the torque to really get any wheel speed. Crawls awesome, but if it gets wet or muddy, you're looking for some ponies.
Original plan was a 22RE, but the 3rz came along, & is IMO alot more engine. I'll probably gain about 300# between engine & transmission upgrade, but for twice the HP, & 3 times the torque, I can live with a few extra pounds.
Not needing the VSS is a relief. I don't have any gauges anyway, just warning lights, & intend to stay that way.
Undoing gear swap for another gear swap Balboa X-Runner Talk 28 11-16-2008 10:11 PM
2jz swap Firdaddy Off Topic 1 08-31-2006 03:39 AM
2.7 swap SpoolinTaco Performance 4 08-03-2005 05:16 PM
v6 swap from 2rz teamrj83 Performance 3 06-02-2004 05:28 AM
2.4L swap to a 2.7L? teamrj83 Performance 12 11-24-2003 11:19 AM
