Direct port methanol injection - Toyota Tacoma Forum
post #1 of 14 (permalink) Old 09-12-2008, 08:56 PM Thread Starter
Cruznlife1's Avatar
Why ? Because I can
I'm fabricating my new intake manifold. Methanol is next and instead of a single nozzle at the throttle body, I was considering direct port with some nice hard lines etc.... I'm not sure about what injectors/nozzles to use, and what bungs to weld into manifold.. I had meth on my turbo ranger, and I still have the fittings, solonoid, nozzle etc. from that. All I really need is a pump to get it in the tacoma, but while it's all torn apart I'd like to do direct port, just because. I want to do it all pretty with polished stainless hard lines. Can anyone point me in a specific direction ? I've been googling
Cruznlife1 is offline
post #2 of 14 (permalink) Old 09-14-2008, 06:06 AM
Re: Direct port methanol injection
Do you have a supercharger? The bower will vaporize the mix i would think. At least that is how I picture it in my mind. Keep in mind I am drunk.
EDIT: OK dur, i see in your sig you a 3rz. Nevermind
elfonzerio is offline
post #3 of 14 (permalink) Old 09-14-2008, 11:33 AM
Hal
Originally Posted by Cruznlife1 View Post
Why ? Because I can
I'm fabricating my new intake manifold. Methanol is next and instead of a single nozzle at the throttle body, I was considering direct port with some nice hard lines etc.... I'm not sure about what injectors/nozzles to use, and what bungs to weld into manifold.. I had meth on my turbo ranger, and I still have the fittings, solenoid, nozzle etc. from that. All I really need is a pump to get it in the Tacoma, but while it's all torn apart I'd like to do direct port, just because. I want to do it all pretty with polished stainless hard lines. Can anyone point me in a specific direction ? I've been googling
do you run an inter-cooler? The idea of direct injection has been done at our shop a few times. We ran into control and uneven mixture levels. now the injectors were at about middle of the runners on a 22rte and a an 4.3l Chevy v6. But the mixture never delivered evenly, the outer cylinders always ran leaner on the ends of the engine. This was determined by exhaust temp chamber temp and mixture sampled at turbo outlets. We concluded that the main problem was lack of proportional control, but setting an alcohol - meth program and controls up was just more than a small problem. We are now injecting between throttle body and manifold Thur a custom throttle spacer with twin nozzles and have not had the same problems.
Hal is offline
post #4 of 14 (permalink) Old 09-14-2008, 11:41 AM Thread Starter
Cruznlife1's Avatar
Yes I'm running a large air/air.... I figured direct port would be key to equal distribution, I've been wrong before though.... I assumed injecting at the throttle body would be the most practical, cheapest, easiest. My "keep it simple" attitude keeps rearing it's head and I know I should start listening... Like I said I have a full single nozzle methanol kit already here, I just dont have the pump. I'm dont have an EGT setup, and I was worried about equal distribution. Maybe a dual nozzle installed in the plenum, aimed between each pair of runners
Or just run what I've got at the throttle body, this will be a large plunum, short runner intake, maybe I should consider some EGT probing
post #5 of 14 (permalink) Old 09-14-2008, 11:43 AM
Tred's Avatar
So, direct port is when you place the injectors in the runners?
Vrrm pssht!
Tred is offline
post #6 of 14 (permalink) Old 09-14-2008, 11:48 AM Thread Starter
Cruznlife1's Avatar
yes, just like the fuel injectors
post #7 of 14 (permalink) Old 09-14-2008, 11:55 AM
Tred's Avatar
LUCKY!!
Vrrm pssht!
Tred is offline
post #8 of 14 (permalink) Old 09-14-2008, 12:48 PM
Tacorvette enthusiast
Im going to do the same...Just gotta find a place to get the parts for cheap, seems Devilsown.com has good prices on this stuff.
I think I will use 1 injector do to the possible problems, I would hate to have 1 injector of 3 stop working and ruin the engine. The only way I would do 4 nozzles is if I had EGT per cylinder.
Edit:Cant spell
BOOST BRIGADE I fabricate custom parts: HEIM STYLE STRUT RODS, FORWARD FACING INTAKE MANIFOLDS, and TRACTION BARS (5 LUG) contact me for more info @ www.Speed-freek.com or just PM me here THANKS!
Former Lexus / Toyota tech
post #9 of 14 (permalink) Old 09-14-2008, 02:04 PM
Hal
The only way I believe direct injection will work would be with a very high pressure injector to be sure of complete vaporization before the air/ alcohol mix separate down the individual runners. Quick note checking tempts is critical. If you are going to try this get a pair of exhaust temp from at least two cylinders. On a tune up run you can use an infrared no touch thermometer.
Hal is offline
post #10 of 14 (permalink) Old 09-15-2008, 09:13 AM
dprofeta's Avatar
If you are running an intercooler, why don't you want to plumb the methanol into the intercooler? That is what I see most commonly with turbo'd intercoooled meth setups.
2000 Tacoma , 4X4 5-speed, TRD S/C , TRD Headers, TRD Exhaust , URD Fuel Mods & 2.2" pulley, URD AFR Controller , URD Short Shifter, AEM Intake , Aquamist Methanol Injection, Camburg Coilovers, 32x11.50 BFG AT's
dprofeta is offline
Hmm.... Can I use an 8 port head where a 4 port used to be ? Cruznlife1 Performance 0 04-06-2008 09:52 PM
Question: Enclosure & Port size (long & technical) Comattack Interior/Audio/Electronics 7 11-15-2007 04:04 PM
What methanol to run? dprofeta Performance 7 03-13-2007 09:50 AM
Devils Own Water Methanol Injection Sytstem $175 shipped WideOpenTuning Parts and Accessories 16 11-19-2006 10:18 AM
water injection through EGR port gastafalo_bob Performance 2 03-11-2004 06:43 AM
