2rz oil leak ? need help - Toyota Tacoma Forum
post #1 of 9 (permalink) Old 10-18-2007, 12:34 AM Thread Starter
omarztaco's Avatar
my mother use a 98 twd reg cab 2rz auto for her daily driver to work . when we bought it two years ago it had 48,000 on it now it has 160,000 . her harmonic balancer went out about 5 months ago , had it fixed , i changed the valve cover gasket and oil pan gasket as well. here lately its been leaking some oil . it drips from the drain plug and oil pan but cant pinpoint where its coming from . does anybody know where else this motor may leak from?
Photo Sharing and Video Hosting at Photobucket
omarztaco is offline
post #2 of 9 (permalink) Old 10-18-2007, 04:19 AM
Firdaddy's Avatar
Quoted: 12 Post(s)
Re: 2rz oil leak ? need help
2rz does not have harmonic balencer..ummm.. did you replace it or get it replaced...... and as far as leaks.. hell the drain plug likes to leak unless you have a good gasket on the plug itself, and the stock one is not known for longevity
dumpted since 2/15/08 MMMMMM boos t
Firdaddy is offline
post #3 of 9 (permalink) Old 10-18-2007, 06:48 AM Thread Starter
omarztaco's Avatar
no we had it replaced . honest. i think we have the old one in my garge . unless the mechanic thought thats what it was called and it was the crank pulley
post #4 of 9 (permalink) Old 10-18-2007, 12:54 PM
chipsndukes's Avatar
oil level sender, underneath exhaust man. towards the front about half way up,
check oil filter and the aluminum arm it is screwed into where it meets the block
was the front oil seal replaced when the crank pulley was done?
also the dipstick O-ring where it plugs into the base of the timing cover on the front of the motor.
On the intake side of the motor there is not much that can leak
last but not least, the rear main seal, that would be leaking from the bottom of the trans bell housing, but would be motor oil, blackish color
I don't know if anyone else has something to add.
Spray the motor down good at a high pressure car wash, run it for a while, then crawl under there and poke around, hard to find a leak on a filthy motor.
Chipsndukes
chipsndukes is offline
post #5 of 9 (permalink) Old 10-18-2007, 01:13 PM
oil pump seal like to leak on these. like someone else stated alawys replace oil drain plug gasket with every oil change. one time use.
sheepwundr is offline
post #6 of 9 (permalink) Old 10-18-2007, 03:35 PM
here's what works for me:
http://www.partsamerica.com/ProductD...pe=797&PTSet=A
if you cant see the link, go to partsamerica.com and search "oil drain plug gasket" , it's the white nylon one.
Chipsndukes
post #7 of 9 (permalink) Old 10-19-2007, 10:18 AM
i use the factory teflon drain plug gasket but that is just because i had sh!t load when i left the last dealership.
post #8 of 9 (permalink) Old 10-22-2007, 01:49 PM
yea replace the gasket. it doesnt last very long. and i dont think 2rz has a balancer, only 3rz.
Total Chaos Long Travel Front, Engage Offroad Long Travel Rear, Trutrac LSD, Big Ron front bumper, USMC2003 rear
tacoyota is offline
post #9 of 9 (permalink) Old 10-23-2007, 10:34 AM
What would an oil level sender be? The tube?
jimstoy is offline
holy oil leak bat man johnny06 X-Runner Talk 2 02-03-2007 08:09 PM
Bad Oil Leak On 2.4 Mac8008 Performance 6 01-27-2007 07:05 AM
2003 Tacoma Crewcab oil leak ? ? ? don 1995.5 - 2004 15 10-20-2006 09:06 AM
2RZ / 3RZ Oil Filter Relocation Kit Proteus503 1995.5 - 2004 22 07-16-2004 10:21 PM
Stupid oil question... GlocksRock 1995.5 - 2004 10 09-27-2003 10:17 AM
