won't pass emissions. - Toyota Tacoma Forum
post #1 of 9 (permalink) Old 06-07-2006, 09:52 PM Thread Starter
spicy taco's Avatar
My truck won't pass at the emissions testing place. I had the battery disconnected while i was working on something prior to the first testing attempt.
They said I failed bacause the ecu was still getting all its **** together after being reset.
Ive got an ODBII diagnostic thing for my laptop. Ive put nearly 500miles on the truck since the ecu was reset and it still hasn't completed the evaporative system monitor test.
Ive got no CEL codes. truck runs great, it just won't seem to do that last test. (non-continuous test)
Is there some trick I need to do. Does the damn thing need to just sit and idle for an hour. Can I invoke the test?
I have to get this figured out or I can't get new registration.
spicy taco is offline
post #2 of 9 (permalink) Old 06-07-2006, 09:55 PM
Firdaddy's Avatar
Quoted: 12 Post(s)
Re: won't pass emissions.
well its still not settign the readieness codes.. shoudl do it in a few hundred miles.. that really weird man.. mabey talk to someone at the stealership.. correct me if i am wrong but i think maufacturers warranty emissions equiptment for 10 years
dumpted since 2/15/08 MMMMMM boos t
Firdaddy is offline
post #3 of 9 (permalink) Old 06-08-2006, 12:50 AM
Probation
Just keep driving it. There's no pre-set number of miles it has to reach in order to be ready for testing...you just have to give it time and drive it. Best thing to do is to keep monitoring the system...
fabtaco is offline
post #4 of 9 (permalink) Old 06-08-2006, 01:06 AM Thread Starter
spicy taco's Avatar
well i found an article at http://www.aa1car.com/library/ic10224.htm
that states:
READINESS FLAGS
An essential part of the OBD II system are the "readiness flags" that indicate when a particular monitor is active and has taken a look at the system it is supposed to keep watch over. The misfire detection, fuel system and continuous system monitors are active and ready all the time, but the non-continuous monitors require a certain series of operating conditions before they will set - and you can’t do a complete OBD II test unless all of the monitors are ready.
To set the converter monitor, for example, the vehicle may have to be driven a certain distance at a variety of different speeds. The requirements for the various monitors can vary considerably from one vehicle manufacturer to another, so there is no "universal" drive cycle that will guarantee all the monitors will be set and ready.
As a general rule, doing some stop-and-go driving around town at speeds up to about 30 mph followed by five to seven minutes of 55 mph plus highway speed driving will usually set most or all of the monitors (the converter and EVAP system readiness monitors are the hardest ones to set). So if you’re checking the OBD II system and find a particular monitor is not ready, it may be necessary to test drive the vehicle to set all the monitors.
The Environmental Protection Agency (EPA) realized this shortcoming in current generation OBD II systems.
So, when it created the rules for states that want to implement OBD II testing in place of tailpipe dyno testing, it allows up to two readiness flags to not be set prior to taking an OBD II test on 1996 to 2000 vehicles, and one readiness flag not to be set on 2001 and newer vehicles.
Some import vehicles have known readiness issues. Many 1996-’98 Mitsubishi vehicles will have monitors that read "not ready" because setting the monitors requires very specific drive cycles (which can be found in their service information). Even so, these vehicles can be scanned for codes and the MIL light without regard to readiness status.
On 1996 Subarus, turning the key off will clear all the readiness flags. The same thing happens on 1996 Volvo 850 Turbos. This means the vehicle has to be driven to reset all the readiness flags.
On 1997 Toyota Tercel and Paseo models, the readiness flag for the EVAP monitor will never set, and no dealer fix is yet available. Other vehicles that often have a "not ready" condition for the EVAP and catalytic converter monitors include 1996-’98 Volvos, 1996-’98 Saabs, and 1996-’97 Nissan 2.0L 200SX models.
That makes sense why my evap monitor is still "not ready" The last time i had it tested i think I still had 2 "not ready" tests, but now the evap is the only one. according to this article a 2001 vehicle is only allowed 1 "not ready".
I'll try having it tested again, according to this article I should be fine now.
I just wanted to post what I found in case someone might have this problem later on and might find this useful. I'll confirm tomorrow if I passed or not.
edit: my advice, don't disconnect your battery if your registration is about to expire, haha.
post #5 of 9 (permalink) Old 06-08-2006, 06:49 AM
www.LiquidAss.com
BRB GTG PP's Avatar
Eight years.
BRB GTG PP is offline
post #6 of 9 (permalink) Old 06-08-2006, 06:56 AM
Flaming Bastard
BoostError's Avatar
I've never passed emissions before
airbag light warns passenger that they are the first to die - TallTacomaGary
BoostError is offline
post #7 of 9 (permalink) Old 06-08-2006, 11:19 PM Thread Starter
spicy taco's Avatar
got it tested and i passed this time. EVAP "not ready" is allowed to slide.
post #8 of 9 (permalink) Old 06-09-2006, 11:40 PM
Firdaddy's Avatar
Quoted: 12 Post(s)
Originally Posted by BRB GTG PP
Eight years.
think they'll notice the lack of any cats pvc valve and the addition of a turbo
Firdaddy is offline
post #9 of 9 (permalink) Old 06-10-2006, 12:41 PM
Good think I have "hook ups"...
Sorry buddy to hear that...
JDM'ized is offline
Will an AZ-bought Taco pass CA emissions? UofATaco Off Topic 3 11-04-2005 06:47 AM
Im240 emissions test on 2.7 Gaz On Road 27 02-07-2005 05:53 PM
Looking for suggestions to PASS SMOG TEST 3.4 Supercharged V6........ 1991Supercharged Performance 7 02-06-2005 08:19 AM
Emissions CE Codes THRICEGUY 1995.5 - 2004 4 12-09-2004 09:34 AM
pass smog? lowtaco915 Performance 2 12-28-2003 01:41 AM
