3.4 cylinder order - Toyota Tacoma Forum
post #1 of 7 (permalink) Old 11-11-2007, 09:55 AM Thread Starter
3.4 cylinder order
How's it going? I just recently threw some codes (PO300, PO302 & PO305). These relates to a multi misfire, a misfire on cylinder 2 and a misfire on cylinder 5. The pick up is an 01 with the 3.4 V6. My question is looking at the engine from the front which cylinder is which when it comes to engine codes? Looking at the three plug wires they are in some weird order (drivers side is like 5, 1, 3 from front to back. I want to find out which cylinders the computer relates the PO302 and PO305 to. Thanks for any correct help you can give with this.
SR5Tacoma is offline
post #2 of 7 (permalink) Old 11-11-2007, 10:06 AM
damn
spyder041's Avatar
Re: 3.4 cylinder order
looking from the front of the truck, look at the spark plug closest to you, thats #1. Then across the block on the other side, is 2..back and forth till #6...Got it?
New Jersey: Home of where the strong survive, and the weak are killed and eaten.
http://www.myspace.com/wildjerseyfirefighter
Photo Sharing and Video Hosting at Photobucket
spyder041 is offline
post #3 of 7 (permalink) Old 11-11-2007, 10:39 AM
Supporting Vendor
One coil fires two cylinders.
Coil 2 also fires cylinder 5 I think.
You most likely have a coil problem.
Look at the plug wire on coil 2, if it is stock it will have the cylinder number that the wire goes to. Make sure it is cylinder 5.
To confirm it is a coil problem, you can swap coil 2 for coil 1 and see of your missfire follows to coil 1. If so, you probably need a new coil.
Gadget
Gadget@URD is offline
post #4 of 7 (permalink) Old 11-11-2007, 09:03 PM
Hope the attached pic is useful.
1-4 fire together
3-6 fire together
5-2 fire together
waldog is offline
post #5 of 7 (permalink) Old 11-11-2007, 09:19 PM
Supporting Vendor
Damn, I almost got it right.
Coil three (cylinder 5) also fires cylinder two.
Anyway, move that last coil and see if the missfire follows the coil.
Gadget
post #6 of 7 (permalink) Old 11-13-2007, 06:58 AM
Jade's Avatar
...and a new one (dealer only) is just about $100. Call either:
Trdparts4u
TOP
...or your favorite dealer.
Tesla > Edison
Jade is offline
post #7 of 7 (permalink) Old 11-14-2007, 12:57 PM Thread Starter
To all,
Thanks for the replies and all of your help! Waldog, thanks for the picture, I have the TRD blower on the engine so looking straight down on it to see which spark plug is closer to the front of the engine (#1) is a little harder. I was going to take a guess and would have had it correct but a picture is always better. With both misfire codes and those cylinders ( #2 & #5) running off of the same coil pack it is looking more like the pack it bad. I will clear the codes in the next day or so and swap the pack with another and see if the CEL comes on with two different locations then. The truck is a 01 with only 9k miles on it so those things must be junk (not enough miles for it to go back).
Thanks again
Something fell in my cylinder....need some help/ideas ChrisTaco Off Topic 44 10-07-2007 06:07 PM
3 & 4 cylinder missfire on a 2.4l losbadgts 1995.5 - 2004 13 10-28-2006 02:34 AM
Crutchfield ROCKS!!! 03TacoPre Off Topic 6 12-28-2005 12:49 PM
89-95 master cylinder question norcals-lowest 1995.5 - 2004 0 06-14-2004 04:44 PM
