Adjusting headlights? - Toyota Tacoma Forum
post #1 of 32 (permalink) Old 12-29-2004, 06:04 PM Thread Starter
xxxxxBazzy's Avatar
The search feature on here doesn't help too well. I tried to find out how to adjust headlights and couldn't get anything, so would someone like to tell me where the little screw is that i have to twist to adjust my headlights down a little bit, alot of people are flashing their brights at me. I'm afraid when i drive behind cops or go by them on one lane roads they're gonna pull me over, and i have a warrant right now so that will most definitely suck.
xxxxxBazzy is offline
post #2 of 32 (permalink) Old 12-29-2004, 06:05 PM
Probation
Re: Adjusting headlights?
If that's the case, your headlights are the least of your worries
fabtaco is offline
post #3 of 32 (permalink) Old 12-29-2004, 06:09 PM Thread Starter
xxxxxBazzy's Avatar
Well it's not a very big deal even though i can go to jail for it. I skipped school with a few people and went to get some food during our lunch break and got tickets for daytime curfew. Then i accidently missed my court date and got a warrant served so.. i've had a few cops tell me they don't feel like dealing with the paper work so they just lemme go. Fab you know how to adjust my lights?
post #4 of 32 (permalink) Old 12-29-2004, 06:14 PM
Probation
Check the back of the headlamp housings, in the space between the airbox (right side) and the battery (left side). There should be like a plastic piece sticking out, use a wrench and socket to move the headlights. There's 2 per side, one controls vertical, the other horizontal.
fabtaco is offline
post #5 of 32 (permalink) Old 12-29-2004, 08:43 PM
Quoted: 193 Post(s)
Well, here's what the '04 FSM has to say about headlight adjustment... If it sounds weird / incomplete, well... that's what it says.... I'm guessing your '01 is same / similar, 'cause '01 was the year that front style was introduced.
First, there's only one adjustment control on each side, outboard of the headlight units / just inside the fender wall in the engine compartment. Like Fabtaco said, it protrudes backward toward the rear. This controls vertical alignment only. There is no adjustment for horizontal alignment.
I interpret the official procedure as follows (* someone in the truck; springs bounced to relieve any pressure / tension):
- get the truck on a level surface facing a vertical wall
- mark on the wall the level / line directly in front of the headlight bulb / center (i.e., @ same vertical height as headlight)
- back the truck away from the wall to a distance of 3 meters (9.84 feet) from the wall surface to the headlights
- turn on low beams
- the low beams should hit the wall 20.9 mm (0.823 in.) _below_ the line @ headlamp height (based on designed 4 degree low beam downward deflection from horizontal)
- use the vertical adjuster bolt / screw to make this so
This should work on any model, because the spec is relative to horizontal from lamp center, not distance from the ground.
post #6 of 32 (permalink) Old 12-29-2004, 09:14 PM
Probation
That's odd...my 97 has both the vertical and horizontal adjustments...I must have assumed that they were still there.
fabtaco is offline
post #7 of 32 (permalink) Old 12-29-2004, 09:23 PM
Quoted: 193 Post(s)
My former '85 and my beater '93 both had / have the dual adjusters. I didn't believe what I was seeing in the '04 FSM until I saw the note that reads "...the horizontal direction is impossible to adjust..."
I don't know for sure that this applies backward to the original poster's '01... I'm just guessing it might, since that's when the last edition of the front end came on the scene.
post #8 of 32 (permalink) Old 12-30-2004, 02:12 AM
Tred's Avatar
On my 2002, there is one adjustment piece on each headlight. It appears to be a bolt with the last 1cm or so that is hex shaped.
As I started to turn it with an adjustable wrench, it began to strip. A tiny pair of pliers did the same. It must be made of aluminum. I didn't have a 4mm socket either, so I had to create a tool out of a 4mm hex bolt, and two 8mm nuts. Then I used an 8mm wrench to turn this tool. Socket wrench wouldn't fit with the 8mm socket, stepdown adapter, and the wrench itself.
Yours might be stiff too, so don't force it. Do it slowly, and make very very certain it's actually turning even if it feels like it... before it breaks. You'll need a flashlight, too.
My Volant intake box would have to come off in order to adjust the right side. Booo. Left side is very accessible.
Tred is offline
post #9 of 32 (permalink) Old 12-30-2004, 11:04 AM
On my '02, its just as Enola said, vert adj only, and you use a 4mm wrench to adjust it. I pulled the wrench out of my pack o' mini craftsman wrenches, and I keep it in the truck.
MountainBiker is offline
post #10 of 32 (permalink) Old 12-30-2004, 04:16 PM
Tred's Avatar
Early morning today (4 AM), I went driving in town with a loose intake box (for access when adjusting), drove around forever, and I could not find a level ground with a flat wall. Everywhere I went, it was slanted. I think I may have aimed it too high. Also, the beams are uneven on both sides, for whatever reason.
Tred is offline
